Old 04-17-2012, 02:27 PM   #61
sagedrifter
Southern Explorer
sagedrifter's Avatar
Oddometer: 1,233
Originally Posted by Nessman View Post
Thanks Drifter.
I've got a stock exhaust, what should my jetting be?
It runs fat, no choke required at start so I think I'm fighting a jetting problem. No fuel in the oil and the float is high and dry.
I'm guessing its a DJ 160 main? Thats usually run with an after market pipe. It could be a 160 Mikuni which would be very fat.
I would use a DJ 155 or a Mikuni 145 main jet with a cut air box and stock exhaust. If your getting 30 mpg, something else is wrong though. Your only on the main jet when the throttle is well open. The needle controls the economy the most.
With the stock exhaust, I would try the needle in the middle or 3 down from the top. If your at 4, there should be two open notches below the E-clip.
I always like the 4th position though.
The carb is leaking some where, I would just replace the float o-rings with OEM parts, check the float needle. Does it seal when you blow on the fuel line? If its original, I would just replace it. Put a fresh OEM stock pilot jet in, I think thats a 42.5.
www.cheapcycleparts.com has the parts, I usually get my jets through them. Motolab in the vendors section sells the correct o-rings and jets too.
If I go into a carb, I just freshen every thing up. It seems like the o-rings last about 3 years now with the ethanol blends. My bowl seal just failed this year, it was like hard plastic after 4 years. The ethanol eats up the fuel hose too, so I tend to replace rubber stuff at least before three years. The float needle is rubber tipped also. I've been running marine stabil for the last two years off and on and it does help greatly to keep things lubed.
I always get 47 mpg or better.
sagedrifter is online now   Reply With Quote
Old 04-17-2012, 02:45 PM   #62
Nessman
Social invalid
Nessman's Avatar
Oddometer: 1,294
Ethanol....I hates ethanol.
I'll take your O-ring advice and see what happens, smaller jets if that doesn't help.
Matt
Moto Guzzi T-3
'05 DR650
Nessman is offline   Reply With Quote
Old 04-17-2012, 03:01 PM   #63
sagedrifter
Southern Explorer
Oddometer: 1,233
The stock main is a 140, the 145 Mikuni works fine with a cut air box. I always thought the DJ 155 was a bit rich, the 160 DJ would be really rich with stock exhaust. Probably had a slip on before and the original owner put the stock pipe back on without reducing the main to a DJ 155?
If you need to change the main, I would get OEM. Make sure the needle only has the e-clip and the white plastic spacer was left out.
Old 04-18-2012, 04:42 PM   #64
Nessman
Social invalid
Nessman's Avatar
Oddometer: 1,294
I ordered the kit from ProCycle yesterday, it was in the mailbox this afternoon.
Now to find time to put it in.
Matt
Moto Guzzi T-3
'05 DR650
Old 05-02-2012, 01:16 PM   #65
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 2,908
Send a message via AIM to Bronco638 Send a message via Yahoo to Bronco638
I know that Kris and Nordie Boy already posted similar charts (Kris on Page 1 Post #3 and NB on Page 2 Post #30) but I found a more comprehensive one, courtesy of motolab, (here) and thought I would share.
Width (in.)Keihin #DynoJet #Mikuni #
0.054140130121.9
0.055142.5132123.8
0.056145134125.6
0.057147.5136127.5
0.058150138129.4
0.059152.5140131.3
0.06155142133.1
0.061157.5144135
0.062160146136.9
0.063162.5148138.8
0.064165150140.6
0.065167.5152142.5
0.066170154144.4
0.067172.5156146.3
0.068175158148.1
0.069177.5160150
0.07180162151.9
0.071182.5164153.8
0.072185166155.6
0.073187.5168157.5
0.074190170159.4
0.075192.5172161.3
0.076195174163.1
0.077197.5176165
0.078200178166.9
0.079202.5180168.8
0.08205182170.6
0.081207.5184172.5
0.082210186174.4
0.083212.5188176.3
0.084215190178.1
0.085217.5192180
0.086220194181.9
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 05-02-2012, 08:08 PM   #66
Nessman
Social invalid
Nessman's Avatar
Oddometer: 1,294
Last tank was @35mpg, we're making progress. Thanks for the O-ring advice.
Next step is a stock shimmed needle and 145 main.
Matt
Moto Guzzi T-3
'05 DR650
Old 05-02-2012, 08:40 PM   #67
sagedrifter
Southern Explorer
Oddometer: 1,233
If the petcock is stock; Make sure the petcock is not back feeding through the vac line and make sure its not leaking when it shoud be off.
35 mpg is BAD.... No need for the stock needle, the DJ needle ain't causing 35 mpg. The stock needle sucks.
I bitched when I saw 42 mpg, it was the float o-rings.
Normal BST carb economy for me was 45 to 47 mpg jetted and with my fat but over the pegs while the right hand twisted the throttle often...
You could always just order a TM40 from Procycle...
Old 05-14-2012, 02:49 PM   #68
Nessman
Social invalid
Nessman's Avatar
Oddometer: 1,294
52MPG
New O-rings got me from 30MPG to 35MPG, swapping the 160 main jet for a 142.5 (shop didn't have a 145) put me over the top.
It doesn't have quite the stomp it had but it's still fun. I might go to a 145 some day but I'd rather do the TM40 carb swap
Thanks sagedrifter.
Matt
Moto Guzzi T-3
'05 DR650
Old 05-20-2012, 02:55 AM   #69
Mambo Dave
Mambo Dave's Avatar
Oddometer: 2,497
Here's what I'm running - or plan to run - and wouldn't mind some input:
My bike has a DG exhaust and a 165 main jet with the air/fuel screw turned out a little by the previous owner. He also ran it with the side-plate off of the airbox... and this is the way mine sits now. Both he and I are worried it is lean in the mid-ranges since he didn't shim up the stock needle, but the bike runs absolutely great (maybe too great - don't want to urn a hole in the piston here...)
I just ordered the pro-cycle DJ kit for mine.
My plan is to open the top of the airbox up and put that side-plate back on. I run at sea level to... sea level. Florida doesn't change much.
How rich of a DJ (in the kit) main should I go, what initial clip setting do you suggest I use (DJ needle), and the stock air filter seems pretty free-flowing... so would there be any benefit to any other air filter out there?
This bike will have a 16-tooth sprocket, and be usually run at 80 to 90 MPH for about 30 minutes at a time twice a day (slower on weekday mornings when I get caught in traffic), so it probably won't ever be wide-open-throttle, but it will be really open. Eventually it will get a 17 tooth sprocket when I convert it over to a 520 chain, but as this OEM chain only has 2900 miles on it, I figured it would be worth using a 16 tooth for now.
"After reading through this thread I've come to the conclusion that more people cruise the internet looking for reasons why X bike won't work in Y scenario rather than actually riding their motorcycles." -- RyanR
Mambo Dave is offline   Reply With Quote
Old 05-20-2012, 03:42 AM   #70
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 6,781
160 main and 3rd from top to start with and fine tune from there. Mixture screw to suit.
The stock filter works ok but others like the TwinAir work better.
NordieBoy is offline   Reply With Quote
Old 05-20-2012, 08:35 AM   #71
jessepitt
Dual Sport Addict
jessepitt's Avatar
Oddometer: 988
I have a whopping 200 miles on my new DR650 and the low speed/throttle surge was killing me. I cant afford a jet kit yet so I decided to shim the needle. I had done this on my previous DR650 so I new it was easy and I figured I would take some pics of the process to help those who have yet to do this including my little brother who just picked up his new bike yesterday! If that surge bothers you this trick eliminates most of it. I forgot what a great difference it makes, night and day! It is very easy to do as I said; first remove the side panels, then the seat then the tank. Be sure to disconnect the small vacuum line from the carb to the petcock and don't worry about emptying the tank as the vacuum petcock will not flow without the engine running.
Once you have it stripped down you can easily see and access the carb. Be sure to clean the area around the carb so no contaminates make it inside your carb while you are working on it.Then loosen the cab boot clamps on either side of the carb and rotate the top to the left side of the bike, you may need to loosen or remove the plastic reusable zip-tie that holds the throttle cables to the frame. That will allow more rotation without damaging your cables. Once you have the carb rotated so that you have a clear shot at the cap remove the two screws holding the cap in place. Be aware that there is a spring under the cap so press down on it while removing the screws.
now you should be here:
Under the cap is the diaphragm which is very delicate so proceed with caution and keep everything clean. Remove the cap and the spring then gently pull up the diaphragm which is connected to the slide.
Here is the slide/diaphragm/needle assembly:
The needle just sits down in the slide and is held down by the spring so to get it out just tip the slide and it will fall out. Once you have the needle out you will see a plastic spacer and a c-clip. Remove the c-clip and slide the spacer slightly down the needle and place a thin stainless washer on top of the spacer and replace the c-clip, then snug them all tight to the c-clip:
I used a plastic washer from another carb I had laying around but any thin washer will work as long as it wont rust.
When you drop the needle back into the slide you may notice that it does not hang straight down from the slide. This is due to a shoulder inside the slide. I don't know the purpose for the shoulder but as we are not changing the seating surface I don't think it is a problem. I have heard that some people cut there spacer so that it fits past the shoulder and sits flat but that would require a thicker shim and I feel like there must be a reason for the shoulder so I left mine alone. The reassembly is easy. Just drop the slide back into the carb. Make sure the the diaphragm is sitting flat and even around the top of the carb body and does not get pinched when reinstalling the cap. Also of note: there is a tiny o-ring that seals the vacuum line connection between the carb body and cap. It is visible in the third picture. Be sure not to loose or pinch this little guy. Other than that there aren't any tricky parts, just be careful not to pinch any vacuum lines when you rotate the carb back into place. You will know the carb is aligned correctly when the bump on the front of the carb neck aligns with the corresponding notch on the carb boot.
While I had the carb rotated to do the needle shim I decided to go ahead and remove the plug over the fuel screw and install an extended full screw I had from another carb. The extended screw can be purchased from procycle.
First it is drill (by hand) the little brass cover plug:
Once you have CAREFULLY drilled through this plug you can CAREFULLY thread a small screw into the hole.
Grip the screw with pliers and twist/tug out it comes!
Easy, and now you have the ability to adjust your fuel screw.
This pic illustrates why an extended fuel screw is nice. Getting to that little bugger while the engine is hot is no fun:
Extended vs. regular screw:
Anyway, I hope this helps a few folks with their low speed surge. It really does make a huge difference and doesn't cost anything, also it is a good way for new DR owners to get a feel for their bikes and show you just how easy they can be to work on.
jessepitt screwed with this post 07-01-2012 at 08:57 AM
jessepitt is offline   Reply With Quote
Old 05-20-2012, 01:57 PM   #72
sagedrifter
Southern Explorer
Oddometer: 1,233
I would not ride a stock needle carb with the cover off. That would be way too lean. Very lean! The DJ needle is totally different and much better than the stock USA needle.
Put the cover back on ASAP. With an open air box you need a jet kit with the adjustable needle. Taking the side cover off produces extra noise and surging. Don't kill the poor thing... Its amazing how much abuse the DR650 can take.
The exhaust doesn't really matter, its the added air from the intake that matters most. The needle should be at 4 just like the directions will say. The procycle kit uses mikuni jets. The 160 works fine. You can run the needle at 3 or the middle position, but in my experience its too lean and surges more for Florida. I prefer the 4th notch, that's two up from the bottom or 4 down from the top.
Have fun...
Sent from my GT-S5690L using Tapatalk 2
sagedrifter screwed with this post 05-20-2012 at 02:04 PM
Old 05-20-2012, 08:58 PM   #73
Mambo Dave
Mambo Dave's Avatar
Oddometer: 2,497
I did as you suggested, and it may have nearly got me killed tonight. It's either the cover, or that Sea Foam added to the fuel tank earlier in the day dislodged some varnish or debris and is blocking some part of the carb.
I put the cover back on and just assumed everything would be fine for my 40-mile ride in to work tonight. Instead I ended up in a terrifying position of a bike that would sputter at about mid-throttle, so the best I could do was an indicated 70 MPH (give or take 3 MPH... slower up gradual hills or into the wind, best speed of 73, once, when I got lucky) which is way, WAY too slow on a Florida super-slab. I was just waiting for someone to rear-end me with them doing a real 85 MPH while I was probably only doing 63... if that. In the 35 miles of highway I was passed by everything except about 3 cars...
I will take the cover back off to see how it runs... I've got a funeral to make it to tomorrow morning, so it would be ideal if the bike would run the way it was running before I put the cover back on... I don't have the time to go this slow, and tomorrow morning's run south is in rush-hour traffic.
As it was, I had no surging with the plate off, and the bike ran very well - better than most DR's I'd guess. But the bucking-bronco I tried to ride in to work was a whole different story... I finally learned to only turn the throttle to a certain point, and no more - no matter what.... that made for a long and dangerous ride.
Mambo Dave screwed with this post 05-20-2012 at 09:10 PM
Old 05-20-2012, 09:18 PM   #74
sagedrifter
Southern Explorer
Oddometer: 1,233
Well, you are running a 165 main of some sort? So, yes at heavy throttle use it would be too rich with the cover on. BUT... At moderate throttle you are very lean with the cover off.
You would be very, very lean when in the needle, if its a stock needle with an open air box. I would not run it like that.
You would be better off running a mikuni 140 main or a DJ 150 with the stock needle and a stock air box with the dg exhaust.
If it was mine, I would NOT run a stock needle with the air box cover off. Even with the needle shimmed I would leave the air box intact.
The needle controls mid throttle, the main jet comes into play at interstate speeds.
The air box should only be opened when you have a jet kit. Other wise leave the main alone. You can shim the needle and pull the snorkle.... any more than that .... Add a jet kit.
sagedrifter screwed with this post 05-20-2012 at 09:27 PM
Old 05-21-2012, 12:08 AM   #75
Mambo Dave
Mambo Dave's Avatar
Oddometer: 2,497
Thanks. I am kinda of stuck for the moment - I need the power to stay alive for the ride home. I just tested it with the cover back on and off, and sure enough it does cut out after about mid throttle (even without the RPM's up).
I guess mid-range will be lean, but apparently my normal cruising RPM's are well above mid-range or I wouldn't keep hitting a wall.
Thanks for the help. I have the ProCycle jet kit on order, so hopefully a little lean running in the mid range won't kill it. I bought this bike to rely upon for commuting, so it has to be on the road... parking it isn't an option. Maybe tomorrow I'll shim up the needle for the time being.
Times are GMT -7.   It's 06:37 PM.
