Old 12-23-2012, 07:28 PM   #106
basketcase
lifelong reject fixer
basketcase's Avatar
Oddometer: 1,417
Installed 35F0x can - rejetting suggestions or thoughts?
I ran up on a 35F0x can locally and have it installed with the stock header and the 2-bros midpipe. Here is the set-up as it is currently parked in the carport:
Stock carb and needle
Extended mixture screw
Slide drilled
Snorkel pulled
No other mods to fuel or intake system.
Since installing the new can the bike idles fast after it is warmed up. I expect I can take care of that with the mixture screw and the idle adjustment. But I've not run a tank of fuel through it or pulled the plugs to get a read on whether it is now running lean.
Before I get into all that, what suggestions can the brain trust provide about possible jetting changes?
Thanks in advance,
Rick
'00 BMW R1100RT, Gone away: 5 previous BMW's, 3 Honda's, 2 Suzuki's
"The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane." - Marcus Aurelius
basketcase is offline   Reply With Quote
Old 12-23-2012, 07:40 PM   #107
Cobain
night owl
Cobain's Avatar
Oddometer: 132
155 jet without snorkel, 160 without side cover. Thats what I've come up with from my experience. Ive just installed a gsxr so we will see how that goes with the 160.
Cobain is offline   Reply With Quote
Old 12-23-2012, 08:20 PM   #108
sagedrifter
Southern Explorer
sagedrifter's Avatar
Oddometer: 1,418
As long as you keep the air box intact your fine. The exhaust doesn't add air so its fine. But, your missing out on things. Add a TM40 and cut the air box.
sagedrifter is offline   Reply With Quote
Old 12-23-2012, 08:48 PM   #109
Cobain
night owl
Cobain's Avatar
Oddometer: 132
That'd be great! anybody wanna donate one? Haven't looked into getting one too much, what are the advantages?
Old 03-14-2013, 01:15 PM   #110
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,568
BST carb - Off-idle bog issues and things to check:
http://www.advrider.com/forums/showp...ostcount=74911
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins is online now   Reply With Quote
Old 09-20-2013, 06:38 PM   #111
Nessman
Cluttered Minimalist
Nessman's Avatar
Oddometer: 1,747
Not sure where to put this so I'll put it here.
My choke is hanging up, I've cleaned out the "well" in the carb a couple of times and it helps but it only lasts a little while. I've been starting without the choke all summer but it's getting cold, time to fix it.
Am I more likely fighting crud in the choke well or a dodgy cable that needs to be replaced with a push/pull knob from Procycle?
The Procycle knob looks to be recessed, is it difficult to actuate?
'07 Bandit 1250ABS
'78 XS650 with patina
Huge piles of Guzzi that aren't motorcycle shaped.
Nessman is offline   Reply With Quote
Old 09-20-2013, 06:54 PM   #112
sagedrifter
Southern Explorer
Oddometer: 1,418
Yep some oem cables get sticky. I'm still using the original on my 07 and I lived on the coast also.
If mine goes bad I'll get the short one from Procycle. PC also has metal choke nuts that replace the easy to strip plastic ones....
Old 03-01-2014, 10:24 PM   #113
ER70S-2
ER70S-2's Avatar
Oddometer: 6,274
This tapered piece has been found in an occasional float bowl. (photo thanks to Alanthealan)
It goes here. From Motolab: "The tapered end goes in first. It may want to fall out again. If it does, try a little bit of super glue."
2004 DR650: 62,496 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 03-02-2014, 04:28 PM   #114
BergDonk
BergDonk's Avatar
Oddometer: 3,467
We've got an DR650SE FCR thread going over on the Oz forum:
http://advrider.com/forums/showthread.php?t=958369
A few of us have started off with MXRob's specs, but have moved on. Might be the coriolis effect, or different fuel, dunno.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 05-27-2014, 11:15 PM   #115
Tinker1980
Tinker1980's Avatar
Oddometer: 1,232
I have a nicely farkled 2009 DR650, and while it runs like striped ass gorilla, I find I am not getting the gas mileage mentioned other places for this bike. My mods include:
Tm40 carb
Header pipe, I believe it is an FMF.
Supertrapp muffler with 9 plates
Side cover removed from airbox.
The best I can seem to get is 39 mpg. No fuel in the oil, no problems other than an occasional issue with extended idling. I weigh 230 and tend to run a bit too fast (70-75 mph) on the highway.
Tinker1980 is offline   Reply With Quote
Old 05-28-2014, 10:35 AM   #116
rpet
Awesometown
rpet's Avatar
Oddometer: 820
Tm40 carb
tires?
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surfboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Old 06-07-2014, 02:47 AM   #117
Tinker1980
Tinker1980's Avatar
Oddometer: 1,232
Originally Posted by rpet View Post
tires?
Shinko 705's, for now. Aired up properly as well.
Originally Posted by Motomedic View Post
Shortly afterward, I heard the voice of God. He said, and I quote, "Dumbass."
Old 06-10-2014, 03:33 AM   #118
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
What pressure is "properly"?
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 06-11-2014, 06:09 AM   #119
Tinker1980
Tinker1980's Avatar
Oddometer: 1,232
35 front 35 rear.
I was incorrect about the air box - the side cover is present, the top is cut out. I think the problem may have been my air filter - I took it out today after riding home from work, and went to clean it (K&N) and it nearly held water. Got it soaped and cleaned out, it is drying out right now. I'll oil it up and run a tankful or two through it to see if there is a change, but I'm betting there will be a noticeable change in the idle.
Old 06-12-2014, 07:23 AM   #120
dflow
dflow's Avatar
Oddometer: 349
Fuel/float level quick check method
I have used the following method of checking the fuel level of a couple of DRs recently. It's a handy way to check, compare or establish a baseline to reference later. The picture shows the stock BST carb but any carb with a drain nipple and screw on the bowl will work. Attach a length of clear tubing and loop it upwards and hold it there by whatever means. The upper end of the tubing is left open. Now open the drain screw on the carb bowl and set your petcock to prime (if stock) or on/res (if aftermarket). Allow any air bubbles to clear and view the fuel level. Be sure to level the bike and square-up your camera to avoid distortion when registering the level relative to features on the carb body.
You still may need to open the carb to adjust the float height if yours seems to be far from the image shown but at least you know before hand.
I have not checked the float height on either of the bikes mentioned by traditional means in well over 30k miles each so there is no assurance that they are still within the acceptable range. That being said, I have had no issues that would indicate a problem and so it serves as a sound baseline check for me.
'06 DR650SE, '99 R11S, '84 R100 project (eventually)
Get your facts first, then you can distort them as you please. -Mark Twain
dflow is offline   Reply With Quote
Times are GMT -7.   It's 02:24 PM.
