11-07-2010, 05:33 AM
#1 |
Beard Bros Racing
Oddometer: 3,373
gas tank vacuum
i'm wondering if i have a blocked vent tube somewhere...
when i fill up with gas while i'm opening the gas tank i can hear what seems like a very good vacuum being released...i don't seem to remember this behavior before. my question is; am i suffering from a blocked vent tube or other form of blocked venting somewhere? can other f8 owners (us) chime in and let me know if i'm going crazy (ok, we already know that answer)? thanks. |
11-07-2010, 06:21 AM
#2 |
Oddometer: 408
If you are hearing a vacuum sucking sound when you open be warned you are not venting the fuel tank. Here in California we have these nifty little charcole filters, I dont understand them completely but believe they are suppose to eliminate teh fuel vapors when you park the bike in the garage.
Anyway last summer I was riding and it was extemely hot, we were climbing up out of the Kings River Canyon, about 3000 feet. As I was climbing up the bike stutterd and stopped running. I stopped and restarted no problem and then about 1/4 mile later, same thing. I opened the fuel tank to ensure that there was fuel still on board, I was not out of gas but did hear that sucking sound. This repeated itself once more at which I opened the fuel filler cap, wedged some paper under and taped the cap down. this let the tank vent I we climbed and no more stalling. The next morning, we camped that night up fairly high, +/- 7000 feet, I closed the fuel tank and went home, I did not want to break down on a trail miles from home, so I slabbed it home, no problem. When i got home I inspected the fuel vent line that travels aft of the fuel tank and ties into the charcol canister. I did not see anything but I did relocat the vent line in an attempt to ensure that it would not be blocked when I carry a load on the back of the bike. I guess what I am saying is be careful if you pinch that vent line you will can create a vacuum in the fuel tank, and eventually the fuel pump will not be able to overcome this vacuum. Hope this helps, sorry so wordy...
"We do not quit playing because we grow old, we grow old because we quit playing." Oliver Wendell Holmes |
11-07-2010, 06:39 AM
#3 |
Oddometer: 206
Mine has a little suction when I open it and I have never had a problem. There is an older post on this somewhere and most people had some suction If I remember correctly.
11-08-2010, 04:47 AM
#4 |
Oddometer: 3,438
Not sure which bike you have, but the charcoal canister on the F880GS/F650GS twins can cause this issue.
There is a recall active on it. If you have one of the twins you may have a plugged canister. If you have a different bike it still could be same/similar problem Search for "charcoal canister" there was a lot of chatter on this about 6 months ago but it has died down now since the recall and etc... |
11-08-2010, 05:18 AM
#5 |
Oddometer: 2,786
As stated above..... there is a recall on the Carbon canister. That said..... If you want to investigate it your self...... Take off the yellow plastic on the top of the tank..... There will be a little 10mm or so od hose running from the top of the tanks backwards then under the seat, and down to the CC. Right before said hose runs under the seat, you will find a little tubular shaped valve. Make sure the arrow on it points towards the tank....NOT away from it. I have heard of some claiming theirs was installed incorrect. When you remove the hose from the tank.... try to apply suction to the tank end.... It should flow freely... If not... Said hose is the key to you problem. If the CC is plugged.....or the valve is not working the vacuum is not alleviated in the tank.
Erling |
11-08-2010, 08:59 AM
#6 |
I need a cape....
Oddometer: 983
or just remove the charcol filter and eliminate that and a few other problems all together...
11-08-2010, 09:47 AM
#7 | |
Drunken Squirrel
Oddometer: 2,587
That's what I did. Screw the environment, at least I'm not driving a giant truck like everyone else in Texas...
Check out my F800GS Ride Reports: Colorado (F800GS and 640ADV) Sep 2010 Riding to Colorado Solo! June 2011 3000 miles New Mexico and Texas! Arkansas Nov 2009 | Arkansas June 2010 | Arkansas Oct 2010 |
11-08-2010, 10:04 AM
#8 | |
I need a cape....
Oddometer: 983
11-08-2010, 03:50 PM
#9 | |
Oddometer: 2,786
Erling |
11-08-2010, 08:46 PM
#10 | |
Oddometer: 3,438
I should allow air to move freely INto the tank and also allow air to come out of the tank after it reaches some modest pressure of ... several PSI? Is that correct? Thanks! |
11-08-2010, 09:32 PM
#11 |
Oddometer: 206
So what is the vacuum effect doing to my gas tank?
11-08-2010, 09:42 PM
#12 | |
Drunken Squirrel
Oddometer: 2,587
11-09-2010, 05:49 AM
#13 | |
Oddometer: 2,786
Joel should bee here shortly to correct me...... Erling |
11-09-2010, 05:53 AM
#14 | |
Oddometer: 2,786
...... You should have a look.....Erling |
11-09-2010, 07:28 AM
#15 |
Beard Bros Racing
Oddometer: 3,373
thanks for all the replies everyone; i haven't had a chance to go out and check things over yet (since posting the original query) but its good to know that this is just another hiccup in the life of an f800gs and seems to be relatively easily solved.
i am beginning to think that all the quirks the f800gs has exhibited has worked to help us better understand how all the various systems on the machine actually work. if it ran perfect all the time would we be as educated about it? |
