Old 02-26-2012, 01:23 AM   #31
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,143
Originally Posted by ER70S-2 View Post
Another point to check: after readjusting, my pedal hit on the front of the lowering bracket (template graciously provided by NordieBoy), stopping downward motion (no brake); so I removed a bit from it and the pedal to allow clearance.
I left the pedal at the stock height. I liked it out of the way. Same with the shifter.
NordieBoy is offline   Reply With Quote
Old 02-26-2012, 06:29 AM   #32
sagedrifter
Southern Explorer
sagedrifter's Avatar
Oddometer: 1,446
I left my brake lever on the bike and used a die grinder with a barrel bit, took me a couple moments...
My PC lowered pegs came with a longer spring too. I put some BBQ high temp flat black paint on the lever and its been fine for over 10,000 miles.
After a year with the DP pads I'm very happy with them. Very little brake dust, good stopping power and they last. OEM feel and sound without the black dust. I feel it was money well spent, the front pads have out lived the original OEM and still have more to give. I'll be buying DP pads from now on.
sagedrifter is offline   Reply With Quote
Old 03-05-2012, 07:31 PM   #33
basketcase
lifelong reject fixer
basketcase's Avatar
Oddometer: 1,432
RowRoRo-kay. What I did was this...
Using my Dremel tool and a barrel bit (rough sander belt) I took 5/16''s off the bottom of the lever with it still on the bike.
To begin, I removed the right side peg and center stand springs, and then I ground a "recess" on each end of the area and then took out the middle.
When it was all done I still had to go back and take a bit more off the front or leading edge of the section I ground to get the last bit of clearance for the pedal.
After that I removed the master cylinder shackle (did someone call it a "clevis pin") and took 1/4 inch off the master cylinder shank with a cutting wheel. To secure the shank and keep it from jumping around I used a 2-1/2 inch "C" clamp and secured it to the brake lever. Worked like a charm.
Finally, I reassembled it all and adjusted the brake. Deed done.
Thanks to all for the feedback.
PS: My apologies for the poor lighting.
'00 BMW R1100RT, Gone away: 5 previous BMW's, 3 Honda's, 2 Suzuki's
"The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane." - Marcus Aurelius
basketcase is offline   Reply With Quote
Old 05-26-2012, 09:22 PM   #34
ER70S-2
ER70S-2's Avatar
Oddometer: 6,718
Stainless Front Brake Line Caution
Originally Posted by ADV8 View Post
The point, for those who might be going go that route, make sure the braided brake line is 100 % held by the lower fork clamp (stock DR forks)
When I refitted the parts it was noticed that the hose was closer to the rotor but was firm.
On choppy condition roads the line could very slowly work its way down though that fork clamp until the brake line touched the rotor...fwiw
Slips down at the arrow, rubs on the rotor: (saws with the 320mm rotor shown here)
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 screwed with this post 05-26-2012 at 09:28 PM
ER70S-2 is online now   Reply With Quote
Old 06-21-2012, 08:28 AM   #35
Motodeficient
Oddometer: 448
I had to put some electrical tape on the SS line at the area of the clamp to make the diameter of the clamp large enough to hold it. It would be very dangerous to have the brake line moving around, especially with the large rotor. Since I only ride street, and I have a 320mm front rotor, I also re-routed the brake line on the outside of the fork for extra safety. This may or may not be advisable if you ride off road where sticks could grab it.
Motodeficient is offline   Reply With Quote
Old 07-19-2012, 11:15 PM   #36
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,062
Originally Posted by vintagespeed View Post
bleeding the front brake is a real pain in the ass. a good tip i found was to pump up the front pressure and zip tie or velcro the brake lever closed over night, keep the m/c cover loose as well.
great tip for all.
i've heard that one before and used it on my DR.
i did the normal bleed method till things seem good then,
zip tied the lever against the bar overnight. it opens the system so all the left over bubbles rise to top and escape out. i just left the top cap off and put a towel over top so nothing could fall in. the next morning the cap goes back on and the system is rock solid.
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins is online now   Reply With Quote
Old 05-03-2014, 05:08 PM   #37
rockydrxrvr
Multi Meter Meathead
Oddometer: 163
When new pads, and a rotor clean and sand won't work
My 2006 DR developed almost non-stopping ability on the Rear Brake,
So I bought new EBC FA152-R pads, chemically clean rotors, sanded with 800 grit, finished with a cross/X path on the sanding, and still... no amount of foot force would give me 'some' wheel lockup, and stopping power. Old pads had lots of surface left, but glazed, and some pollution.
Ok...so a pint of new DOT 4, pull all the old fluid thru with a simple elevated hose and jar trick, and moderate pressure = moderate lock.
So old fluid, with a possibility of air in the line, ( which watching the clear tube, saw one bubble only).
Bleed and Dot 4 your DR system before you buy new pads, not like dummy here, but OK...those pads did have 11 k on them.
Next step is a 'Braided' line, as I want a bit less foot pressure for the same results.
Also of note, I dropped my pegs with a 1.5'' lowering kit, and may have something to do with the angle of leverage/foot pressure, but my finish work on the lowering, gave me an 'even plain' of petal vs. brake arm.
rockydrxrvr is offline   Reply With Quote
Old 05-30-2014, 10:41 AM   #38
Jenn
praise seitan!
Jenn's Avatar
Oddometer: 865
Anyone have a photo tutorial for how to change rear brakepads on the DR650SE? Thanks!
Jenn is offline   Reply With Quote
Old 06-01-2014, 12:36 PM   #39
TinMan207
Most often a lurker...
TinMan207's Avatar
Oddometer: 1,654
Page 5-34 of the shop manual.
The DR is definitely worth having the shop manual for. Most everything is simple to work on, and seldom requires special tools.
Sent from my AT100 using Tapatalk
When I was young I hoped to be Rich and good looking. At this point, I think that having great stories of many adventures is a much better plan
06 Suzuki DL650 (2 at the moment!) - 00 DR650
TinMan207 is offline   Reply With Quote
Old 06-01-2014, 01:01 PM   #40
Kommando
Kommando's Avatar
Oddometer: 7,389
Make sure that the brake pedal is not contacting the footpeg mount.
Did you check the thickness of the rotor? A rotor that is too thin could cause what you describe. I clean rotors with brake cleaner or acetone. Be sure not to breathe any of the brake cleaner. It can be lethal, even in small exposures.
I run stock rotors and either stock or cheapy pads. With braided stainless hoses and a good bleed, my '03 DR can lock either tire at will on dry pavement. My '13 still has stock rubber hoses and is NOTICEABLY mushier for braking.
Kommando is offline   Reply With Quote
Old 06-08-2014, 07:35 AM   #41
nateberkopec
nateberkopec's Avatar
Oddometer: 146
I just installed the SW-Motech centerstand yesterday, but ended up with a perplexing issue - the brake lever now hits the top of the centerstand mount! I only have, maybe, 1/2" of play in the lever before it hits the centerstand mounting plate.
Is this normal, or is my brake lever bent (new bike to me, only done a few hundred miles on it)? How can I fix this? I was planning on playing with the adjustment screw, but the brake pedal is pretty much already level with the peg, so I think I may end up with the same problem as the above poster.
I don't have access to a grinder - living in a tiny NYC apt means I only have access to my simple toolbox.
nateberkopec is offline   Reply With Quote
Old 06-08-2014, 10:21 AM   #42
ER70S-2
ER70S-2's Avatar
Oddometer: 6,718
If you don't know anyone with power tools (angle grinder, for instance), it's time to add a Dremel Kit to your simple tool collection. Don't force it to cut (pushing down hard), it's a small tool, let the bit do the work. Never run a grinder without safety glasses.
If you're young, tough and patient, you can use a file.
2013 WR250R
Old 06-08-2014, 10:50 AM   #43
Kommando
Kommando's Avatar
Oddometer: 7,389
Is the clevis on the rear of the pedal adjusted correctly?
Old 06-08-2014, 01:46 PM   #44
shu
Oddometer: 1,028
No, it's not normal with stock footpegs. I've mounted my SWMotech centerstand on 2 DRs now and have not had clearance issues on either. Have your footpegs been lowered?
.................shu
shu is online now   Reply With Quote
Old 06-08-2014, 05:18 PM   #45
nateberkopec
Oddometer: 146
Definitely not. I'll check the rear brake adjustment, see what I can do. I'll post a pic if I can't figure it out.
Times are GMT -7.   It's 07:07 PM.
