Old 11-07-2010, 04:36 PM   #31
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,226
Originally Posted by tmex
FWIW, HP2 rims are NOT compatible with F800 hubs.
This doesn't suprise me, what was the final uncrossable hurdle?
The next question would be on the availability of suitable aftermarket hubs that will accomodate the dual disks and ABS and work with the cross spoke rims.. Probably too much to expect
MCMXCIVRS is offline   Reply With Quote
Old 11-07-2010, 05:35 PM   #32
tmex
tmex's Avatar
Oddometer: 2,039
F8 - 36 spokes
HP2 - 40 spokes
Mush different angle and method of hub interface and very different spoke lengths. Just about everything.
my favorite bike - R1200GS
tmex is offline   Reply With Quote
Old 11-07-2010, 08:38 PM   #33
bxr140
Flame Bait
bxr140's Avatar
Oddometer: 1,041
Originally Posted by EnderTheX
I'm talkin field repair, break the bead on one side, pull out the tube, re-insert tube, fight with valve stem, curse, finally tube is in and then re-seat bead.
I don't pull the entire tire off the rim when I'm repairing in the field...
Oh. Got it. Its just as easy for me to unmount and remount the second bead. I guess I don't mind spending the extra 2 minutes. I always change tires with field tools, so its all pretty much second nature.
bxr140 is offline   Reply With Quote
Old 11-08-2010, 03:24 AM   #34
tmex
tmex's Avatar
Oddometer: 2,039
It is much harder to get the bead over the rim (on or off) if both beads are not broken. Breaking the beads is by far the hardest (and most time consuming) part of tube replacement. When working the edge of the tire always be sure to have both beads on the opposite side near the middle of the rim.
Old 11-08-2010, 05:42 AM   #35
woody's wheel works
Built to Last
woody's wheel works's Avatar
Oddometer: 3,426
slight modification to ease ''breaking the bead''...
howdy tmex,,,,
FYI,,,there have been numerous posts prompted by the troubles folks had busting the bead on the 950Adventure rear wheels....the Behr rim has one of the highest/tallest safety beads i've ever seen
Rx= grinding/filing down about a 6''section of bead near the valve stem on both sides [we do that so you'll know where to apply the pressure from your sidestand]
now you have a place to apply the pressure and get instant results,,,using your side stand works wonders...
w
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 11-09-2010, 08:21 AM   #36
LaPorte
LaPorte's Avatar
Oddometer: 500
Replacing the tube
I have changed many tubes due to flats in the field. It's not to bad a job, especially if you have someone there to help. Just had a flat on the rear of my F8 last week. Changing the flat was not bad, got it done in about an hour. Had trouble getting the bike on the center stand. Bike has been lowered. Getting the wheel back on, now that was a PITA. Couldn't get it on unless I removed the brake pads. Something in the braks calliper would not allow it to return to the full open position. Needed to complete my ride home without rear brakes. Next day I played with the calliper and found no trouble, in the garage it would open to the full open position. I replced the brake pads and it's ready to go!
You tell me???????
LaPorte
If you don't know where your going don't lead!
LaPorte is offline   Reply With Quote
Old 11-09-2010, 08:33 AM   #37
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
You tell me???????
LaPorte
Sometimes you need to get in between the pads with a flathead screwdriver or similar tool and pry them open wider. There was nothing in there that was preventing movement other than than a lot of hydraulic pressure. Most of the time it is too much to overcome with just the human hand, which is why you need to use the rotor itself or a flathead screwdriver or something to re-widen the opening. Why did you need to widen the opening between the pads anyway? Did someone squeeze the rear brake lever while the wheel was off? If the rear brake lever is left alone while the rear wheel is off, the rear wheel's rotor should slide right back in between the pads no problem.
The moral of the story is: don't squeeze the brake lever even the slightest bit while the wheel is off, or you'll have to re-widen the opening between the pads so the rotor will fit.
Old 11-09-2010, 08:45 AM   #38
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
PS, the reason it was too hard to re-widen the space between the pads/calipers by hand out in the filed is because the the brake fluid, brake lines, brakes, etc were just in use a wee bit ago. Therefore there is a higher level of hydraulic pressure within the system pressing against the calipers in the brake itself.
Now fast forward to the next day when it was easy enough to re-widen the calipers by hand. This is because the brake system was not in use for a number of hours. Therefore there was less hydraulic pressure pressing against the calipers. Easy-peazy lemon squeezy to press 'em open by hand at that point.
Rule of thumb is that when out in the field, the brake system is in use and there is a operational level of hydraulic pressure against the calipers. Therefore it will be extremely hard to re-widen the space between the calipers by hand. So don't squeeze the brake lever while the wheel is off even a tiny bit.
You can feel what I'm talking about when you get into your car and go for a drive after it has been sitting overnight or longer. Notice how easy it is and how far you have to push on the brake to get it to actuate? The brake feels squishy and you have to push it in farther. Then pump the brake a few times. Now notice how much less you have to press the brake to get it to actuate and how much more firm it feels? There is a lot more pressure against the calipers now and the brake system is in operational state.
Old 11-09-2010, 08:50 AM   #39
LaPorte
LaPorte's Avatar
Oddometer: 500
The first thing I did before trying to replace the wheel was spread the calliper with a screw driver. Seeing that the wheel wouldn't fit because of the brake pads, I tried spreading them again and again. No go thats why I removed the brake pad to get home.
The next day with one pad in (piston side) I pumped the brake pedal until the calliper touch the brake rotor. Then with my thumbs, I slid the calliper to full open and replaced the second brake pad.
Like I said-----you tell me???????
LaPorte
Old 11-09-2010, 09:01 AM   #40
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
LaPorte
I just did. Read thoroughly above.
The wheel's rotor will slide right back in between the pads if no one touches the lever while the wheel is off. Someone or you squeezed that lever while the wheel was off. Don't do that again. That is the answer.
The technical answer as to why it was hard to re-widen between the pads is in my post above. Let the bike sit for a bit then try and re-widen the space between the pads again. Time is your friend.
Old 11-09-2010, 09:17 AM   #41
itsatdm
itsatdm's Avatar
Oddometer: 4,873
It is fairly easy to bump one of the pads out of position when struggling with the tire. It pops out and hangs down a little. If you see it, usually you can put it back with that screw driver. If you don't it won't retract.
itsatdm is online now   Reply With Quote
Old 11-09-2010, 09:20 AM   #42
digdesign
Hack
digdesign's Avatar
Oddometer: 151
What you're saying is that hydraulic lock is present immediately after use but dissipates over time. This goes against everything I know about modern braking systems. Is that your personal theory or a fact? Can you point to root cause of lock in the system?
2010 F800GS
2009 Buell XB12Scg FOR SALE
1990 E30M3 track rat
digdesign is offline   Reply With Quote
Old 11-09-2010, 09:24 AM   #43
tmex
tmex's Avatar
Oddometer: 2,039
LaPorte
You need a metric screwdriver to spread the pads on a BMW.
Old 11-09-2010, 09:46 AM   #44
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
Firstly, I didn't say "lock" I said "pressure level". Secondly, I don't fully understand why what I was saying happens, but it is my experience with changing tires and tubes that what I said in my posts above actually happens. And again, I wasn't saying that hydro-lock happens. I understand how hydraulics work and specifically hydraulic brake systems, but we need to understand that there may be things about it that are very complex that cause things like what I was talking about. Just because you and I understand the basics of 'modern' hydraulic brake systems doesn't mean we know what could or could not potentially happen within the system while changing a tire on the F800GS.
It obviously happens, and happened to LaPorte. Why that is? I don't fully know. If you want to go figure it out be my guest. I was simply telling him my experience of what works and how to go about it.
Old 11-09-2010, 09:49 AM   #45
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
Times are GMT -7.   It's 11:20 AM.
