Old 11-04-2010, 06:07 AM   #1
genka OP
SUV hater
genka's Avatar
Oddometer: 1,631
Cheap fog lights from China
Anyone tried them?
http://cgi.ebay.com/ebaymotors/BMW-R...item35ab001de4
genka is offline   Reply With Quote
Old 11-04-2010, 07:26 AM   #2
(none)
poser
(none)'s Avatar
Oddometer: 2,626
$100 ain't cheap enough
Current:
R1150GS
GN400
LC80
JK Rubi
(none) is offline   Reply With Quote
Old 11-04-2010, 08:56 AM   #3
genka OP
SUV hater
genka's Avatar
Oddometer: 1,631
If they were even cheaper, I'd post in Penny Tech thread Do you know about even cheaper alternatives?
Old 11-04-2010, 09:21 AM   #4
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,740
http://www.calsci.com/motorcycleinfo/DrivingLights.html
I have got a $17 pair from advanced auto on mine, a H3 55watt bulb in each ( common, cheap, and easy to replace)
they are very bright, and simple to mount.
Smoke em if you got em, and drink your glasses to the bottom...-Will Whitmore
Charter member: T.O. club.
mouthfulloflake is offline   Reply With Quote
Old 11-04-2010, 10:19 AM   #5
maalstroom
Ferret Legger
maalstroom's Avatar
Oddometer: 458
Hella Micro DE
http://www.summitracing.com/parts/HLA-H12090041
Get the real thing for about the same price.
My gears grind more and more each day.
maalstroom is offline   Reply With Quote
Old 11-04-2010, 11:06 AM   #6
Desert Skies
One brick shy...
Desert Skies's Avatar
Oddometer: 2,409
Went cheap here too. Bought some replacement lights from Tulsa Enterprise that fit a Goldwing $15 each whit H3s. Got two wide beam yellows down low for fog and two focused driving lights up high.
“Sorry I'm late, feck'n off takes a lot of time.”
" The 'Wing is my wife's bike - I'm just the feck'n driver." - USMCG_Spyder
" This post is full of VonBadenisms." - Gordy
Tripn' with Tom Some pictures ZZ Rider - Tom Lowry Texas Blue - Tom Lowry
Desert Skies is offline   Reply With Quote
Old 11-04-2010, 11:15 AM   #7
Irish John
Oddometer: 234
Could one of you provide a tutorial on how you wired your lights into the bikes wiring harness, where you put the switch and what did you use for mounting brackets.
Irish John is offline   Reply With Quote
Old 11-04-2010, 11:58 AM   #8
Desert Skies
One brick shy...
Oddometer: 2,409
Here is what I did for my dual (hi/lo beam) setup. I used interposure relays to keep the load off the CANBus sensing circuit.
I tapped into the bikes power by picking it up at the light bucket. Small black wire is the low beam connection to the power relay. Red goes to the High Beam for the hi/lo switch relay. I made the connection by crimping on a biforcated lug and slid it in the OEM connector. No wire cutting necessary.
Here is a single light setup.
As for mounting, either buy or fab up a light bar.
Old 11-04-2010, 12:04 PM   #9
SR1
Back in S. Korea
SR1's Avatar
Oddometer: 4,463
1, "Cheap" usually doesn't just apply to the price.
2, They're from China. Ahem.
My TAT trip in 2014: http://advrider.com/forums/showthread.php?t=998193
SR1 is offline   Reply With Quote
Old 11-05-2010, 10:26 AM   #10
Charleetho
Mr. Zoom Zoom
Charleetho's Avatar
Oddometer: 2,050
IIRC some PIAAs are made in China.
Years ago I had some driving lights from Harbor Freight. A friend had some identical looking PIAA lights. Short of the PIAA etched into the lens they looked and performed the same. Mine has a large white sticker that said "made in china" The PIAA "Made in China" sticker was much more discreet.
They may have been made in the same factory. Who knows.
Charlie Thompson
Littleton, CO Learn to ride Mile High Harley-Davidson Riding Academy
Charleetho is offline   Reply With Quote
Old 11-05-2010, 03:16 PM   #11
wjherrick
Oddometer: 1,285
Harbor Freight - $15.00 (came w/ stitch and mounting hardware)/ $34.00 with mounting bracket and all wiring. I have 10,000 miles on them over some pretty rough country. Standard H-3 (I think) 55wt bulb. I just replaced the originals.
Bill in OR
Remember...a fertile mind can be an incredibly dangerous thing when mixed with alcohol!
wjherrick is offline   Reply With Quote
Old 11-06-2010, 02:27 PM   #12
Speedo66
Transient
Oddometer: 6,858
I have been disappointed too many times by items from China, it just isn't going to happen again.
The horrible part is they so under price quality items that the quality items are disappearing from the marketplace.
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 11-07-2010, 07:23 AM   #13
74C5
74C5's Avatar
Oddometer: 998
I have the Hella DEs. The ones for sale on ebay look more like a driving light than fog. They don't have any device in the lens for making the pattern wide. While using probably the best approach for a lamp i.e. projector, looks like a driving lamp instead.
I see this from time to time. Fog lamp with exposed bulb, instead of shielded and no fluting on the lens. Then, to top it off, seems like no one ever shows patterns and cutoff anymore on their packaging like Cibie and Hella years ago.
R1200RT (R1100RT gone)
KLR650 - gone
Don't be the guy who needs to pee on the fence to figure out that it's electrified.
74C5 is offline   Reply With Quote
Old 11-08-2010, 08:54 AM   #14
genka OP
SUV hater
genka's Avatar
Oddometer: 1,631
Quality of cheap Chinese goods vary wildly. I've bought some junk from Meritline which went right into trash. But I boght a nice thick stainless stink kitchen sink for probably 15% of the cost of the brand name one, and it is still as good as new 3 years later.
The lights on ebay have projector lenses. With them you can't tell the distribution pattern just by looking.
While on the subject, any advice on inexpensive mounting options for 1200GS? I remember seeing nice small brackets which use the turn signal mounting points.
Old 11-08-2010, 09:14 AM   #15
thetable
thetable's Avatar
Oddometer: 1,462
Quality on the eBay lights looks very suspect. I wouldn't run those without redoing the wiring going into the light. If you can find a better looking light to photograph, then you have to wonder what the bad ones look like.
thetable is offline   Reply With Quote
Times are GMT -7.   It's 03:41 AM.
