Old 11-07-2010, 08:03 AM   #1
Migs OP
Migs's Avatar
Oddometer: 165
F800GS Missing a Chain Guide
This is my 2011 BMW F800GS. Do you notice it does not have a chain guide? I guess we must all believe that if the chain is tensioned properly no chain guide is necessary right? I'm not so sure. What do you all think?
Missing chain guide by Migs_flickr, on Flickr
"I consider myself a road man for the lords of karma"~Hunter S Thompson
"He who is not afraid will always be safe." -Lao Tzu
"Do not be bothered by anything."-S. Suzuki
Migs is offline   Reply With Quote
Old 11-07-2010, 08:29 AM   #2
EnderTheX
Drunken Squirrel
EnderTheX's Avatar
Oddometer: 2,587
If you look closely there are some reinforced areas on the bottom of the swing-arm where you can drill your own chain guide mounting points.
Many of us have pushed our bikes to the limit without one, just make sure you set your chain to the right tension and it won't come off regardless of the swing-arm angle. If you feel the urge to run super loose you can add one but most of use (myself included) don't feel it is necessary.
FYI... I run my chain with more slack than the specifications with no issues.
EnderTheX is offline   Reply With Quote
Old 11-07-2010, 08:36 AM   #3
Lonster
Avid Reader
Lonster's Avatar
Oddometer: 49
Chain guide
Here is a posting you might be interested in seeing how a chain guide was added.
http://www.advrider.com/forums/showthread.php?t=594334
09 F800GS
04 WR450
07 DRZ400
Lonster is offline   Reply With Quote
Old 11-07-2010, 11:03 AM   #4
Migs OP
Migs's Avatar
Oddometer: 165
Thanks for the links and the reassurance. I'm going to leave well enough alone. I have some motocrosser buddies who cannot understand the absence of the guide.
Times are GMT -7.   It's 03:04 AM.
