Old 08-16-2012, 07:23 PM   #106
Pr0xy
Shreddin' the gnar
Pr0xy's Avatar
Oddometer: 341
What about the Heidenau K60 Scout? Seems to also be roughly a 50/50 tire, though a little more spendy.
At least compared to the Kenda Big Block, the K60 looks like it would have more side-side traction off road.
'03 DR 650 SE
'06 KTM 250 XCW - SOLD
'88 KDX 200 - Restoring
Rides :: Albuquerque to Vegas 2011 | Colorado 2009 | SLAP 2009
Pr0xy is offline   Reply With Quote
Old 08-17-2012, 01:39 AM   #107
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,208
the 130-17" rear was not getting the best mileage for the $ paid, but it might be better now with the rubber redo. i ran a mefo explorer rear and got awesome tire life but they are now $150 a tire (was $100 back then) so the price vrs life is questionable. another tire on the horizon is the mitas E-07 rear which has been reported to get the best mileage out of everyone and there might be US distribution soon...if ya can believe that
http://www.advrider.com/forums/showthread.php?t=706242
here is a new E-07
and how they'll wear past 10K miles. the tire has a center bar at the end of life so it can be pushed pass where other tires would be wearing to the inner tire.
Alaska
AZ map COBDR AZBDR IDBDR South East map
Butler Maps website:
http://www.butlermaps.com
eakins is online now   Reply With Quote
Old 08-17-2012, 01:50 AM   #108
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,208
my latest mullet (or emu as some call it):
IRC-TR8 front
http://www.motorcycle-superstore.com...ront-Tire.aspx
works as well as a tck-80 for less $. well built japanese tire.
Shinko 700 rear (5.10 - 17")
http://www.motorcycle-superstore.com...Rear-Tire.aspx
went with this after using a mefo explorer. almost 1/3 of the price and it works very well on paved and decent off-road. i can spin it easier than the mefo but it still hooks up when i need it. after using the mefo rear, i'm still searching for the ideal longer mileage rear tire at a reasonable price. i'd pay $100 for something better but $150 gets nuts. hoping mitas can come in at $100 as they have been much cheaper in other places where heidenau K60 and mefo explorers are also sold, Australia for instance. in OZ the E-07 is most everyone's go to rear tire. very happy with the IRC front and i'll buy another when needed.
shinko 700 rear on my DR
Alaska
Old 08-17-2012, 07:42 AM   #109
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,785
Interesting. The Shinko 700's tread pattern is very similar to the o.e. Dunlop D607 rear tire that was on my '99 DR350SE. I always thought that tire was pretty good, off road, in the dry and on gravel.
Just out of curiosity, have you tried the Shinko 700 front? If so, why do you like the TR8 better?
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 08-17-2012, 07:58 AM   #110
sagedrifter
Southern Explorer
sagedrifter's Avatar
Oddometer: 1,413
The Shinko 700 is a good all around tire. I like them when I'm staying local. When touring I keep the 700 on the front and put a longer wearing 705 on the rear. There actually is not much difference between the two rears. The 700 does better on loose stuff, but I get around 2K more out of a 705. So, I prefer that in long trips.
Sent from my GT-S5690L using Tapatalk 2
sagedrifter is offline   Reply With Quote
Old 09-08-2012, 02:34 PM   #111
Heavy
Heavy's Avatar
Oddometer: 120
Shinko 700 - seating bead
Hey All,
I bought a set of 700's for my DR and I'm having trouble with getting the front bead to seat. The rear seated fine so my method was okay, I guess.
I've broken it down a couple of times and relubed it. Right now I've run it up to 45 psi and part of it still won't seat.
This is my first experience with tube type tires. I got a 3.00 - 21 front, 5.10 - 17 rear and new tubes for each end.
Any suggestions? Any tricks?
There is never enough time or money to do it right the first time.
2008 DR650, 2006 V-Strom 1000, 2014 CB500X
Heavy is offline   Reply With Quote
Old 09-08-2012, 02:59 PM   #112
sandwash
sandwash's Avatar
Oddometer: 1,333
Take the vavle stem out and take to tire shop and fill it up till it seats.
97dr650
sandwash is offline   Reply With Quote
Old 09-09-2012, 04:38 AM   #113
greer
Oddometer: 3,727
We pump em way up sometimes to seat the bead, 60 psi or so on a regular basis. Be sure to lube well and make sure the rim is clean.
Sarah
'08 DR650
greer is offline   Reply With Quote
Old 09-09-2012, 06:46 AM   #114
Heavy
Heavy's Avatar
Oddometer: 120
60 psi?
Old 09-09-2012, 07:57 AM   #115
greer
Oddometer: 3,727
Yep. We're from Ky. Here, hold my beer and watch this.
Sarah
'08 DR650
Old 09-09-2012, 09:28 AM   #116
sagedrifter
Southern Explorer
Oddometer: 1,413
Deflate all the way, loosen up the bead on both sides, spray some windex etc on the tire and air it up with a good compressor with a tank. Mine usually sets at 40 psi or so. I've gone to 60 psi plus on the rear tires before. Keep airing up till the tire seats or goes boom.
Old 09-09-2012, 01:15 PM   #117
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,208
Originally Posted by Heavy View Post
60 psi?
i would not worry about 60psi.
i use ruglyde from napa.
another trick is to lube, pump up the tire and hit the section with a rubber mallet. that moves the tire out too.
Alaska
Old 09-09-2012, 02:04 PM   #118
Heavy
Heavy's Avatar
Oddometer: 120
Okay. It worked.
My gauge only goes to 60 psi so I don't know what the final pressure was.
That, and beating it with a rubber mallet did the trick.
Thanks for the suggestions. Guess I just had to man up and put some air in it.
Old 09-09-2012, 02:06 PM   #119
Heavy
Heavy's Avatar
Oddometer: 120
Sarah
So you stop short of the starter fluid and a match?
http://www.youtube.com/watch?v=7hJFNuNoVfg
Old 09-10-2012, 07:56 AM   #120
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,785
Sarah
Times are GMT -7.   It's 09:25 PM.
