Old 05-02-2011, 02:12 PM   #31
Eggsontoast
Eggsontoast's Avatar
Oddometer: 62
It's always a compromise
Some interesting write ups.
I bought myself the DR just over a year ago and it was fitted with a new set of Michelin Anakees which were very good on the road in all conditions. The front has lasted me 11,000 miles and the rear lasted roughly half of that, although both rear sets received punctures so would have lasted abit longer, judging by the amount of tread left.
Changed those over to some Pirelli MT21's as I fancied something much more off road orientated. Other than they wear out rather fast I'm pleased and at the same time amazed at how much grip you can really get out of them on the road, very good off-road but as is to be expected the MPG drops off considerably which cought me out but that's another story...
One thing I would say is try and get as close to the standard speed index as possible, you may never hit a ton but it's good to know that whilst the bike can hit that speed, you've got a tire which can deal with it all the same; as it turns out the 120 does whereas the 130 brickwalls at 80-85 if I remember correctly.
I'd like to try the T63's but realistically I will change back to the Anakees and either buy or build myself a set of wheels for that quick change over from road to offroad: still debating on which way to go...
Regarding the wheel bearings, if your careful you can actually pry the seal off and pack them with some lithium grease, not too much mind or they'll overheat.
Pat
La Moto, c' est une aventure qui mene jusqu' au bout du monde...
Eggsontoast is offline   Reply With Quote
Old 05-02-2011, 08:24 PM   #32
EvanADV
Big Bearded Boy
EvanADV's Avatar
Oddometer: 1,125
Would you guys say an 18" rear is a good way to raise the rear for a heavy/tall rider?
Current: '07 B1250.
Former Steeds: '99 DR650, '02 DR650, '09 DL650
First Trip on 2 Wheels. 10,000 miles. 21 years old.
EvanADV is offline   Reply With Quote
Old 05-02-2011, 08:50 PM   #33
shu
Oddometer: 758
Don't know.... but I have these questions:
-Wouldn't that raise the bike barely a half inch?
- Would that make much difference?
.........shu
shu is offline   Reply With Quote
Old 05-02-2011, 11:34 PM   #34
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 6,844
.........shu
Same as dropping the forks half an inch.
3mm makes a difference you can feel.
NordieBoy is offline   Reply With Quote
Old 05-03-2011, 01:59 AM   #35
BergDonk
BergDonk's Avatar
Oddometer: 1,707
Like shu says, 1/2" only, but helped me. I also fitted a longer shock and forks and taller seat and lower footpegs. I was after ground clearance and a size of tyre that is easier to find outback here, and one that the XRs and KTMs I'm travelling with will have when we head out next month. It also changes the gearing, roughly equivalent to a 16t cs from the stock 15, or an extra 3 teeth up back.
Steve
shed time IS quality time
Check my DR650 story:
BergDonks DR650 Build
BergDonk is offline   Reply With Quote
Old 05-03-2011, 08:50 AM   #36
EvanADV
Big Bearded Boy
EvanADV's Avatar
Oddometer: 1,125
.........shu
I realize it's only 1" more than stock rim diameter, so half of that comes to 1/2", but I wasn't sure if the tires made a difference as well or if they were the same height as 17" options.
If an 18" rear wheel really raises it 1", that could make a big difference for me. Right now I feel like I am sliding backward at freeway speeds (wind is a factor, but the bike is squatting a good bit with me on it). My hands start to get tired after 10 or 15 miles because I am holding myself up toward the front of the bike rather than just sitting in place.
I'm gonna install raising links and a stiff rear spring first and see what happens from there.
Current: '07 B1250.
Old 05-03-2011, 12:16 PM   #37
Xplorr
hoi polloi
Xplorr's Avatar
Oddometer: 320
Hi c2c4c,
I measured to the top of the rear rack, with a mefo explorer 17" and the 18" which has a 140/80-18, the difference was 1" exactly.
cheers, matt
Xplorr is offline   Reply With Quote
Old 05-03-2011, 01:34 PM   #38
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 6,844
Just the spring will keep the rear up higher.
Old 05-03-2011, 02:55 PM   #39
Krusty ... OP
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,487
Send a message via Skype™ to Krusty ...
From what I've read, 18 inch tires are much easier to find in many countries while 17 inchers are rare. Might make a big difference on that tour of South America...
SUZUKI DR650SE INFORMATION INDEX
Krusty ... is offline   Reply With Quote
Old 05-03-2011, 03:12 PM   #40
EvanADV
Big Bearded Boy
EvanADV's Avatar
Oddometer: 1,125
Hmm, good point.
Any idea if 21 inchers are easy to find?
Current: '07 B1250.
Old 05-03-2011, 03:19 PM   #41
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 6,844
Hmm, good point.
Yes
Old 05-04-2011, 10:55 AM   #42
EvanADV
Big Bearded Boy
EvanADV's Avatar
Oddometer: 1,125
Yes
Glad I could give you a good laugh
Never been tire shopping outside the 48.
Current: '07 B1250.
Old 05-27-2011, 06:45 PM   #43
eakins
Butler Maps
eakins's Avatar
Oddometer: 14,577
rear wheel bearing/seal dimensions
Wheel bearings - 2 x 6204 - 20x47x14
LHS Seal - 1 x 26x47x7
Cush Hub - 1 x 6205 - 25x52x15
Cush Seal - 1 x 35x52x7
Seal widths is not critical, so alternates may be available.
If you want to beef up the cush hub, which I did after a couple of failures, a double row 3205 fits, maybe just gotta sort the seal. There is a description in the latter pages of my build thread, starting here:
http://www.advrider.com/forums/showt...646076&page=10
Steve (Bergdonk)
Quality Bearings:
(All Balls are Chinese bearings)
-Front wheel bearings: SKF 6003-2RSJ(EM) - Bought from Napa and labeled 2RSJ, other places label with EM at the end?
2 - 17 x 35 x 10
-Front wheel seal:
2 - 23x35x7 (09284-23001 – Suzuki #)
-Rear wheel bearings: SKF 6204-2RSJEM
2 - 20x47x14
-Rear wheel seal (brake side):
1 - 26x47x7 (09283-26019 – Suzuki #)
-Cush Hub bearing: SKF 6205-2RSJEM
1 - 25x52x15
-Cush Seal:
1 - 35x52x7 (need Suzuki #)
Two 6003 2RD/2RS/2RSJEM (2RSJEM is the best spec)
Two 6204 2RD/2RS/2RSJEM
One 6205 2RD/2RS/2RSJEM
Originally Posted by trailrider383 View Post
Here are the part numbers for bearings, seals, etc for DR650 1996 and newer. I got the bearings from a bearing supplier. About the same cost as OEM but with seals on both sides so they last longer than the OEM with only one side sealed. And for those of you with 2007 and older versions I added the rear axle lock nut part number so you don't have to mess with the cotter pin. See my other post for part numbers for the rear cush drive bearing and seal.
Front wheel bearings: SKF 6003 2RSJEM
Front wheel seal: 09284-23001
Rear wheel bearings: SKF 6204 2RSJEM
Rear wheel seal brake side: 09283-26019
Lock nut from 2008 and newer: 08319-2118a
Ozarks
, Nor Cal , COBDR shipping, AZBDR scouting
Facebook:
http://www.facebook.com/butlermaps
eakins screwed with this post 03-02-2013 at 10:22 PM
Old 07-04-2011, 02:17 PM   #44
(none)
poser
(none)'s Avatar
Oddometer: 2,500
Can anyone clarify something: Will a DR350 NON-CUSH rear wheel directly replace my stock 17" wheel? I have a cush dr350 18" rear wheel in the garage right now, but i'm thinking of trading it for a non-cush just so that i can leave a sprocket on the wheel and not have to swap the cush drives and make mounting easier. It'd only be used when i go off-road, so i'm not worried about losing the cush drive as much as i am about the fitment.
Current:
2001 R1150GS
1981 CB650 Custom
2011 Golf TDI - New tow rig
(none) is offline   Reply With Quote
Old 08-23-2011, 09:05 AM   #45
hmmwv15
young grasshopper
Oddometer: 145
IRC tires?
Anyone tried the IRC GP-110 tires? These look like a good fit for my kind of riding, but if anyone has any gripes about them I'm all ears. I'm on pavement more than dirt, but I want good grip in the dirt. Currently running the d606's that came on it. No real complaints about them, but I could use a more streetable tire. If the dirt ride is too much of a trade off I might stick with the 606's.
hmmwv15 is offline   Reply With Quote
Times are GMT -7.   It's 10:39 PM.
