Old 09-16-2014, 10:26 AM   #1
skeelo221 OP
Oddometer: 108
2013 KTM 350 EXC, Headlight stays on?
Hello,
I just picked up a 2013 KTM 350 EXC-F. Sweet bike!
My issue with it when trail riding is when I come to a stop and want to kill the bike for a few min, I hit the kill switch yet the headlight stays on indefinitely until you switch off the key.
Is this the intended behavior? Is there a different relay one can install so that the headlights turns off after, say, 10 seconds after the engine stops running?
skeelo221 is offline   Reply With Quote
Old 09-16-2014, 10:28 AM   #2
sprocket3
Oddometer: 286
Originally Posted by skeelo221 View Post
Hello,
I think that's normal since you've got the ignition in the ON position. My 690 does the same thing.
sprocket3 is offline   Reply With Quote
Old 09-16-2014, 10:29 AM   #3
skeelo221 OP
Oddometer: 108
Are you saying the ignition has 2 "on" positions? That would make me feel stupid if I didn't notice that...
Old 09-16-2014, 10:32 AM   #4
sieg
sieg's Avatar
Oddometer: 2,924
It's a 50 state street legal bike, all 50 state street legal bikes do that.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 09-16-2014, 10:36 AM   #5
sprocket3
Oddometer: 286
When you use the "kill switch" you're not turning off the ignition system completely. Mine still has power to the lights and the ABS system settings stay the same until i actually turn off the key. All you're doing is stopping the engine by using the kill switch.
Nice Bike BTW. I might have seen that on CL as I was looking for a 350 off and on.
Old 09-16-2014, 10:38 AM   #6
skeelo221 OP
Oddometer: 108
My buddy has the 530 EXC and when he hits the kill switch (key stays on) the headlights turn off...
Old 09-16-2014, 11:46 AM   #7
empedrado
Oddometer: 379
The 530 is different than the 500 in that the light is an AC light which requires the motor to be running. The 500 the light is DC. Under the mask there is a dongle that can be removed and the headlight will turn off after a short period of time once the motor is killed.
empedrado is offline   Reply With Quote
Old 09-16-2014, 01:05 PM   #8
skeelo221 OP
Oddometer: 108
Cool! Do you have any further details on this procedure?
Old 09-16-2014, 01:22 PM   #9
empedrado
Oddometer: 379
I must first qualify that I assume the 350 is the same as the 500. Under the mask there should be a connector that is the same shape/size as the one for the headlight. This connector will not have wires coming out of it but terminate with some shrink tube that has been fused. Simply remove this connector and all is well. I keep the connector that is removed in my tank bag, Reconnecting sure helps should you have some issues with the light circuit that might need to be diagnosed.
Old 09-16-2014, 01:32 PM   #10
skeelo221 OP
Oddometer: 108
Thanks a lot!
I will take a look tonight.
Old 10-21-2014, 08:29 PM   #11
skeelo221 OP
Oddometer: 108
I forgot to update you -- this worked brilliantly. Thanks so much for the tip!
Now when I hit the kill switch and leave the key on, the headlight turns off after about a 5-10 sec delay. Once the bike re-fires the headlight turns back on. Perfect.
Times are GMT -7.   It's 10:22 PM.
