03-05-2011, 12:48 AM
#16 | |
Oddometer: 344
But then the price. That stuff is pretty expensive, and both sheets and welding wire are subjected to minimum quantities. I think I will stick with HDPE. Make it a little thicker at the wheel side for damage resistance, and it should be very durable. |
03-05-2011, 11:54 PM
#17 |
Oddometer: 344
Shot a photo of the bike yesterday:
![]() Those blinkers on the hand guards are pretty ugly. It seemed like a good idea but once on the bike it looks like shit. New blinkers are in the making... |
03-06-2011, 07:46 AM
#18 |
Oddometer: 1,491
There's some really bright LEDs out there now. I think a row of yellow LEDs could be hidden quite well in a hand guard. Yes - I've been thinking of doing the same thing...
03-06-2011, 09:27 PM
#20 | |
Oddometer: 1,491
I hope you keep this thread updated - it's much easier to read than the other one.
03-07-2011, 12:55 AM
#21 | |
Oddometer: 344
Fortunately pictures often say more than a thousand words |
03-08-2011, 03:48 AM
#22 |
Oddometer: 344
Blinkers mounted on the handguards:
![]() They produce an insane amount of light. I have already reduced the LED-current to 200mA, and now it's OK when viewed in full sunlight, but at night it's still a bit much. Oh well, just another 'get out of my way' sign to the cagers |
03-15-2011, 06:29 AM
#23 |
Oddometer: 344
Slight progress.
I had a not-so-minor setback which I found out after searching for the reason why the bottom of the engine became wet: a crack in the engine casing. I didn't find it until I blasted a suspected spot with some dry sand. ![]() Probably caused by the bike slipping off the bike stand and falling down on concrete hard a few weeks ago, combined with a waaaaay too high tightening torque (35Nm) for that M10 bolt I put through the cases. Both were very stupid things to do, but oh well, I'm the kind of guy that only seems to learn the hard way. I fixed it with some 2-part polyurethane glue. Seems to hold. Needless to say: the steel frame beneath the engine was pretty deformed too. So I made a new one, this time out of 20x20x2mm square stock and with a slightly better design. Should be many times stiffer and stronger (and heavier..) than the steel strips I had before, and hopefully move some of the stress to the frame instead of the engine casings. ![]() On the bikes' left side one of the bars is removeable. This allows me to use the space between skidplate and engine for the battery, tools, spares, etc. Of course the side flap of the skid plate will be removeable too to access this space. ![]() One evening of work in the HDPE skidplate-to-be: ![]() Test mount, right side: ![]() Test mount, left side: ![]() More metal is not necessary. A few extra pieces of plastic welded to the bottom plate together with the tool compartments will give more than enough strength and rigidity. And yep, that's a lot of space between skidplate and engine. Storing tire levers, two spare tubes, basic toolset, etc. there should be possible. This skid plate is light enough to float on water, and extremely slippery. Ground clearance is some 23cm / 9". Enough for a light offroad bike. |
03-18-2011, 08:16 AM
#24 |
Oddometer: 344
![]() ![]() Not totally happy. It sticks out forward too much, and I don't like the gaping holes between engine and skidplate. Oh well, I knew in advance that 'design' is not one of my most developed capabilities. Since it's only about $10 worth of plastic I'll probably build another one which is a tad shorter and with the side wings also curving upwards so it matches the engine and frame tube form a bit better. But I can do that when waiting for parts or so; for now being able to lift the bike again is sufficient. The new internals for the fork legs have arrived :) Something I am totally happy with though, is the strength and toughness of the skidplate. No problem to lift the bike at a point outside the metal frame, and hitting it with a hammer only dents it slightly. Weight is similar to the same construction made out of thin 2.5mm/0.1" aluminium sheet. Didn't weight it, but it's a lot lighter than the skidplate on the LC4Adv. |
03-18-2011, 09:04 AM
#25 |
lizards,bugs and me
Oddometer: 525
skid plate
Innovative construction method, and good execution .
Regards,Ed |
03-19-2011, 08:01 AM
#26 |
Oddometer: 1,023
Looks great to me. Never really thought about a plastic skid plate, guess it would certainly do the job!
I'd like to keep an eye on your plastic welding skills, especially how you construct your tank. I've seriously been considering adding that skillset to my repertoire as it's very handy for a variety of projects. You've done good work so far for learning it on your own (and with a homemade rig). Great looking bike though, can't wait to see it in action!
Sarah 2012 R1200GS Rallye - Gypsy 2003 R1150GSA with DMC sidecar Ask A Self-Publisher "Don't be careful, be awesome." - Cornfed |
03-19-2011, 01:47 PM
#27 | |
Oddometer: 4,754
2009 DL650A, 2008 Tiger 1050 ABS, 1994 XR100R |
02-16-2013, 06:38 AM
#28 |
Skin Donor
Oddometer: 8
Been a while...
What ever became of this build? I'm into the "adv" conversion of bikes and love to see the ingenuity. And a plastic tank?
Security is mostly a superstition. It does not exist in nature, nor do the children of men as a whole experience it. Avoiding danger is no safer in the long run than outright exposure. Life is a daring adventure or nothing at all. -Helen Adams Keller |
02-16-2013, 10:52 AM
#29 |
Oddometer: 344
Oh, many things happened. Only not that many past year; I had to exercise with carbon fiber and build things for the LC8.
This is the current status: .A lot of effort went into the DR-Z forks/triples. Mounting the biger forks with the more massive triples meant the radiator was in the way, and since this is a budget build, I decided to chop up $15 worth of aluminium heater cores and make bike radiators out of them: ![]() Cramming 8 hoses where there were two before tool some effort and included special distribution pieces: ![]() Of course, also many small things changed, such as PivotPegs ![]() Test ride ![]() And so on. In the mean time I processed about 10kg epoxy and various fiber in small things, and I feel confident enough to make a tank to replace the entire subframe. This will start when the temperatures go up again; it's too cold for composite work right now. |
03-23-2013, 02:36 PM
#30 |
Oddometer: 17
Updates!!!!!!
How is the build going?!?!?!? I am very interested in doing exactly what you have done to your sv. I can't wait to see how the tank turns out. Keep up the awesome work.
![]() Aaron |
