Old 11-04-2010, 02:07 PM   #1
dbarc38 OP
Oddometer: 6
2010 GS Horn
I'm ready to replace the stock horn on a 2010 GS with a Stebel Magnum and the stock horn is powered via a Canbus connection. Notify Jerry F. at Pirate's Liar and he said he has never seen a horn without the two prongs to plug in the positive and negative wires. So my question is what have others done?
Dave
dbarc38 is offline   Reply With Quote
Old 11-04-2010, 02:18 PM   #2
Nitzo
Nitzo's Avatar
Oddometer: 4,894
best thing to do is a search for the stebel, lots has been written about it. btw, great horn, i love mine.
Nitzo is offline   Reply With Quote
Old 11-04-2010, 02:20 PM   #3
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,349
Contact Tom at http://www.excelcyclewerkes.com/ and order one of his kits. Wiring and mounts all ready to go. Oh, and you only need to tap into the hot side to activate the relay to make it work.
Jim
Old 11-05-2010, 01:29 PM   #4
Sleepy John
Grumpy Adventurer
Sleepy John's Avatar
Oddometer: 3,731
The Stebel Magmun horn and wiring kit from Nippy Normans makes installation of a new horn into a simple plug and play operation with no need to tap or cut into your wiring. You do not need to install a relay for this horn however you would need one if you decided to install the Stebel Nautilus compact air horn.
Horn wiring kit for BMW bikes with Can-Bus wiring
http://www.nippynormans.com/Horn-wir...B%2DCANBUSKIT/
MAGNUM HORN (black) - 136dB (WITHOUT spade connectors)
http://www.nippynormans.com/MAGNUM-H...nfo/STB%2DZZZ/
Standard BMW horn next to Stebel Magnum
Sleepy John
'10 R1200GSA Big Pig, '10 DR650SE Piglet
Don't shoot... It's only me!
Women and cats will do as they please, and men and dogs should relax and get used to the idea.
Sleepy John is offline   Reply With Quote
Old 11-08-2010, 06:56 AM   #5
itrider01
itrider01's Avatar
Oddometer: 72
Quick question Sleepy John, have you heard this model horn next to the Stebel? I had a Stebel on my previous bike and loved it, but a simpler install for the same effect would be great.
Thanks.
itrider01 is offline   Reply With Quote
Times are GMT -7.   It's 01:27 AM.
