Old 11-08-2010, 10:16 PM   #1
Krusty ... OP
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,600
DR650SE Index Topic #10- CARBURETOR/INTAKE
Several schools of thinking here. Many opt to stay with exactly what the engineers at Suzuki designed. Others feel the need to make a good thing better, and the intake tinkering can go from mildly tweaking the stock CV carb to opening up the airbox and/or switching to a flatslide pumper. And if you're so inclined, do-it-yourself fuel injection is on the horizon, thanks largely to the relentless efforts of mx_rob.
Intake-wise, what's worked for you?
-AIRBOX MODIFICATION
-AIR FILTERS
-STOCK CARBURETOR [MIKUNI BST40] MODIFICATION
-MIKUNI TM-40 [HSR-40]
-KEIHIN FCR39-MX
-FUEL INJECTION?
SUZUKI DR650SE INFORMATION INDEX
"...choosing a DR indicates an affinity for peace, harmony and enlightenment. Serenity lies in accepting it as it is, changing what you want, and the wisdom of knowing it ain't orange." -psmcd
Krusty ... is offline   Reply With Quote
Old 11-08-2010, 10:32 PM   #2
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,270
my bike had dynojet mods when i bought it. it surged and the power was very abrupt on/off. hated it.
now:
-stock needle & raised up w/ 1 washers for more gas on the main
-stock jetting
-slide NOT drilled w/ an additional hole
-spring not modified
-Procycle fuel screw now set at 1.75 turn out. this is my peak ideal speed.
-carb fully cleaned w/ pine sol soak. this made a huge difference in how much better it ran even though it looked clean. a ton of dirt came out. safe on rubber. search for hondo's post.
-ngk iridium plugs for the best possible fuel burn.
-stock airbox w/ only snorkle gone
-twin-air air filter
-gsxr muffler
-upgraded 2ndary air filter form procycle
-stainless allen bolts on top cap, throttle cables plate and float bowl (heat stock screws 1st w/ a lighter so they come out easier)
bike runs well from sea level to over 13k that i've had it to. pulls strong and linear. i use a 14 tooth cs and i can off-road in 1st and pull 80 all day in top. 50 or so mpg
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins screwed with this post 05-11-2015 at 11:10 PM
Old 11-09-2010, 06:43 AM   #3
Krusty ... OP
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,600
Bst40
From the factory, your DR650SE came equipped with a Mikuni BST40 constant velocity (CV) carburetor. You may begin your journey of enlightenment here:
The BST40 Bible
Airbox mod? If you plan to enhance your DR's ability to breathe, you will need to address the restrctive airbox. If your plans to tweak your carb include stay with the factory jetting, you won't likely need to do more than remove the snorkle at the top of the airbox. If you plan on doing more (bigger jets, Dynojet kit, etc.) you'll likely end up doing the "airbox mod".
Here's a picture, from the Keintech website:
www.keintech.com
mx_rob has been a man on a mission to improve the performance of the DR. He is a "fixture" over at ThumperTalk, and his early efforts focused on the BST40.
His website www.mxrob.com, has a BST40 section, including a link to this thread at ThumperTalk, comparing different needles.
Mikuni / Dynojet Jet Size Comparison
[from vmaxoutlaw.com]
Mikuni Dynojet
140
149.3
Flow rates based on size markings of Mikuni and DynoJet jets are not comparable. As a guide .. the chart to the left indicates equivalent sizes based on the diameter of hole in the jet. Mikuni jets are chamfered on the inside opening at the threaded end and
Dynojets have a machined flat surface. Keep this in mind when using this chart. These physical differences will never allow an exact comparison.
This chart is intended to be used as a tool to assist you in making a more
accurate decision when selecting a jet size range or comparing tuning data where an opposing brand is being used.
Actual jet sizes are highlighted with a gray background.
DynoJet jets are marked according to the diameter of the hole in the
jet .. ie: DJ150 = 1.5mm and DJ175 = 1.75mm. This is not true for Mikuni or most other OEM equivalent jets. This size
Mikuni jet, (N102.221 Super BN), is marked according to its' flow rate,
ie: 150 = a rating of 150 cc of fuel per minute.
150
142.5
152.0
145
154.7
155
147.5
157.3
150
160
152.5
162.7
165
155
165.3
157.5
168.0
170
160
170.7
162.5
173.3
175
165
176.0
167.5
178.7
180
170
181.3
172.5
184.0
185
175
186.7
177.5
189.3
190
180
192.0
182.5
194.7
195
185
197.3
187.5
200
190
202.7
Krusty ... screwed with this post 05-04-2011 at 11:35 PM
Old 11-09-2010, 08:17 AM   #4
SkunkWizard
recycle crime scene tape
SkunkWizard's Avatar
Oddometer: 756
reference pic
TM-40 & stock
~DR 650~
Upgrades:
1. dented tank
SkunkWizard is offline   Reply With Quote
Old 11-23-2010, 01:04 PM   #5
macdesign
Just another f@t b@st@rd
macdesign's Avatar
Oddometer: 136
What about a road only set up?
Let's establish one thing up front - My DR doesn't see any dirt at all.
It's a city commuter, which is currently being made even more so (read - being motarded), and a damn good one at that
So, I'm after anyones views or experience on dumping the airbox entirely and running a pod filter or similiar.
In the stock of bits and pieces to play with there's obviously the standard carb and exhaust as well as a TM-40, an FMF Q4, a GSXR titanium can, and finally a FMF oversize front pipe/Hindle rear (to suit the X40X can).
I'll probably end up mucking about with them all but don't mind not having to "re-invent the wheel".
If it ain't broke, modify it.
'07 GSX1400 for .... my ego
'08 DR650 for .... everything the 14 doesn't do
'69 Honda 750-4 for teaching my son how to build bikes
macdesign is offline   Reply With Quote
Old 11-28-2010, 09:02 AM   #6
Krusty ... OP
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,600
TM40-6 (HS40) manual from Mikuni:
http://www.zodiac.nl/instructions/234862.pdf
Krusty ... screwed with this post 03-01-2011 at 09:00 AM
Old 11-28-2010, 04:24 PM   #7
shu
Oddometer: 1,053
I'm pretty happy with the stock carb/airbox set up on the DR. It has been totally reliable and I never have to mess with it. I live at 7500 feet and ride above 11,000 feet on Colorado passes often, and have put in many miles at sea level as well. The bike always starts and runs well with no hesitation or misses from idle to redline. (If I want more power, I usually choose my other bike.)
Just my .02.............shu
shu is online now   Reply With Quote
Old 11-29-2010, 05:13 AM   #8
plugeye
mc caregiver
plugeye's Avatar
Oddometer: 3,893
cut box/ twin-air AF
39mm fcr-mx, jetted normal except:
38pilot 50leak EMP-3 magic-racing screw 1.0 turns out
plugeye screwed with this post 11-29-2010 at 06:06 AM
plugeye is offline   Reply With Quote
Old 11-30-2010, 08:00 AM   #9
996DL
Buell me
Oddometer: 2,333
07 DR650 with stock exhaust at 2200 ft asl...
Full Jesse/Kientech airbox mod, TwinAir foam air filter, Uni pleated filter replacing useless oem foam cannister, drilled slide, exposed oem mixture screw @ 1 turn out, Jesse's recommendation of 155 DynoJet mainjet for oem exhaust, and Most Importantly in my case: DynoJet needle set one step leaner than instructions, to Completely Cure the common off extended idling flat spot: (DJ needle's clip set at 3 down from top).
This setup performs perfectly and routinely yields 60mpg Imp gal / 48mpg US gal. My DR is used as a "roadie" with a taller 16 tooth frt sprkt and ridden like I want to keep it for the long run, with no banging off the rev limiter, nor treating the transmission like a 125 motocrosser.
996DL
996DL is online now   Reply With Quote
Old 12-04-2010, 08:40 PM   #10
inire
Browncoat symp
inire's Avatar
Oddometer: 412
Bump
Coz my bike only gets 40-45 mpg and i dunno why.
1982 AR80 (The Neverending Story)/ZX750A3 "99 Problems"/VTR250
inire is offline   Reply With Quote
Old 12-07-2010, 07:06 PM   #11
kalsop
kalsop's Avatar
Oddometer: 81
throttle shut down responce
Originally Posted by inire View Post
Bump
I have a question, my carb doesn't seem to shut down quite quick enough between shifts. The only mods done are air/mix screw 1-1/2 turs out and shimmed needle. .32/.09 mm. Any thoughts?
kalsop is offline   Reply With Quote
Old 12-07-2010, 10:38 PM   #12
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,270
start by cleaning it with pine sol soak (google for hondo's thread)
you might have sticky/gummed throttle cables or throttle tube.
Alaska
Old 12-08-2010, 08:13 AM   #13
kalsop
kalsop's Avatar
Oddometer: 81
now:
-stock needle & raised up w/ 2 washers for more gas on the main
-stock jetting
-1 additional hole drilled in the slide for better throttle response
-jesse's fuel screw now set at 1 turn out. had it out more for better idle but off-idle bog. now off idle bog at 1.
What size washers did you use?
Old 12-12-2010, 02:53 PM   #14
ER70S-2
ER70S-2's Avatar
Oddometer: 6,931
Fuel Chart
Thanks to Northyork:
http://www.advrider.com/forums/showp...ostcount=35442
2004 DR650: 62,605 miles
2013 WR250R
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 12-12-2010, 06:47 PM   #15
kalsop
kalsop's Avatar
Oddometer: 81
1
Thank you.
Times are GMT -7.   It's 12:50 PM.
