Old 06-11-2014, 11:51 AM   #46
nateberkopec
nateberkopec's Avatar
Oddometer: 146
Fixed it! Definitely was a poorly adjusted clevis. When I really sat down and measured it, the rear brake was resting nearly an inch below the peg!
Which also explains why I had such poor rear brake power... Time to go riding now though!
nateberkopec is offline   Reply With Quote
Old 07-20-2014, 07:08 PM   #47
ER70S-2
ER70S-2's Avatar
Oddometer: 6,709
Cleaning Your Caliper Pins
Our calipers move slightly as the pads wear, sliding on two pins. Since the calipers live in a harsh environment, they get dirty. It's your job to clean and grease them and should be done regularly, like each time you replace a tire.
The rear caliper will slide off to the right, as soon as the rotor is clear. That didn't seem to work for me the last time I tried it with the front caliper, I had to remove the pads.
Ewwwww Be sure to replace this rubber seal when you're done.
Use Q-Tips or paper towels to clean out the sockets.
Rear caliper pins cleaned up pritty.
This seal, on both calipers, runs all the way thru the alum. I thought it was just a cap and should pull right off.
This is a pic of one of the pins. The flats are there to allow grease to pass the pin when reassembled. All four pins (2 front, 2 rear), slide into dead end sockets; don't over grease. I think there is a special caliper pin grease. The bronze colored piece is the caliper adapter for a 320mm rotor (you probably don't have one).
This is when I learned two things:
1. The rear caliper will slide off with the pads in place, and be hanging on the side of the swing arm when you stand the bike back up.
2. That rubber seal mentioned above will get lost.
This is a heat insulator, it keeps the brake fluid from boiling when using the rear brake for trail braking, etc.
Don't bend the tabs on the stainless shim, done properly, they'll snap on without loosing their shape. Note: shown on the wrong side of the pad for the top photo.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 screwed with this post 09-29-2014 at 02:05 PM
ER70S-2 is online now   Reply With Quote
Old 07-21-2014, 08:14 AM   #48
Krusty ... OP
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,600
Nice write-up ...
"...choosing a DR indicates an affinity for peace, harmony and enlightenment. Serenity lies in accepting it as it is, changing what you want, and the wisdom of knowing it ain't orange." -psmcd
Krusty ... is offline   Reply With Quote
Old 07-21-2014, 09:04 AM   #49
ER70S-2
ER70S-2's Avatar
Oddometer: 6,709
Hiya Krusty
2013 WR250R
Old 10-21-2014, 04:56 PM   #50
Lobster
Oddometer: 392
Looking for some brake advice. Just bought a 2001. Front brake feels "wooden". Lever doesn't feel spongy...just feels like no matter how hard you pull the lever the brakes don't squeeze any harder.
Ideas?
Stuck caliper?
Pads glazed?
Old fluid?
Lobster is offline   Reply With Quote
Old 10-21-2014, 06:32 PM   #51
Krusty ... OP
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,600
Ideas?
Stuck caliper?
Pads glazed?
Old fluid?
I could also be time for a new brake line. The old rubber can flex under pressure. Hey, you were looking for an excuse to upgrade to a braided hose anyway, right?
Times are GMT -7.   It's 04:52 PM.
