Old 10-05-2012, 03:31 PM   #46
Bluethumb
Oddometer: 124
Cylinders
Your cylinders look great, at least in my limited experience. I've pulled the cylinders off maybe 4-5 airheads, and the cylinder walls have always looked like the picture you posted. What I've been told is that those "swirls" are the factory honing marks. Maybe someone else can jump in and tell me if that's true. I pulled the cylinders off my old RS with 100k and the cylinder walls looked brand new. I thought that was so impressive.
I was always told to reassemble the pistons into the cylinders dry, but again, this was years go and someone with far more experience may want to jump in on reassembly. I did not hone the walls, simply installed new rings and put the pistons back into the cylinders and buttoned everything back up.
What's great bout these motors is they are extremely easy to work on. Plus this forum helps to make it even easier.
Just for fun, ask what kind of oil you should use..........just kidding! Starting a dreaded oil thread cn be dangerous!
Bluethumb is offline   Reply With Quote
Old 10-09-2012, 05:46 AM   #47
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 3,379
Anyone have any comments concerning the piston top wear / pattern?
One of my R100S pistons had a similar minor "pitting", but not near as deep or rough as this.
I rebuilt my top end and used the pistons with no issues yet.
http://jupiterhack.blogspot.com
Living proof you shouldn't play with matches
Old 10-09-2012, 05:57 AM   #48
Horsehockey
A GPS? Huh?
Oddometer: 222
See post #33. BMWrench has provided the likely explantion.
Horsehockey is offline   Reply With Quote
Times are GMT -7.   It's 03:24 AM.
