Old 11-13-2010, 06:20 AM   #1
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,228
Question Really dead 1150
After riding five days in pouring rain, and the bike sitting outside during the night,
this morning the bike was utterly dead. Not even the RID comes on.
I might as well have waved the keys in front of the bike.
Removed the tank. Battery is fine.
Where do I start?
[TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here.
Renting out motorbikes in Toscana, Italy
Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index.
IBA: 33616
tagesk is offline   Reply With Quote
Old 11-13-2010, 07:58 AM   #2
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,164
Check the wiring to the ignition switch and maybe spray some water repelling stuff into the switch. Take a look at the connector to the wiring harness.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 11-13-2010, 08:08 AM   #3
dlcool
Are we lost yet?
dlcool's Avatar
Oddometer: 69
Non Starting 2000 GS
What did you do to determine the battery is ok?
If you haven't done the obvious:
Check your kill switch.
Check the side stand switch.
Pull spark pug covers, remove wires and blow out excess water.
dcool
dlcool is offline   Reply With Quote
Old 11-13-2010, 08:16 AM   #4
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,414
Where do I start?
[TaSK]
Nice bombolone or a cornetto or bomboloni con la crema and a hot caffelatte.
def is offline   Reply With Quote
Old 11-13-2010, 08:19 AM   #5
4wheeldog
4wheeldog's Avatar
Oddometer: 13,644
Just for drill, check BOTH ends of both battery cables for tightness/corrosion. Also, check your fuses. Then start wiggling the wiring harness (With the key on) around the steering head. And try operating the sidestand and clutch switches with the key on. If all else fails, try swapping around the relays under the seat......It could possibly be the load shed relay is full of water.
That is all I got, from a distance.
Sometimes a man has got to do what a woman wouldn't even consider.
4wheeldog is offline   Reply With Quote
Old 11-13-2010, 08:46 AM   #6
rcrampton
Oddometer: 208
First thing I'd do it let it sit in the sun or somewhere it can dry out real good and see if it works then.
If I wanted to start troubleshooting I'd trace power and ground to something that should work, like the horn, headlight, tail light, or whatever. If everything on the bike is dead then tracing any of them should lead to your problem.
Here's a link to the wiring diagrams:
http://www.bmwgsclub.nl/schematics/R...0schematic.pdf
I've never read through the diagrams so I don't actually know how it's hooked up, but if everything is dead then I'd do something like trace 12V to the ignition switch and out to the relay K9120 then to the horn fuse.
And of course a ground connection can be the culprit just as much as a +12V connection.
2004 R1150GS
2001 KR650L
2009 CRF250X
1965 Shelby Cobra (home built)
Factory Five GTM
rcrampton is offline   Reply With Quote
Old 11-13-2010, 08:50 AM   #7
NEVERLOST
NEVERLOST's Avatar
Oddometer: 949
there are worse places to be stranded.... tuscany!
NEVERLOST is offline   Reply With Quote
Old 11-13-2010, 08:58 AM   #8
John Smallberries
John Smallberries's Avatar
Oddometer: 1,301
De-ox-it
A liberal spraying of all connectors you can find with Deoxit may be a good idea.
'05 BMW 1200GS '09 Honda CRF230 '10 Yamaha TW200 '07 KTM 400 XCW/EXC '15 Jialing 150 GY2
John Smallberries is offline   Reply With Quote
Old 11-13-2010, 09:02 AM   #9
rtortore
'00 R1150GS
rtortore's Avatar
Oddometer: 463
Water in fuse box
The only thing that is really 'different' from your normal rides is likely the water ... so that is where I would start - "What could water do to kill the electrical system?" :
I too have a 2000 1150GS. With time I noticed that the "clamps" that hold the fuse box lid down tend to become worn and not really work too well.
When I ride without the pillion seat on and use just the tool cover I found (after riding for a few weeks in really bad BC rain) that there was a small amount of water in the fusebox. Perhaps you have enough in there to short out the fuses and thus kill the system.
Of course the basic checks are in order:
sidestand kill switch
water in ignotion system (WD40 in a pinch works well to get rid of this crap)
Good luck, and worst case, just off the bike a little Campari - make it nice and hungry for a ride!
Good luck!!
Richard
"From the point of ignition
To the final drive
The point of the journey is not to arrive
Anything can happen."
rtortore is offline   Reply With Quote
Old 11-13-2010, 10:19 AM   #10
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,533
Did you check the GSpot FAQ? The guy who runs that does a really good job.
A bad ground has stumped many good mechanics.
scooteraug02 is offline   Reply With Quote
Old 11-13-2010, 11:21 AM   #11
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,228
Thumb
In local parlance: Vorrei una svoglia con ricotta, ben riscaldata, e' un capuccino.
Per favore.
I had that. It didn't work.
I told him (the bike): I warn you. The '08 model Adventure, with ABS but without servo, is now only about
10.000 euro at moto.it.
That didn't work either.
It's been sitting dry all day, with no go.
The battery has 12V over the poles, and a bulb shines nicely on it.
That should be enough to turn the RID on.
I'll start at the ignition switch tomorrow and work my way.
I'll keep you posted as I start to take things apart.
Thank you. Thankfully: The next vacation on the bike is several month away.
[TaSK]
IBA: 33616
Old 11-13-2010, 11:50 AM   #12
(none)
poser
(none)'s Avatar
Oddometer: 2,624
RID won't come on if the bike is in gear with the sidestand down. Do you not get a battery and oil light when you turn the key on?
Current:
R1150GS
GN400
LC80
JK Rubi
(none) is offline   Reply With Quote
Old 11-13-2010, 12:11 PM   #13
PacWestGS
Life Is The Adventure!
PacWestGS's Avatar
Oddometer: 10,866
Where do I start?
[TaSK]
Start in a couple of days!
You'll just get frustrated in the mean time.
Water in some connection under the tank. I'd start there with the main wiring harness.
Russ
The world is a dangerous place to live, not because of the people who are evil, but because of the people who don't do anything about it. (Albert Einstein)
PacWestGS is offline   Reply With Quote
Old 11-13-2010, 12:18 PM   #14
booger1
booger1's Avatar
Oddometer: 907
battery can still be bad, if you have dead cell it will still show 12 volts but may not turn the thing over.
Maybe try a jump start.
Eating_goat_with_the_Cartel , Never_ventured_never_gained
oncostaricantime , boundlessbooger , 1998xr400buildwithe-start
Good judgment comes from experience. Experience comes from bad judgment - Mark_Twain
booger1 is offline   Reply With Quote
Old 11-13-2010, 12:26 PM   #15
GS Addict
Pepperfool
GS Addict's Avatar
Oddometer: 4,124
First things first.
Attach voltmeter right across battery.
Turn on Ignition....what voltage do you read?
Old enough to know better....
Young enough to try it again
GS Addict is offline   Reply With Quote
Times are GMT -7.   It's 12:15 AM.
