Old 11-28-2010, 09:35 AM   #16
grinns OP
Semper Fi
grinns's Avatar
Oddometer: 1,327
Quote from Tahoeacr:
http://www.advrider.com/forums/showt...=402142&page=2
Not needed unless you screw it up. There should be a little play in the throttle grip at idle. Left or right. If you take the play out, the throttle valves can sit a little off of fully closed throwing off the tps.
To adjust the tps the dealer tool is not needed. You must make sure that the idle control motor is not effecting the throttle valves. At idle, with a warm engine you should get approx .6 volts from the signal wire. Full throttle engine off ignition on should be approx 3.8 volts.
Black is ground
Blue is 5 volt supply
Yellow/White is signal cable
2nd tps should be approx. 1.0 volt at closed and approx 4.3 volt at full throttle with engine off ignition on.
Black is ground
Green/Red is signal
Almost forgot, the tps's are held on with one screw. The tps case is slotted so you can move it while reading your volt meter.
If there out of range the ecu goes in to a Emergency operation program. Still rideable.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
grinns is offline   Reply With Quote
Old 11-28-2010, 03:17 PM   #17
grinns OP
Semper Fi
grinns's Avatar
Oddometer: 1,327
I think this may be my problem, because I synced the throttle bodies and it was pretty far off. The TPS was close so I went for a ride and gdam was it smooth. You could feel the transition to tps sensors, from map sensors, but it was minor. My problem was where the engine felt like it was stalling.
Adjusting tps to spec and going for anouther ride after I reset tps.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Old 11-28-2010, 04:55 PM   #18
Dusty
Dusty's Avatar
Oddometer: 1,297
Thumb
Right on!
Sounds like a productive Sunday.
My answering machine only got part of your message.
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty is offline   Reply With Quote
Old 11-28-2010, 05:04 PM   #19
grinns OP
Semper Fi
grinns's Avatar
Oddometer: 1,327
Originally Posted by Dusty
Right on!
Ah, I am waiting for it to cool down. Probably post more after 8pm. I had to make a special wrench.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Old 11-28-2010, 08:13 PM   #20
grinns OP
Semper Fi
grinns's Avatar
Oddometer: 1,327
I was getting .57 when it was warm. Still in tolerance, but the stall came back. I am going to turn it up a little bit so its at .60-.63. Before fusing with it it was .60 after throttle balance it was .67 when I test road it.
What I think is happening is the rpms get to 5k ish where if the throttle is 0 the fuel injection is cut off. The sensors think its really close to zero because I am slowly creaping up and cutting off the fuel injectors, even though I am excelerating slowly.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Old 11-28-2010, 09:36 PM   #21
grinns OP
Semper Fi
grinns's Avatar
Oddometer: 1,327
I still think it thinks its at 0 throttle. I have it adjusted to .63 volts warm, which is still in tolerance. It is better, but it still feels like it stalls. Step two I think is tape my tablet pc to the handlebars and go find a remote road.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Old 11-29-2010, 08:57 AM   #22
Spark01
V-Twin
Spark01's Avatar
Oddometer: 304
TPS sensor
If you very slowly turn the throttle, how does the voltage of the TPS change?.
Does it change smooth or does it move jumpy?.
Because it could be possible that the sensor has a bad spot some where?.
'10 990SMT
Spark01 is offline   Reply With Quote
Old 11-29-2010, 07:07 PM   #23
grinns OP
Semper Fi
grinns's Avatar
Oddometer: 1,327
It is totally smooth. When accelerating I don't really move the throttle at all. I think tonight I am going to make a map with the secondary open all the time. Just to rule this out.
Then I am going to check the ignition switch.
My tablet is all set and ready to go for a ride, but it is raining out.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Old 11-29-2010, 09:54 PM   #24
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,204
Go Grins Go!
cyborg is offline   Reply With Quote
Old 11-30-2010, 01:00 AM   #25
Dusty
Dusty's Avatar
Oddometer: 1,297
I tried this test with TuneECU today on my bike and you can watch the volts move with the throttle, it updates the readings pretty quick.
As for adjusting the TPS, are you fukin kidding me, i could hardly see it with a flashlight.
Are you guys doing this with the airbox on? Sure seems like it would make it a lot easier to get it spot on without it.
Mike, how close did you get the TBs .
Old 11-30-2010, 07:33 AM   #26
grinns OP
Semper Fi
grinns's Avatar
Oddometer: 1,327
I made my own tool and I have mad finger coordination skills! Airbox on!
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Old 12-04-2010, 05:19 PM   #27
grinns OP
Semper Fi
grinns's Avatar
Oddometer: 1,327
Noticed the vaccum from the sensors flucuates more to the second cylinder at the stall point. I wonder if it has a bad map sensor. Going to switch them and see if it follows.
Also turning off the secondaries.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Old 12-04-2010, 05:33 PM   #28
Venteuri
I don't give a shit
Venteuri's Avatar
Oddometer: 15,352
Cheek out no hose is pinched or blocked when you reassembly everything.
BMW R1200GSA 2014
Member #68,893
Above all stop pandering to posts from morons like Venteuri who can't even spell Venturi properly.
Venteuri is offline   Reply With Quote
Old 12-04-2010, 05:35 PM   #29
grinns OP
Semper Fi
grinns's Avatar
Oddometer: 1,327
Will do when i swap them. It started doing this out of the blue after running well.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Old 12-04-2010, 08:57 PM   #30
grinns OP
Semper Fi
grinns's Avatar
Oddometer: 1,327
Didn't matter with secondaries open, I changed the map to have them open all the time.
tomorrow I am going to swap the sensors and check the hoses.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Times are GMT -7.   It's 11:55 AM.
