Old 11-17-2010, 08:19 PM   #1
grinns OP
Semper Fi
grinns's Avatar
Oddometer: 1,323
4-5k hesitation
The bike has had a 4-5k hesitation off and on riding back from houston, but now it has it perminently.
Here is what I have done so far:
valves adjusted
sas removed
new airfilter/prefilter
new fuel filter
new 02 sensors (one was bad found with tuneECU)
reloaded newer stock map and reset settings + 15 minute idle
What I plan to do:
tps sensor adjustment (is this possible?)
balance throttle bodies (they measure off a little in tuneECU)
Right now after new o2 sensors and reset its running amazing, but the hesitation is still there. It feels like the injectors shut off because it thinks the throttle is closed.
SUMMARY AND FIX IS ON PAGE 3
2012 300 EC Race
2010 690 R
2014 hypermotard sp
grinns screwed with this post 12-11-2010 at 01:37 PM
grinns is offline   Reply With Quote
Old 11-17-2010, 11:33 PM   #2
Nut Clutch
was Steve Lavigne
Nut Clutch's Avatar
Oddometer: 429
Two things I would recommend for that:
1. Disable the EPC either by removing the pins in the harness for the gear position sensor, or disable it in the map.
2. Remove the secondary throttle plates in the throttle bodies.
You will see the largest difference by removing the secondary throttle plates. You also could change the mapping for the secondary throttle in TuneECU.
'07 KTM 990 Adventure Long Road to Dug Bar
Nut Clutch is offline   Reply With Quote
Old 11-18-2010, 01:15 AM   #3
Spark01
V-Twin
Spark01's Avatar
Oddometer: 304
valves adjusted
sas removed
new fuel filter
What I plan to do:
Yes you can adjust the TPS
the voltage should be rond 0.6-0.7V when closed en 3.6V when fully opend. it's in the manual
but you should do this after you balanced the throttle bodies.
Maybe also check if there isn't any thing loose on the throttle bodies
'10 990SMT
Spark01 is offline   Reply With Quote
Old 11-18-2010, 02:59 AM   #4
wee tee cee
Oddometer: 170
Try removing the secondary butterflies,I had a similar lag at that rev range which this resolved.
wee tee cee is offline   Reply With Quote
Old 11-27-2010, 06:59 PM   #5
grinns OP
Semper Fi
grinns's Avatar
Oddometer: 1,323
After doing some more reading when its doing this hesitation it should be using the map based on the Map sensor (L table). It shouldn't switch unless its above 67% tp at this rpm range according to my stock map.
I looked at the secondary positions and it starts changing a little more rapidly at this rpm.
My next test would be to datalog or view this info when the hesitation happens.
If anyone knows anything interesting as this is the first time I am diving all the way in fuel injection please yell.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Old 11-27-2010, 07:25 PM   #6
grinns OP
Semper Fi
grinns's Avatar
Oddometer: 1,323
Throttle boddies are like 70 hPa different at idle. Need to find out that issue. The sensors are only off by 1 when bike is not running.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Old 11-27-2010, 07:34 PM   #7
grinns OP
Semper Fi
grinns's Avatar
Oddometer: 1,323
It's around 50-70 hPa off all rpms while running. Doing some more thinking...
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Old 11-27-2010, 07:36 PM   #8
grinns OP
Semper Fi
grinns's Avatar
Oddometer: 1,323
I am going to swap the sensors and see if it follows.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Old 11-27-2010, 09:00 PM   #9
grinns OP
Semper Fi
grinns's Avatar
Oddometer: 1,323
Didn't follow, so I synced the throttle bodies. They indicate the same now, but idle went up and you can see the TPS is off now.
Tps adjustment to follow after I make an allen key a little shorter and bent.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Old 11-27-2010, 09:14 PM   #10
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,193
cyborg is offline   Reply With Quote
Old 11-27-2010, 09:50 PM   #11
cyborg
cyborg's Avatar
Oddometer: 5,193
If you have Tubeboy or TuneECU you can program the secondary butterflies to be open all the time without having to remove them. Very handy to be able to go back and forth quickly to figure out if it really helps or not.
Old 11-28-2010, 01:16 AM   #12
Dusty
Dusty's Avatar
Oddometer: 1,287
Don't forget to take some snapshots for us NooB's..
edit: found some pics on the duke site.
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty screwed with this post 11-28-2010 at 11:03 AM
Dusty is offline   Reply With Quote
Old 11-28-2010, 01:27 AM   #13
Dusty
Dusty's Avatar
Oddometer: 1,287
add content
Is this something that needs looking at... Linky
Old 11-28-2010, 10:08 AM   #14
grinns OP
Semper Fi
grinns's Avatar
Oddometer: 1,323
Thats pretty cool, but this is more like what I want. I would need to tune more bikes than just my own to make it worth it :).http://www.innovatemotorsports.com/x...cat=273&page=1
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Old 11-28-2010, 10:17 AM   #15
grinns OP
Semper Fi
grinns's Avatar
Oddometer: 1,323
http://compare.ebay.com/like/1805842...=263602_304662
and anouther 9k for a dyno! Thats a lot more bikes!
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Times are GMT -7.   It's 08:27 AM.
