Old 11-28-2010, 09:06 AM   #16
Krusty ... OP
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,600
Bump
SUZUKI DR650SE INFORMATION INDEX
"...choosing a DR indicates an affinity for peace, harmony and enlightenment. Serenity lies in accepting it as it is, changing what you want, and the wisdom of knowing it ain't orange." -psmcd
Krusty ... is offline   Reply With Quote
Old 11-28-2010, 01:34 PM   #17
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,403
Originally Posted by justscoutin
got a set of michelin T63's here now. put the rear one on last night and tried it out today. 120 miles. worked really well on everything I threw at it. way more stable in the loose gravel roads than the mt21 that was on the rear. can't wait to get the front swapped and try it out.
bben reading great reports on those t63 as far as mileage for the price you pay. guys are saying 4-6K on them. after my tck-80/mefo combo wears out that is my next tire,as my combo is now 2x the price of the t63, yet it's not gonna be 2x the mileage.
http://www.motorcycle-superstore.com...=45&zmap=19852
fyi,
stay away from the heidenau k60 rear in the 130-17" size. reports are very poor on mileage in that size for the $110 price whereas the 140-17" is getting huge mileage. very odd.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 12-27-2010, 07:57 PM   #18
Kranked
Zen Master
Kranked's Avatar
Oddometer: 37
Kenda Trackmaster II - K-760
I started with the stock trailwings. Tried to get Michelin T-63s but they were apparently back ordered across all of Canada at the time. I went with available and even cheaper - Kenda Trackmaster II K-760. Listed as a 20/80 road/dirt biased tire. I know I'll get at least 5000 kms out of the rear and much more out of the front since I only ride the road/highway to get to long bits of dirt. There's 2600 kms on them now, the front looks pristine ~5-10% wear and the rear has about 40-45% wear.
With these Kendas I do ride slower in town, exercise caution in the rain, and watch that I don't corner too hard on the tarmac. No problems on the highway. I love 'em to death off-road.
Edit: They start to hum at 55 kph.
2009 Suzuki DR650 - Black
*Barkbusters w/ Storm handguards *SW-Motech bash plate *SW-Motech rear rack *Procycle Saddlemen Gel Foam Seat *Powermadd 2" handlebar risers
Kranked screwed with this post 12-30-2010 at 02:52 PM
Kranked is offline   Reply With Quote
Old 12-28-2010, 03:38 AM   #19
rivercreep
Oddometer: 3,243
F.W.I.W. they got me through the winter last year on my DR without studs. Other than that (since I'm 90% street rider these days) they weren't for me.
My current tires are IRC GP1 front and a Shinko 244 rear. The front and rear are pretty well matched for wear at about 4,000 miles. (front has tread left but it cups bad) I like the combo because the shinko will slip out first when pushed hard and I like the warning.
Another good IRC tire is the 110 for the rear as they go around 5,000 miles and don't slip out as easy as the shinko 244.
Put the 110 on the front however and it will howl through turns and try to slip out from under you.
Kezza....what kind of mileage on those siracs are you getting?
rivercreep is offline   Reply With Quote
Old 01-10-2011, 02:12 PM   #20
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,403
17" vrs 18" rear tire which is better????
great read for anyone considering the dr350 rear wheel mod and what you are actually getting yourself into. my commments/opinions start on page 2.
http://www.advrider.com/forums/showthread.php?t=647911
Alaska
Old 01-14-2011, 11:46 AM   #21
trailrider383
867-5309
trailrider383's Avatar
Oddometer: 3,393
Get Your DR650 Rolling Right
Here are the part numbers for bearings, seals, etc for DR650 1996 and newer. I got the bearings from a bearing supplier. About the same cost as OEM but with seals on both sides so they last longer than the OEM with only one side sealed. And for those of you with 2007 and older versions I added the rear axle lock nut part number so you don't have to mess with the cotter pin. See my other post for part numbers for the rear cush drive bearing and seal.
Front wheel bearings: SKF 6003 2RSJEM
Front wheel seal: 09284-23001
Rear wheel bearings: SKF 6204 2RSJEM
Rear wheel seal brake side: 09283-26019
Lock nut from 2008 and newer: 08319-2118a
DO WHAT YOU LIKE - LIKE WHAT YOU DO
Explain to me again why enjoying life when I retire is more important than enjoying life now?
trailrider383 is offline   Reply With Quote
Old 01-14-2011, 11:51 AM   #22
trailrider383
867-5309
Oddometer: 3,393
Check Your Rubbers
On my 07 DR650 with 12,300 miles I noticed some slop in the cush drive hub. If you grab the top of the sprocket with one hand and push towards the spokes and the bottom with the other hand and pull out away from the spokes and get a fair amount of movement it may be time to replace the six drive cushions. I took mine apart and looked at the seal in the cush drive hub and you could see that the double lips were wore down almost smooth. You could put thewheel spacer in and there was no drag from the seal. Which means it wasn't sealing like it should. The bearing in the hub is right behind that seal and doesn't have a seal of it's own on that side of the bearing. So any dirt getting by that outside seal is going right into the ball bearings. The bearing felt fine, but I bought a new one that is sealed on both sides anyway. So if you get a lot of play in the cushions it is putting a lot of extra force on that bearing in the hub and then it also wears out the seal. It doesn't really seem possible to me that there would be play if the bearing is still good, but there is. If you think about it when you tighten the axle it all becomes a solid piece. The left side head of the axle tightens up against the swingarm, spacer, inner race of cush hub bearing, spacer between cush hub bearing and left wheel bearing, spacer in wheel hub and right wheel bearing, spacer, swingarm and axle nut.
Here are a couple of pictures of an old cushion compared to a new cushion. New is on the right. The Suzuki part numbers are 09283-34003 for the seal, 64651-32E00 for the cushions x 6, and the double sealed bearing I got from a bearing house is an SKF 6205 2RSJEM made in USA.
Old 01-19-2011, 10:00 PM   #23
Midpack
Midpack's Avatar
Oddometer: 133
more on tires
I've previously run Kenda 760s which are inexpensive and do great here on the sandy southern NM terrain. Drawbacks are pretty slick on street especially is damp and super stiff sidewalls hindering tire repair out in the field.
Considering this when replacing rubber on my new DR in 08 I went with MT21s working great in the sand and dirt while easily levered on and off in the boonies. An added benefit is surprising sport tourers on the twisties. Mileage about 3000 on rear and 4000 front. I did a 970 mile 3 day ride up to the Mora / Toas area with some friend from El Paso and Las Cruces so I put the origina Trail Wings on because of the extensive Hwy travel. About 90 miles of it was rocky dirt forest roads with quit a few long river rock climbs and was surprised how well they worked while being quite and smooth riding. Already picked up a spare front and hopefully rear as to be able to switch back and forth better.
'' Progress isn't accomplished by early risers, but by lazy people looking for an easier way to do things"by ?
Midpack screwed with this post 02-14-2012 at 03:35 AM
Midpack is offline   Reply With Quote
Old 02-08-2011, 06:27 AM   #24
bumblebee1
All bikes are dirt bikes
bumblebee1's Avatar
Oddometer: 1,431
I have experimented with a gs400 bike first with DS tires.
I tried the Shinko 244 but found them loud, slippery and swaying on asphalt, even the dry stuff.
Since there is about 60 miles of tarmac to travel before the trails, street wear and performance is a strong consideration.
I didn't want an 80/20 tire that would be useless on a wet dirt road.
I fitted a Trailwing 42 4.10-18 on the rear and loved it. The heavier bike just dug in and grabbed with the narrow tire. Allas, the tire was discontinued in that size.
The next try was front and rear Cheng Chin c186 trials tires. 2.75f and 3.50r. A great combo but the rear wore out fast. Maybe got 4500km on a rear. The street ride was great and the grip on gravel and dirt was surprizing. The small knobs are spaced close enough together to give a smooth ride on asphalt. The sipes(small cuts on knob) help to grip in the rain (I was told).
For the DR, I tried the K270 front and rear but hated then on the road. I went to a trials c186 front and a Trailwing TW302 rear and am pleased with the result. The rear grips well on asphalt, even when leaning hard in curves. It has a srong sidewall for riding two up without flex in the curves and is quiet and smooth enough for long asphalt rides. Combined with the C186 Cheng shin front, the bike handles well in all situations. When riding on wet or loose gravel, the front stays planted and the rear can slide out like a flat track bike, when wanted. It's a blast.
On wear, the Trailwing doesn't last as long as I would have expected for a dual compound tire. I might get 6000km out of it.
Now for the C186 front, it's a real nice all around tire. The only issue I have had with it was the fast cupping wear one day when doing some hard braking over and over again on asphalt.
This led to a discovery as to the reason for cupping.
Most of you probably know this but the cupping is caused by hard braking. d'uh.
So I began braking with my rear brake only when on asphalt. Now my front brake is always covered and I prepare ahead of time to do this. On dirt or in a fast stop, I have both brakes going but otherwise, I'm back to rear only.
I put on a new trials tire last summer and rode about 4000km so far on it. I swear it has hardly any wear. As soon as I notice some cupping, I will reverse it on the rim. This should help it. I will also re-groove the sipes with a blade when they disapear.
So that is my experience with tires.
And what are you planning to do with your one and only life?
bumblebee1 is offline   Reply With Quote
Old 02-08-2011, 08:57 AM   #25
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,403
i've tried alot of different DS tires.
mich T63 are my next pair.
they are getting great reviews for the price.
Alaska
Old 04-04-2011, 10:13 PM   #26
Xplorr
hoi polloi
Xplorr's Avatar
Oddometer: 320
18" rear wheel conversion
I somehow got interested in putting an 18" on my relatively new-to-me DR650; and then as I looked into it, interest became obsession. I was confounded by how easy some made it seem and how little specific info there was on something that was supposed to be so easy. So here is my saga, er.. write up: I hope it helps someone. I have no great understanding of motorcycles, and I make no claims of expertise what so ever, at all. I consulted a friend of mine who owns a shop, and knows WAY more than me, several times to make sure I wasn't doing something unsafe to the bike/wheel. So fairwarning, if you know a lot or bore easily, move on .
I was lead to believe that a dr350 wheel was a 'plug and play' solution to an 18" rear, so I set out to track down a such a wheel. Turns out, this is only partially true. The DR250's and DR350's both had models with hubs compatable to the DR650, but a person really wants the CUSH DRIVE. This is feature is found on 1990-95 DR250SE and 1990-96 DR350SE models (except the 'T' model). The hub part # is 64111-15D00. The non 'SE' model does not have a cush drive, and the rim and spoke set is different (trust me on this). A useful tool I found in my travels was the Babbit's parts site: you can find a part number, and then check what other bikes use that same part number and therefor crosscheck what bikes/years share parts. FWIW, ThumperTalk has the absolute lowest priced Suzuki OEM parts I could find on the web.
So I found a wheel on E-bay, and ordered it up. The spokes had a lot of what I assume was salt corrosion, so I figured I would replace the spokes. On the advice of people smarter than myself, I took a few steps at this point, before reaching for the bolt cutters. First, measure the off-set of the hub/rim on each side to make sure it gets back to the same spec. Second, make note of the [first] four spokes and their positions in the hub/rim, so when you go to re-lace the rim, its that much easier. I used colored zip ties. Third, save a few of each size spokes, for backup-- Suzuki only sells spoke sets (36).
Once I got my wheel, I decided that it needed some cleaning up. After the aforementioned considerations, and spoke removal, I took the hub and rim to friend's shop with a bead blaster, and, well.. bead blasted em. Then I buffed them with a pad on my die grinder. Cleaned em up quite nice it think:
PARTS SIDENOTE: before I bought the 18" wheel, I looked up part numbers for both the 250/350 se wheel and the stock 650se wheel and found that most of the associated parts are interchangable; with the following exceptions: rim (obviously), hub, brake disc, spoke set, and cush bumpers. the other part numbers are the same. So bearings, spacers, the axle, etc. for the 650 work for the 250/350se wheel. I wanted to keep my original wheel mostly intact, in case this whole experiment goes horribly wrong, so for my new wheel I ordered a new spoke set, new sealed wheel bearings, and cush bumpers. Turns out, the cush bumpers on my stock wheel fit better than the ones I ordered for the new wheel. The sealed Moose wheel bearings are part# A25-1256, and are compatible with the DR250se, 350se, 650se.
To summarize, if you found the wheel, didn't need new spokes, and wanted to use your 650 bearings and cush pads, you are go to go, and now about here:
So now we get to the brake disc issue. The disc from the 250/350 wheel is smaller and has different fasteners. 250 Hub:
The mounting holes from each disc match up, but the 650 disc has a recess in both the disc and the hub:
The reason why this is a problem, is that the 650 screws need a recess because of this:
My solution was to shim with washers that fit both the disc recess and fastener shoulder, of these , the 2 serrated lock washers seemed the perfect solution:
So now we look like this:
And this:
And this:
OK, so now the wheel is good to go. The next thing is the tire. I really wanted to try a Mefo super explorer which is a 140/80-18 tire. People are talking about getting 6-9K miles on ktm 990's and the like, so I figure I should be able to get crazy milage on a DR. Also, I really like the tread; very similar to the heidenau K60, which I've tried but crappy mileage.
ANyWho, here's the wrap-up kids if you are still awake: The new wheel/tire raised the rear end 1" and is about 3 lbs heavier than the 17" with a mefo explorer. It looks badass, if that's what you are into. It also raised the gearing. (I had wanted to lower my gearing, even when the stock wheel was on the bike.) I put a 14 tooth front sprocket on to (a) get some more room between the tire and the swing arm, (b) to lower the gearing. Lowering the gearing to a 14t only maybe got me back to stock, now I have to go lower. Also, I need to add some links to my chain if I want to go with a bigger sprocket in the back. Here's some pics of the bike with the 18":
I'll have to put some mileage on this thing to see if the trouble was worth it. Another issue to consider, the 650 rim is wider than the 18", so a 140/80 is a big tire, and a PITA to spoon on and mess with.
Happy trails, Cheers, matt
Xplorr screwed with this post 04-05-2011 at 01:42 PM
Xplorr is offline   Reply With Quote
Old 04-05-2011, 02:32 AM   #27
BergDonk
BergDonk's Avatar
Oddometer: 3,930
18" Rim
I got a 2.5 x 18" from John Titman Racing here in Oz. He also supplied a set of heavy gauge stainless spokes cut to size, and the rim drilled accordingly too. Bit $xxcy, but simple enough to lace the stock hub, and much stronger. My initial reasoning for doing this was primarily that the big trip to the Simmo and Kimberly happening soon would be accompanying bikes with 18" back wheels only and this would economise on spares, and 18s are a bit easier to come by in outback Oz if required. The raising of the rear 1/2" was good too for ground clearance.
I fitted and balanced a Mitas 130/18 E07 and got 7,000 kms before I scrapped it after a cut carcass and puncture. Maybe 2,000 kms left. It was mated with a balanced MT21 front. I've swapped them for another E07 and 606 front.
The E07 seems to get traction OK most antwhere, but is not real good for side grip in slop. Good compromise though, like the DR. The MT21 just worked too, and would fit one again. Its good that the MT21s are unidirectional too, as they scallop up a bit and need to be turned around. the 606 is directional. we shall see...
Balancing is good, and recommended.
Steve
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 04-05-2011, 04:56 AM   #28
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,973
another 18 inch conversion here.
dr250 wheel all that was required was new cushions & used the dr250 bolts for the dr650 brake rotor.
brake rotor removal tip: use a torch & impact driver to pull rotor bolts.
they are saturated in loctite.
plugeye is offline   Reply With Quote
Old 04-10-2011, 10:19 PM   #29
ER70S-2
ER70S-2's Avatar
Oddometer: 7,277
Tire Tubes
Thanks to Lex:
http://www.advrider.com/forums/showp...ostcount=47277
2004 DR650: 62,605 miles
2013 WR250R
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 05-02-2011, 12:58 PM   #30
Kranked
Zen Master
Kranked's Avatar
Oddometer: 37
Laugh Heads up Canadians... cheap tires
45% off of tires at G. Bourque in New Brunswick. http://www.gbourque.com/
I purchased a rear Kenda Trakmaster for $46.00 from G. Bourque - compare that to $85, the "discounted price" from my local Suzuki/Honda dealer.
'Slow' shipping since they order from the warehouse in Quebec, have to send it to New Brunswick, then ship it to the destination, in my case Ontario. Only took 11 days to receive the box of stuff and tire.
Awesome prices at G. Bourque, I think I'll try a set of Michelin T-63, next, for only $114.00
Kranked screwed with this post 05-02-2011 at 01:15 PM
Times are GMT -7.   It's 11:38 AM.
