Old 12-10-2010, 11:33 PM   #31
grinns OP
Semper Fi
grinns's Avatar
Oddometer: 1,327
I figured out the problem. I will post pics tomorrow!
2012 300 EC Race
2010 690 R
2014 hypermotard sp
grinns is offline   Reply With Quote
Old 12-11-2010, 12:36 PM   #32
grinns OP
Semper Fi
grinns's Avatar
Oddometer: 1,327
Ok, Here is my summary
Done:
valves adjusted
sas removed
new airfilter/prefilter
new fuel filter
new 02 sensors (one was bad found with tuneECU)
tps sensor adjusted
throttle bodies balanced (used real tool, not off tuneECU)
throttle cables adjusted
throttle bodies, map sensor fittings cleaned
new map sensor hoses
Here is what I found as the problem:
This kind of clued me off, since this was on the cylinder that had wierd map readings. At first I thought it was sealant, but look at the next picture...
Rear one that was semi still working...
I guess it sat to long, it had 3k when I bought it 07 in september 2010. This is my best guess as the bike literally looks like brand new. All that gunk was interfering with the map sensor holes. This is one reason it was acually running a bit rich.
Then I did a little cleaning. I pulled off the map sensor hoses and replaced them. Cleaned out the brass niples and resealed the threads and put it all back together.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Old 12-16-2010, 08:15 PM   #33
catalina38
Contrarian
Oddometer: 1,645
any updates?
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 is offline   Reply With Quote
Old 12-16-2010, 09:14 PM   #34
grinns OP
Semper Fi
grinns's Avatar
Oddometer: 1,327
Originally Posted by catalina38 View Post
any updates?
It's running great now. I have 0 flat spots. I only have the lower rpm normal ktm stuff. Working on that, but if I change anything it will be on the tuneecu thread.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Old 09-24-2013, 05:42 AM   #35
mschviuz
mschviuz's Avatar
Oddometer: 100
Done:
valves adjusted
sas removed
new fuel filter
tps sensor adjusted
Could someone please tell me where the map sensor hoses attach..in other words where did you find that crud? ^^^thanks
____________________
2007 KTM 990 Adventure
mschviuz screwed with this post 09-24-2013 at 05:49 AM
mschviuz is offline   Reply With Quote
Old 09-24-2013, 07:48 AM   #36
renogeorge
Oddometer: 1,396
Below the throttle bodies, in the manifolds--front cyl on right side, rear on left. Don't confuse the MAP sensor lines with the SAS if that system is on the bike.
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 09-24-2013, 07:50 AM   #37
mschviuz
mschviuz's Avatar
Oddometer: 100
Old 09-28-2013, 07:44 PM   #38
mschviuz
mschviuz's Avatar
Oddometer: 100
Mine looked just like those pics ^ I pulled everything down and cleaned it up. Only got to ride a little afterwards but so far so good. Thanks for the info....
Old 09-28-2013, 08:07 PM   #39
grinns OP
Semper Fi
grinns's Avatar
Oddometer: 1,327
NP! I still have my 990 it has about 30k now and still runs great! I run startron when i have to use ethenol, but I currently live by a non ethanol station.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Old 09-29-2013, 06:25 AM   #40
mschviuz
mschviuz's Avatar
Oddometer: 100
Gotta love ethanol. Money maker for small engine repair shops and gives me something to do like this all day job I just wish it was time to do the valves .....I was right there yesterday. Oh well, when it's time to inspect the valves I will know how to break it down.
Times are GMT -7.   It's 01:35 AM.
