10-17-2012, 07:14 PM
#91 |
Oddometer: 648
I haven't had a chance to pull it yet but should by Saturday, I'll check it out and get back with you. It's only been 200 miles since it was rejetted and the p/o couldnt remember what was in there, I am starting to get that "uh oh, I just got hoodwinkled" feeling.....
1996 Kawasaki KZ1000P (currently being rebuilt) World class nutritional supplements, weight loss, meal replacement shakes, quality energy drinks, pre and post workout supplements! Earn extra income, become a distributor or just purchase: Advocare products-www.advocare.com/12084065 badweatherbiker screwed with this post 10-19-2012 at 03:20 AM |
10-17-2012, 07:49 PM
#92 | |
Oddometer: 75
It seems to run well and I'm loathed to try and fix what isn't broken. I like the quietness of the standard pipe too but would like to remove the restrictor ring in the header pipe or replace the standard rusty pipe with an FMF Hi-Flo Stainless steel headpipe but I'm unsure if this will require or affect carburation changes. Or if this will give any increase in power or noise. I doubt it will happen but if Suzuki announced 2013 DR650i I think there would be a lot of people buy them up. |
10-20-2012, 09:40 AM
#93 |
Oddometer: 77
Carb/exhaust Mods
My 2004 DR came with a cut airbox, Dynojet carb kit & stock exhaust.
I replaced the stock exhaust with an FMF Q4 & powerbomb header for less weight & more power. The stock carb set-up was great on the roads, but any off-road work quickly showed the CV carb's limitations. I installed a Kehien 41mm, a K&N & have never looked back. Best single mod ever!
"Win without boasting...lose without excuse!" 2004 DR650 Suzuki,1978 Yamaha XS750,!986 Yamaha Radian, 1981 Yamaha XS650 Street Tracker,1981 Yamaha XV920 Chain-drive 2003 Yamaha FZ1,1986 Yamaha YZ490-Vintage MX project, Yamaha TW200(Girl Friend's Ride) |
10-20-2012, 11:02 AM
#94 | |
Grumpy Young Man
Oddometer: 3,765
10-28-2012, 04:46 PM
#95 |
Oddometer: 648
any ideas on how to set the float height on a stock carb?
I looked at the st bible but unless I am a tard I still don't see an actual setting for it other than a pic
1996 Kawasaki KZ1000P (currently being rebuilt) World class nutritional supplements, weight loss, meal replacement shakes, quality energy drinks, pre and post workout supplements! Earn extra income, become a distributor or just purchase: Advocare products-www.advocare.com/12084065 |
10-28-2012, 05:17 PM
#96 | |
2 wheel whore
Oddometer: 123
In short... The float assembly has a little metal tang that actuates the float needle. You make small adjustments to the height by bending the tang. This affects how soon after the float starts to rise that it lifts the float needle. From my own experience the float height is very sensitive to being wrong. Too high and it floods, too low and it dies every 500m. If I remember Derek's post correctly it's 14.7mm from level. There are other posts that can describe the measuring process better than I can. Will try and find one for you [PS: had the same issue as you with leaky petcocks too. Had to drain airbox regularly until I got it fixed. Rock bike in 3rd gear until you hit the compression stroke to make sure your valves are shut. Better to fill the airbox than cylinder]
2 Brothers, 2 Scooters, 25,000 kilometres. www.rightaroundaustralia.com PX200 '86 K100RS K7 DR650SE greystoke screwed with this post 10-28-2012 at 05:26 PM |
10-28-2012, 05:28 PM
#97 | |
2 wheel whore
Oddometer: 123
Found Dereks post
http://advrider.com/forums/showpost....postcount=1121 Using a float height measuring tool Quote:
2 Brothers, 2 Scooters, 25,000 kilometres. www.rightaroundaustralia.com PX200 '86 K100RS K7 DR650SE |
10-28-2012, 05:34 PM
#98 |
Oddometer: 1,658
With care, ie a good eye allowing for parallax http://en.wikipedia.org/wiki/Parallax a short steel ruler available at most hardware stores will do the job http://www.justtools.com.au/prod7108.htm
![]() Use either a metric or imperial, not a dual scale. Any dual scale measuring stick is almost useless. |
10-28-2012, 05:42 PM
#99 | ||
Oddometer: 2,564
For our purposes, the float has 3 positions. 1. With the float bowl off and the float hanging straight down. It will be in a similar position to pic 1 2. Slowly rotate the carb toward upside down. Somewhere past 90*, the float will pivot toward the carb body, stopping when the tang engages the needle. This is not 'see-able', it's hidden in the plastic. This is when you want the float edge seam to be parallel to the bowl 0-ring surface; pic 2 This is where you'd measure the float height, but parallel is easier. From the manual: Float height: 14.7 +/- 1.0mm (0.58 +/- 0.04 in) 3. While continuing to rotate the carb completely upside down, the weight of the floats MIGHT over power the tiny spring in the needle assembly. If not, a light touch with your finger will. Pic 3 You can also see the finger holding the float frame, not touching the float itself. Shamelessly Stolen From the BST-Bible (thanks to Laramie LC4): Quote:
2004 DR650: 46,358 miles of ![]() ER70S-2 screwed with this post 12-23-2012 at 11:55 AM |
10-28-2012, 05:55 PM
#100 |
Southern Explorer
Oddometer: 1,233
The BST Bible shows the no tools method.... but I always measure mine like the manual shows.
You can pic up a Vernier Caliper pretty cheap at a Habor Freight store, maybe an auto parts place etc... With the float installed, flip the carb over and measure from the carb to the floats bottom or the middle center of the rounded area looking at it from the side. Manual says .58" or .47mm. Gently bend the metal tab on the float needle till its right. Its very easy to screw up, you might want to have a local show you. I've helped my neighbors before, there is probably an inmate or some other bike guy near you. Many of the screwed up carbs I've seen are float related. Guy's put in a jet kit and bump the float off and it runs lean or floods bad.... Usually the latter, some with fuel dumping on the ground... So its... .58" from the float's bottom to the carb base where the bowl seals to. Venier Calpers work the best, you set them and lock them up to the right gap. Then use them as a story pole etc.. Then later you can measure bearings and shafts and all kinds of other good stuff. Every tool box should have the usual measuring devices anyway. Doing it like the manual from Suzuki is fairly exact and it works every time, bike runs perfect, no guess work, no eye balling, measure it at .58" and you know its right. sagedrifter screwed with this post 10-28-2012 at 06:00 PM |
10-29-2012, 05:09 AM
#101 |
Oddometer: 648
thanks for all the help guys, got a bunch of numbers going on here though. 14.7mm .47mm, 58"
lolI have a measurer that reads 32nds or mm so am I going the 14.7 route or as Sage says .47? I gues I am still confused
10-29-2012, 05:13 AM
#102 |
Oddometer: 648
This is where you'd measure the float height, but parallel is easier. From the manual: Float height: 14.7 +/- 1.0mm (0.58 +/- 0.04 in) -as you slowly rotate the carb vertically, the float will drop into the bowl. when this happens you want these 2 edges to be straight. ![]() So at this point where the tang first contacts the little spring loaded pin on the needle, this is where I should take my measurement?
10-29-2012, 07:11 AM
#103 |
Oddometer: 648
when the float drops into the bowl should the needle be seated all the way down into the chamber or half way out, I can get a parallel either way
10-29-2012, 01:41 PM
#104 | ||
Oddometer: 2,564
14.7mm = .58" SAE Quote:
2004 DR650: 46,358 miles of ![]() ER70S-2 screwed with this post 12-24-2012 at 06:13 PM |
12-10-2012, 05:35 PM
#105 |
night owl
Oddometer: 130
Airbox screen
Made a screen for the air box to keep those pesky fishflies outta there.
