Old 11-23-2007, 04:54 AM   #1
MZcountryboy OP
MZcountryboy's Avatar
Location: Northeast Kingdom, Vermont USA (close to Canada!)
Oddometer: 5,466
Honda XR350R
New to me, I pick it up next week.
Anybody know anything about these things? Looks like a XR250 on roids.
I did a search, not much turned up....
MZcountryboy is offline   Reply With Quote
Old 11-23-2007, 05:44 AM   #2
drew-at-large
Outhouse Race Team
drew-at-large's Avatar
Oddometer: 266
Early to mid-80s XR... basically a XR250R on roids... heavier but with more travel. Solid and fun. Below is the vitals on the 1983 model, however, I believe front disc brakes really didin't show up until 1984. I also provided the 1983 XR250R specs as well. I believe the hp ratings maybe a typo for both. I've seen the XR350Rs with around 31-32hp and the XR250R with around 20-22hp in other places.
Hope this helps some...
Cheers,
Drew
Make Model
Honda XR 350R
Year
1983
Engine
Air cooled. four-stroke, single cylinder SOHC, 4 valve,
Capacity
339
Bore x Stroke 84 x 61.3 mm
Compression Ratio 9.5;1
Induction
2x 26mm Keihin
Ignition / Starting
CDI / electric
Max Power
22.4 hp @ 7500 rpm
Max Torque
Transmission / Drive
6 Speed / chain
Front Suspension
41mm Air adjustable forks, 280mm wheel travel.
Rear Suspension
Single gas shocks, fully adjustable , 290mm wheel travel.
Front Brakes
Single disc
Rear Brakes
Drum
Front Tyre
90/90 -21
Rear Tyre
130/80 -17
Wet-Weight
165 kg
Fuel Capacity
9 Litres
Make Model
Honda XR 250R
Year
1983
Engine
Air cooled. , four-stroke, single cylinder SOHC, 4 valve,
Capacity
249
Bore x Stroke 75 x 56.5 mm
Compression Ratio 10.0:1
Induction
2x 24mm Keihin carbs
Ignition / Starting
CDI / kick
Max Power
30 hp 21.9 kW @ 9000 rpm
Max Torque
24.5 Nm @ 7500 rpm
6 Speed / chain
Front Suspension
Leading axel air spring 38mm forks 240mm travel
Rear Suspension
Pro-link air/oil shocks 4-way rebound damping 260mm travel
Front Brakes
Single disc 2 piston calipers
Rear Brakes
Drum
Front Tyre
80/100-21
Rear Tyre
110/100-18
Dry-Weight
108 kg
Fuel Capacity
9 Litres
calix meus inebrians
'03 F650GS Dakar
'95 ST1100 Pan European
"If you are part of the Rat Race, just remember at the end of the race... you're still a rat."
http://www.advrider.com/forums/showt...=4753&page=123
drew-at-large is offline   Reply With Quote
Old 11-23-2007, 08:08 AM   #3
Eurobiker
Vintage Cat Herder
Eurobiker's Avatar
Oddometer: 5,993
These were only made 83-85, when Honda inexpictedly decided to discontinue production. The 83,4 had dual carbs, while the 85 went to a single. The 85 had a slight bump in displacement at 353 cc. These, especially the 85, are great little trail bikes. You'll find more info over at thumper talk. Here's mine:
"If you don't know where you're going, any road will get you there." -Henry Foster
Eurobiker is offline   Reply With Quote
Old 11-23-2007, 09:04 AM   #4
KneeKicker
KneeKicker's Avatar
Oddometer: 2,630
funny to see this posted maybe it's a sign . There is one of these for sale locally an 84 for $750 decent looking bike in the picture especially for an 84 I've owned older xr's before (an 86 xr600) and they are good trail riding bikes how does $750 sound for this bike?
everything looks cool on motorcycle
"I got so drunk last night I woke this morning and someone had shit my pants" Ron White
KneeKicker is offline   Reply With Quote
Old 11-23-2007, 09:35 AM   #5
Eurobiker
Vintage Cat Herder
Eurobiker's Avatar
Oddometer: 5,993
Lets see a pic. Does it have the pimp-daddy enduro speedo/ elapsed timer? This may have only been on the 85's. As for price, I'd try to get him closer to $500, as it will need something; even if running.
Old 11-23-2007, 09:47 AM   #6
brp2004
Orygun
brp2004's Avatar
Oddometer: 200
xr350r
Fun bikes, although a little heavy. I had a 83 xr350r and an 85 xl350. Dual carbs are pain to tune, but have good power. I think they went to front disc in 84 and single carb in 85, if i remember correctly. My only complaint was that if the bike was hot it was a pain start.
brp2004 is offline   Reply With Quote
Old 11-23-2007, 11:54 AM   #7
drew-at-large
Outhouse Race Team
Oddometer: 266
It was only the '85 model that had the enduro speedo/timer set-up.
Old 11-23-2007, 12:05 PM   #8
WoovsHoovs
RUN SILENT
WoovsHoovs's Avatar
Oddometer: 3,830
Good bikes really-I have an extra set of dual carbs....
buddy had an '85 and it was very nice in its day-zero problems and it had decent lighting for night trails
I believe the 350 motors were more a downsized 500 than a larger 250-not a bad thing.
WoovsHoovs is offline   Reply With Quote
Old 11-23-2007, 01:32 PM   #9
apex
Oddometer: 323
I belive that is correct. I like all dual carbed XL & XRs but factory jetting is too lean which lead to problems run them rich and they last. I would also recommend a later model XR250 or 400 oil cooler. you didnt say what year it is.
apex is offline   Reply With Quote
Old 11-23-2007, 02:07 PM   #10
MZcountryboy OP
Oddometer: 5,466
I really don't remember much....
I rode this this bike a year ago, didn't buy then.
Guy comes back a year later, lower price, I do a barter deal for the bike even.
He's away for the holiday, I can't get it until monday.
I seem to remember the digital setup on the handlebars, and don't remember it having two carbs, but I could be wrong. The guy who I'm buying it from is only like 5'5", so he doesn't ride it much. He has fixed most of the issues on the bike, like new plastics, tires, cables, carb rebuild, etc..... When I rode it, I was impressed by how "snappy" it was for a 350.
Now I can't wait to pick it up, so I know what the hell year it is, and get a pic up here for you.
It's a pretty clean machine.
Thanks for all the help.
Old 11-23-2007, 02:35 PM   #11
2whlrcr
gooligan
Oddometer: 6,516
I had a friend who had the dual carb version. He absolutely hated it, because the carbs were such a pain. He still bitches about that bike.
I don't know if it's possible to convert it to a single carb, buy you may want to take that into consideration.
2whlrcr is offline   Reply With Quote
Old 11-23-2007, 03:17 PM   #12
apex
Oddometer: 323
they can be difficult for novice tuners but no way I would convert to single. sounds like its an '85
Old 11-23-2007, 04:21 PM   #13
KneeKicker
KneeKicker's Avatar
Oddometer: 2,630
my 86 xr600 had dual carbs I never had any problems and yes it did seem to have more power than my single carbed 94. And no it doIesn't have the fancy digital tripometer. it does have a speedo though. We'll see I emailed the guy for his bottom dollar I was thinking no more than $600 thats if the bike runs as good as the ad claims. I was planning a tear down with all new bearing repaint the frame and some new plastics.
Old 11-23-2007, 06:56 PM   #14
Solaros1
Solaros1's Avatar
Oddometer: 1,255
I had an 84 XR350 - neat bike - dual carbs were a bit of a pain. I sold it to a friend of mine and he rode it for about a year before it blew up (may have been running too lean) - he said finding parts for these old XR350's was getting difficult so he's switched to a DR400.
Solaros1 is offline   Reply With Quote
Old 11-24-2007, 07:01 AM   #15
WoovsHoovs
RUN SILENT
WoovsHoovs's Avatar
Oddometer: 3,830
I have an 84 xr500 and parts seem easily accessed-since it's way low on the priority list-it prolly won't get its new piston for awhile.
Tell ya when she was right it was close to my 525 on the bottom-and made my buddy's 02-xr400 feel like a mini bike-but the ktm kills it up top.
I think it'll make a good ds bike once freshened up-solid old scoot.
Keep us posted on the 350! It does look alot like an xr400...parts interchange!!!
Times are GMT -7.   It's 08:35 PM.
