Old 02-11-2012, 04:05 PM   #46
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,270
here's the dr windscreen thread
http://www.advrider.com/forums/showthread.php?t=164001
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 02-27-2012, 08:58 AM   #47
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,270
pics of the safari rally kit
http://advrider.com/forums/showpost....81&postcount=3
just gas tanks will have it 1st
Alaska
Old 03-02-2012, 05:49 PM   #48
ShadyRascal
Master of None
ShadyRascal's Avatar
Oddometer: 6,759
Front fender from 2009 Yamaha YZ250f. I re-drilled the holes to shift the fender about 1/2" forward to clear the frame/oil cooler on the back end.
Originally Posted by Javarilla
Evolution, or, natural selection, has nothing to do with better.
It merely weeds out what is no longer suitable for the given context.
Originally Posted by Dragoon
I would rather be on my motorcycle thinking about God than in church thinking about my motorcycle.
ShadyRascal is offline   Reply With Quote
Old 03-02-2012, 06:27 PM   #49
neilaction
Slightly Less Adventurous
neilaction's Avatar
Oddometer: 7,609
Rally Raid
If it can't be fixed with a hammer, its probably electrical.
2009 Honda CBF1000, 1980 Suzuki GS1000ST (Aus spec), Dr6fiddy,
neilaction is offline   Reply With Quote
Old 03-03-2012, 10:07 AM   #50
exboomer
exboomer's Avatar
Oddometer: 91
Nice looking DR Shady. Do you want to sell your old side racks?
exboomer is offline   Reply With Quote
Old 07-20-2012, 04:05 PM   #51
macdesign
Just another f@t b@st@rd
macdesign's Avatar
Oddometer: 136
Something I knocked up
Here's my version of what I need to protect all the gear that I want to mount behind a windscreen.
There's a few more pictures in here if you're interested.
If it ain't broke, modify it.
'07 GSX1400 for .... my ego
'08 DR650 for .... everything the 14 doesn't do
'69 Honda 750-4 for teaching my son how to build bikes
macdesign is offline   Reply With Quote
Old 07-21-2012, 06:58 AM   #52
kbuckey
Oddometer: 867
So far I like this a lot - Dual Sport Fairing (see Vendors)
kbuckey is offline   Reply With Quote
Old 07-21-2012, 08:34 AM   #53
ShadyRascal
Master of None
Oddometer: 6,759
I put 1/2" spacers under my Screensforbikes and it smoothed out the airflow in the cockpit noticeably.
Old 07-30-2012, 01:19 AM   #54
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,270
I'm now using and loving a Madstad screen (18" CR in light smoke).
http://www.madstad.com/s.nl/sc.7/category.1921/.f
I can adjust if any angle and height i want and achieve ideal airflow for me!
A must do IMO if you do any long tours on your DR.
I can see over top just fine and it's out of the way when i stand up for rougher sections.
I went with light smoke so i could still see some down through it if need be.
Kept my FZ1 screen i had bolted to the stock light shield and cut out notches so the Turbo City brackets passed through.
Going to get some hand-tighten bolts so i can quickly remove the Robobrackets and shield all at once for more hardcore riding.
Alaska
Old 08-08-2012, 05:47 PM   #55
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,270
Update:
Played with my screen angle and height for the smoothest position for wind @ my helmet. I tried alot of variations as the robo-brackets move every way possible.
In the end, I raised it some and angled it back a bit more that the 60 degree Madstad talks about. The bottom is more open for air to pass underneath too and this makes it very nice going down the road. Having a vstrom and madstad bracket, it's also the same bottom open angle that works on that bike too. it may look a little funny but sure does it work well.
Nothing but calm air on my chest and head. Of course there is air leaking in from the side but it's not a goldwing. If you spend alot of time on paved roads with your DR this might be the ideal screen solution. I can see over it just fine for off-road work and the whole bracket / screen can come off quickly with 4 bolts/nuts if need be. (update: changed over to thumb nuts so I can do this by hand in minutes)
Alaska
eakins screwed with this post 02-17-2013 at 08:39 PM
Old 10-20-2012, 09:53 AM   #56
NYTrainer
NYTrainer's Avatar
Oddometer: 145
MRA Windscreen
I installed a small MRA bar-mounted windscreen from Twitsed Throttle that just keeps the wind off my chest & can be tilted up/down for colder/warmer days.
"Win without boasting...lose without excuse!"
2004 DR650 Suzuki,1978 Yamaha XS750,
1981 Yamaha XS650 Street Tracker,1981 Yamaha XV920 Chain-drive
1986 Yamaha YZ490-Vintage MX project, Yamaha TW200(Girl Friend's Ride) Yamaha TDM 850
NYTrainer is offline   Reply With Quote
Old 02-17-2013, 08:25 PM   #57
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,270
DR windscreen pic thread:
Alaska
Old 03-05-2013, 09:52 AM   #58
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,270
My cold weather DR setup:
http://www.advrider.com/forums/showp...&postcount=107
Alaska
Old 08-27-2013, 06:36 PM   #59
COSpringer
COSpringer's Avatar
Oddometer: 32
+1 for the Parabellum windscreen. Just finished a 600 mile road trip on my DR650 after installing a 25 inch screen (I'm 6'2"). I can see over the top of the screen and was getting a little head buffeting until I adjusted the bottom attachment points inward making the screen a little more vertical. No buffeting afterward; the clear air was just brushing the top of my helmet. From the vendor, the Parabellum uses locknuts to fasten the windscreen to the mounting brackets, but I substituted lockwashers under the bolt heads and threaded knobs ($3.60 each at Ace Hardware) for the locknuts so that I can detach the windshield quickly to ride offroad. It worked great maybe took 2 minutes to detach and reattach the windshield. Here are some pics:
COSpringer screwed with this post 08-31-2013 at 09:37 AM
COSpringer is offline   Reply With Quote
Old 10-21-2013, 02:33 PM   #60
gwhis
gwhis's Avatar
Oddometer: 521
Cee Bailey
Mounted about 2" higher than normal using inner bark buster bar mounts
It'a a disease and once you have it-that's it, it doesn't leave your body.
Colleen Millsaps, On Any Sunday The Next Chapter
gwhis SE IN
DR650 DRZ
gwhis is online now   Reply With Quote
Times are GMT -7.   It's 05:28 AM.
