Old 09-22-2014, 12:40 PM   #1
jdemeritt OP
Oddometer: 54
KLR Petcock kits
On ebay it seems buying a whole new petcock is cheaper than buying the kit with the diaphragm and gaskets? There are tons of chinese knockoffs, but I'm seeing what look likes either NOS or OEM for ~20 and the kits are ~25. Plus there's always the manual from eaglemike. Anybody have some wisdom here?
jdemeritt is offline   Reply With Quote
Old 09-22-2014, 12:43 PM   #2
Hybridchemistry
Hybridchemistry's Avatar
Oddometer: 394
I bought a whole manual petcock from a reputable guy on eBay, works fine. Keep it simple, silly.
Hybridchemistry is offline   Reply With Quote
Old 09-23-2014, 05:36 AM   #3
75bronco
Oddometer: 366
Go manual. Easy fix and less to screw up.
75bronco is offline   Reply With Quote
Old 09-23-2014, 04:09 PM   #4
jdemeritt OP
Oddometer: 54
That's the route I'll take given theres not a cheaper fix. There is no way to get a kit for less than $28
Old 09-23-2014, 05:16 PM   #5
juddspaintballs
Never too many bikes
juddspaintballs's Avatar
Oddometer: 488
I prefer the manual petcock. I bought mine directly from Ron Ayers using the Yamaha part number 5LP-24500-00-00. It's the same one that Eagle Mike sells and it's from a Yamaha Raptor. I had other stuff to order from Ron Ayers at the same time so it was no skin off of my back to order that part from them as well.
KTM 250EXC | KLR650
You can't say happiness without saying penis.
juddspaintballs is offline   Reply With Quote
Old 09-23-2014, 05:21 PM   #6
nonamehorse
Concrete Jungle
nonamehorse's Avatar
Oddometer: 223
Go manual from eaglemike and never look back.
I like to bite off more than I can chew, then chew it.
nonamehorse is offline   Reply With Quote
Old 10-17-2014, 10:21 PM   #7
REALGRAVEROBBER
LEAVING GRAVES EMPTY
REALGRAVEROBBER's Avatar
Oddometer: 366
Go manual.
The kits on eBay that are no-name, and the parts from genuine Kawasaki usually do not produce a reliable petcock 85% of the time.
Something about the factory assembling them at the start matters. I have seen and tried to rebuild so many vacuum-operated Kawasaki fuel petcocks and seen them not work consistently that I know the only reliable options are:
1.) Buy a new genuine Kawasaki petcock that is over $100, buy the entire unit new with all internal parts installed.
2.) Get a manual type off of eBay and go on your way with no more problems from an unnecessary and complicated failure-prone gizmo only created to appease some wanker lawyer somewhere.
We have a lot to do with how the world receives us.
Dr. Frazier Writing
REALGRAVEROBBER is offline   Reply With Quote
Old 10-18-2014, 03:42 AM   #8
Grinnin
Forever N00b
Oddometer: 2,901
The Raptor petcock (from Eagle Mike or any Yamaha dealer) has a shorter main intake tube which will leave you with less range after switching to reserve. The reserve starts down in the thin points of the KLR tank so it's a big difference.
I like the gallon of reserve that the stock petcock provides. I have a Raptor petcock but I lengthened the main intake to match the stock one.
If you don't mind a short reserve range then the manual Raptor petcock is great. To me maintaining reserve range is worth more than the few dollars the difference in the petcocks or rebuild kits.
"The belief that there is only one truth, and that oneself is in possession of it, is the root of all evil in the world."-- Max Born, Nobel Physicist
Grinnin is offline   Reply With Quote
Old 10-18-2014, 08:55 PM   #9
Tourbus
Location: Pleasant Hope Mo. Escapee from the Tax Nightmare
Oddometer: 138
Use a pair of pliers and CAREFULLY remove the fuel tubes from the KLR petcock and transfer them to the Raptor petcock. This will keep your reserve range the same.
Tourbus is offline   Reply With Quote
Old 10-19-2014, 05:35 PM   #10
Balootraveler
Balootraveler's Avatar
Oddometer: 355
Eagle mikes manual and never worry, just need to be in the shut off habit.
If I grow up I'll be taller.
Balootraveler is offline   Reply With Quote
Old 10-19-2014, 07:05 PM   #11
Skowinski
Primate
Skowinski's Avatar
Oddometer: 6,078
Originally Posted by juddspaintballs View Post
I prefer the manual petcock. I bought mine directly ..... using the Yamaha part number 5LP-24500-00-00. It's the same one that Eagle Mike sells and it's from a Yamaha Raptor......
This is how it's done. Simple.
"The atoms or elementary particles themselves are not real; they form a world of potentialities or possibilities rather than one of things or facts."
- Werner Heisenburg
Skowinski is offline   Reply With Quote
Old 10-20-2014, 04:07 AM   #12
rarepartbuilder
rarepartbuilder's Avatar
Oddometer: 374
klr petcock modders ... where r u?
im pulling the stock klr petcock apart this farkle season/winter..
Im pretty sure you can throw away the vacuum pull rod / diaphram .. and for 50 cents make a gasket and new backer plate... then just use the remaining stock klr fuel shut off as "manual"..
someone else must have already done this.. ???
RPB
Reaching for far less side stand rocks.... the PISTON MOD
rarepartbuilder is offline   Reply With Quote
Old 10-20-2014, 04:20 AM   #13
griffo1962
griffo1962's Avatar
Oddometer: 1,577
yep, did it years ago. no issues except a couple of times fuel has leaked when I forgotten to turn tap off
griffo1962 is offline   Reply With Quote
Old 10-20-2014, 04:43 AM   #14
rarepartbuilder
Oddometer: 374
thanks for confirming... I'll post up the pictures of the mod this winter and let others decide if this cost saving mod is for them.
RPB
Old 10-20-2014, 10:36 AM   #15
rustynut2
Oddometer: 496
here's your plate
http://www.klr650.net/forums/showthread.php?t=89987
Work harder, millions on welfare depend on you.
12 T800XC, 14 DRZ 400s
rustynut2 is offline   Reply With Quote
Times are GMT -7.   It's 12:40 AM.
