Old 11-18-2010, 01:48 PM   #1
Craig in Alabama OP
Craig in Alabama's Avatar
Oddometer: 33
One rich carb on my airhead
Hi Folks,
I have an '84 R100RS that I rescued about a year ago. I've been remedying the neglect, abuse and lack of maintenance ever since. I'm really close to getting everything sorted out, but a new problem has cropped up. I promise I've searched diligently, but I didn't find an answer.
The bike has been running fine, although not as smooth as I think it should. When I checked the valve clearance recently (it had been 2,000 miles) I was surprised to see the right side plug was very black and sooty. The valves were right in spec so i didn't mess with them. This plug was previously just fine, and I don't know when it began to run rich. Gas mileage has always been poor (about 35 mpg).
I have replaced all the o-rings in the carbs and cleaned them up. Carb diaphragms are good. Plugs and coils are good. It's just one side so I think it's the carb and not timing.
The most interesting thing is that in order to get the right side to run, I have to turn the mixture screw all the way in or it bogs down. That's full lean, right?
Could it be that my float level is too high? I checked it and it looked to me that if anything it would be too low, but I could be wrong. I thought perhaps I had assembled the choke incorrectly, but the little kidney shaped hole is at the top where it should be. Besides that, I did the carbs about 1,000 miles ago. Is there anything else in the choke assembly that I should look at? It really seems like a choke problem to me.
So any idea what could affect it so bad at idle? I've been messing around with it for about a week and not gotten anywhere. I thought it best to ask the collective masses.
Any ideas?
Craig
Craig in Alabama is offline   Reply With Quote
Old 11-18-2010, 04:18 PM   #2
bikecat
bikecat's Avatar
Oddometer: 1,119
Timing and valves clearances must be alright before diving into carbs .... that's what I learnt.
Cheers
bikecat is offline   Reply With Quote
Old 11-18-2010, 04:37 PM   #3
Gravytrain
house husband
Gravytrain's Avatar
Oddometer: 207
Craig
I would think mixture screw all the way in = full rich
If you reject the food, ignore the customs, fear the religion and avoid the people, you might better stay home. ~James Michener
Gravytrain is offline   Reply With Quote
Old 11-18-2010, 04:39 PM   #4
durtwurm
Talented Amateur
durtwurm's Avatar
Oddometer: 4,419
Hi Folks,
Any ideas?
Craig
I would check the tension adjustment where the choke cable attaches to the carb. Each side must be the same. Also the nut that maintains tension at carb can loosen and cause all sorts of problems.
Go far or stay home.
durtwurm is offline   Reply With Quote
Old 11-18-2010, 05:23 PM   #5
rufusswan
rufusswan's Avatar
Oddometer: 962
Sometimes plugs, wires, and coils, etc. fail dude. I wouldn't hesitate to either swap plugs or replace the fouled one, or swap plug leads. Then you can start your diagnosis of the real issue by starting with the symptom.
1971 BMW R75/5 Toaster LWB
1974 Honda CL200
http://zenhuckfinn.wordpress.com/
rufusswan is offline   Reply With Quote
Old 11-18-2010, 06:13 PM   #6
Craig in Alabama OP
Oddometer: 33
Hi Folks,
Thanks for the replies. The valves and timing are fine. I've checked the coils and they measure fine. The spark plug wires are new NGKs and I put in new plugs when I checked the valve adjustment a couple weeks ago. They were also black and fuzzy after a ~50 mile ride. Bike seemed to run pretty good, though.
I swapped the coils over as well, but that didn't change anything.
All the cables are new and I checked to be sure the choke wasn't hanging up. I still think it must be choke related though.
As for the mixture screw, I thought screwed all the way in was full lean as it's not allowing any fuel to pass. Is that not correct? This is why I think it must be either the choke or the float bowl level.
Thanks,
Craig
Old 11-18-2010, 06:28 PM   #7
fishkens
Further...
Oddometer: 5,149
Thanks,
Craig
You are correct:
"Turning in a clockwise direction results in a leaner mixture and turning in an anti-clockwise direction in a richer mixture. (Note: this is just the opposite of the direction required in Bing slide carb mixture settings)."
page 8 Bing carb manual
Forging ahead, down a false trail.
fishkens is offline   Reply With Quote
Old 11-18-2010, 10:43 PM   #8
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,013
The idle and low-speed mixture is set by the idle fuel jet and idle air bleed supplying fuel to the idle and bypass openings in the throttle bore. THe idle mixture screw provides fine-tuning of the mixture and should provide a good mixture in the 1 to 1-1/2 turns-out specified. If it has to be turned in all the way something is amiss.
Check the o-ring on idle jet-- if it is deteriorated, more fuel will flow through/around the jet. Check if the jet opening has been enlarged. Look at the throttle plate-- is it aligned with the throttle bore and installed correctly (ie, not upside-down)? Notice the idle and bypass drillings in the throttle bore-- there should be an idle opening (the mixture screw will be in that opening) and the throttle plate should be centered on it at idle. Above it there is another opening, the bypass drilling, which provides fuel for the low-speed (part throttle) mixture; the throttle plate should not pass by it at idle.
Check the float adjustment and double-check it against the fuel level in the float bowl. The fuel level should be the same in each float bowl (I disremember what it is in the later R100); if not, suspect that a float has gotten "waterlogged" with gasoline, is too heavy, and needs to be replaced. Of course, double-check that the enricheners are correctly assembled and adjusted.
'73 R60/5 Toaster
Old 11-19-2010, 05:47 AM   #9
Craig in Alabama OP
Oddometer: 33
Thanks, fishkens. I should have specified that it's a CV carb.
And thanks Bill. I will check the o-ring on the idle jet and the jet itself tonight. I did not disturb the throttle plate and it doesn't look like anyone else has either. It all seems to line up correctly, but I'll check it's position with the idle and bypass openings as well.
The floats "float" and appear to be new versions. In fact I found a pair of old bing floats bobbing around in the fuel tank, but that's another story...
If all this checks out I may block off the choke area as a quick test. It still seems like the culprit even though it appears to be fine.
If these carbs were clear it would be a lot easier to diagnose this stuff!
Thanks for all the help! I'll report back.
Craig
Old 11-19-2010, 06:09 AM   #10
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,552
You mention neglect. I also spent a good long time reviving an airhead that sat for 20+ years and found that the needles and seats in the carbs had corroded considerably and were nowhere near there former size and shape. My bike ran, but only got about 25 mpg. I replaced the needles and seats and boom. Everything was right again. Worth a look if your bike sat for a long time.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 11-19-2010, 06:10 AM   #11
fishkens
Further...
Oddometer: 5,149
PO: "Hmmm, what do I do with these old carb floats? I know, I'll toss them in the gas tank. They'll happily live out their days floating in gas."
Old 11-19-2010, 07:22 AM   #12
mykill
odd
mykill's Avatar
Oddometer: 1,166
I'm on the idle jet oring path as well. It also may not hurt to remove the mixture screw to check for deformity or corrosion at the tip. Blow some carb cleaner through the passage while you are at it.
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 11-19-2010, 07:31 AM   #13
jwegman
Oddometer: 219
I may have missed mention of it, but has the main needle setting been checked to verify that they are in the proper clip position and the same on both carbs?
jwegman is offline   Reply With Quote
Old 11-19-2010, 07:47 AM   #14
Craig in Alabama OP
Oddometer: 33
I didn't mention it, but the needles are at the stock setting. They weren't when I checked them though! The two mixture screws look identical. I swapped them and the problem stayed in the right carb.
This was one of those cases where I'd find something mis-assembled and think "That's it!" and put everything back together. Like the diaphragms (which were new) had been put in with complete disregard for the correct origin. PO: What are these tabs for? Who cares!
It's been an adventure...
Anyway, I didn't replace the needles and seats and other hard parts when I first went through the carbs, but I see now that that was clearly a mistake. Time to place another order.
I just didn't think this over-rich mixture at idle was needle, jet or seat related. But new stuff will take the uncertainty out of the equation and it can't hurt.
I'll probably still mess about with it this weekend, because I'm stubborn and have music and beer in the garage.
Cheers!
Craig
Old 11-19-2010, 08:51 AM   #15
durtwurm
Talented Amateur
durtwurm's Avatar
Oddometer: 4,419
All the above! I recently had similar problems. It turned out that I had a bad China condenser. And defective China points, and no the rubbing block was not too high. Replaced condenser and the points. Set timing. Set valves. Cleaned the carbs and replaced all o rings. My floats and settings were fine. Also checked the wire between the coils and cleaned. (Did you do this?) Cleaned the fuel filters. Replaced plugs. Runs well, very well now. Don't forget your many settings for choke and fuel as mentioned. Also the chokes cables where they attach and the gaskets for same.
Times are GMT -7.   It's 05:43 PM.
