Closed Thread
Old 12-07-2010, 08:28 PM   #166
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Originally Posted by Lobby View Post
I've got an '05 12GS, and while I like the engine much more than the 1150 models I had (smoother and more powerful), there's a bunch I don't like about it.
When I give it gas to accelerate (normally from lower RPM's - say 3500), it sure seems to take a lot to really get going.
Yet when it's about 5000 rpm, now matter which gear it's in, the bike zooms.
I would like this dead spot in the middle of the RPM band to go away.
But, I'd also like to keep my good fuel economy.
These take a good-sized bite out of that dead spot. And of the improvements available from the first two products, 35% is provided by air temp and 65% by oil temp.
There's a difference in fuel use only during Tip-in and Leading Throttle. Steady State will have the same mileage.
Many people's mileage goes down when they get a new pipe, acourse that's attributable to racing around with their new toy. I'd imagine you'd have some of that with these products, especially since the go-pedal feels so much nicer.
p.s.: To flatten the power output across the powerband requires a new program in the ECU. And it's also possible to do it with high end external add-ons or ECUs, but not with something like a Power Commander.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside screwed with this post 12-07-2010 at 08:33 PM
Poolside is offline
Old 12-07-2010, 08:36 PM   #167
Lobby
Viel Spass, Vato!
Lobby's Avatar
Oddometer: 28,681
And you're not doing that?
I assumed from your posts that you were creating new control algorithms using, or re-using, sensor data (air temp, and oil temp) to reprogram the ECU.
Is this not correct?
Lobby is online now
Old 12-07-2010, 09:44 PM   #168
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
How can I say this? We are inputting externally-controlled changes to the ECU, to cause it to operate in different parts of it's internal algorithm. I hope that's not too ambiguous, cause I'm not trying to be.
JJ says something about it in the quote below. I'll explain more about it later if you like, or I can point you to reference material. I'll try and explain it briefly here.
The stock ECU has 'rules' that it follows. These rules go something like, find out where the throttle is at, and the motor RPM, and what the other inputs are, and determine the fuel and spark outputs. That is an algorithm, a set of rules.
Any external change to any input creates differences in the outputs. Some changes are small, others large. Some are desirable, some are not. Some happen when you want then to, others don't. I'm meaning desirable from a drivability point of view.
Replacing the ECU is only necessary if it is. That may sound vague, but causing the ECU to operate in different parts of its algorithm 'rule set' makes a huge difference. If it's done right, it makes all the difference that people want made, and sometimes it exceeds expectations. What I mean by that is, many people do not know what truly excellent throttle response is, so they literally don't know what to expect. They know how one bike compares to another one they've owned, but often they don't have an absolute frame of reference.
With every stock motor I've seen, the stock ECU is capable of proper fueling. Capable of making the motor run as good as it can. To achieve that performance requires the ECU to operate outside the margins say, of its 'rule set'. That is possible to do with outside modification.
Causing the ECU to operate in different parts of 'rule set' can sometimes be a fairly simple process, or it may need to be more complex to work well, or work at all. Our 1st device is fairly simple. The 2nd one is fairly complex with microprocessor control, and it also interacts with the 1st one. That's the way it needs to be given the 'algorithm' in the Motronic ECU. Nothing else would, or could, work.
What you want is the removal of the undesirable aspects. That generally doesn't mean a 'flat power output'. I don't think I can explain here all that's entailed in the phrase "flattening the power output". But I can say you probably wouldn't like it, most people don't.
That undesirable dip in the powerband, it takes a big bite out of that.
Originally Posted by johnjen View Post
This reaches all the way down into the specific functional and mathematical algorithms that are used for the various portions of the EFI ‘states of operation’ themselves. Which means that depending upon in which ‘operational state' the engine is running, certain variables become important and thus/can be/are externally modifiable without having to re-write the algorithm itself. This is a decidedly GOOD thing for all of us because it means we only have to fuss with certain knobs to get the desired effects in a particular state of engine operation.
Poolside screwed with this post 12-08-2010 at 12:04 AM
Poolside is offline
Old 12-08-2010, 06:01 AM   #169
Visian
Look out!
Visian's Avatar
Oddometer: 1,688
With the right amount of transient enrichment the motor just torques away from a stop. It gives the feeling of having more power than it needs. Beautiful.
Have you had the opportunity to ride the 2010s?
This behavior was what most impressed me about the new motor... a very linear and controllable move away from a stop.
It is also more manageable at the bottom when riding across rough ground than previous models.
'67 Trail 90 || '86 R80 G/SPD+ || '97 F650ST || '00 1150 GS || '06 HP2e
Visian is offline
Old 12-08-2010, 11:37 AM   #170
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,714
So, when do we bolt this box of magic onto the pfig and take it up the hill for a spin, jump and slide?
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is offline
Old 12-08-2010, 01:29 PM   #171
barlytreat
FNG
barlytreat's Avatar
Oddometer: 71
Good question.... Whenever all the 8 LB. brains get done working on the issue I guess. Folks went to the moon using a devise called an E6B not too long ago, not a challenge, just a comment. great work gentleman, a little friendly prodding.
barlytreat is offline
Old 12-08-2010, 02:49 PM   #172
Lobby
Viel Spass, Vato!
Lobby's Avatar
Oddometer: 28,681
But the dip in the powerband from 4000 to 5000 rpm is still there. According to the various motorcycle mags I've read.
Lobby is online now
Old 12-08-2010, 02:50 PM   #173
Lobby
Viel Spass, Vato!
Lobby's Avatar
Oddometer: 28,681
I understand what you're saying. In essence you'll be selling some device that hooks up to the ECU that tricks it into performing better. Sorta like a Power Commander.
You're not selling an ECU reprogramming service (software only).
Lobby is online now
Old 12-08-2010, 03:50 PM   #174
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
 E6B!
I have to replace the drive belt in the dryer just now. So, right after that.
Poolside is offline
Old 12-09-2010, 02:18 AM   #175
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
That's it, no software. We're selling both passive and microprocessor-controlled hardware.
These devices hook up to the existing components on the bike, and in that regard it's similar to a Power Commander. But the similarities pretty much end there.
The PC sort of 'takes over' certain operations of the ECU. And it's got a fancy user interface, and programmable maps and such. There's a lot of fussing to get it right, enjoyable fussing I might add. And of course, when you're all done, bragging rights.
I understand that appeals to a lot of people, heck it appeals to me too! But would you believe me if said it wasn't strictly necessary?
The ECU already has the 'right maps' as it were. And what our products do is access them.
Poolside is offline
Old 12-09-2010, 07:14 AM   #176
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,714
Jim, I'm in town for part of the holiday break and a little after.
We can make an HD movie.
Of course this would be WUI*, I'm guessing.
I now have in-house counsel...
*Wrenching Under the Influence
- Thanks to Gaspipe, the Original for that one.
...Dick
Smugmug
Mr Head screwed with this post 12-10-2010 at 05:11 PM
Mr Head is offline
Old 12-09-2010, 01:38 PM   #177
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,414
If I am correct (and I most always am), the actual processor in our Motronics is not addressable leaving you with either replacing the processor with one that is addressable (and authoring and installing maps, a daunting task) or, telling the existing Motronic processor lies in order to get improved performance (drivability) or messing with the FI pulse width signals coming from the Motronic.
It appears that you are going to lie to the Motronic, yes?
def is offline
Old 12-09-2010, 03:36 PM   #178
Rollmo
Rollmo's Avatar
Oddometer: 35
Very much looking forward to these products. My GS could use a smooth throttle response.
I don't doubt that the stock ECU isn't tuned to provide optimum performance. My question is why would BMW not install stock ECU's that tune the engines to perfection from the get-go? Is it laziness? Emissions laws? Cost-cutting? Lack of knowledgeable personnel?
Perhaps this has already been addressed, but I didn't see it after reading/skimming of this thread.
2005 R1200GS
"Comin' up to the overload"
Rollmo is offline
Old 12-09-2010, 03:39 PM   #179
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
I can see it now. "Hi sweetheart, can you come and get your dad and I out of jail?"
Poolside screwed with this post 12-10-2010 at 07:22 PM
Poolside is offline
Old 12-09-2010, 03:51 PM   #180
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
It's probably a little of everything you mentioned. Poor drivability is usually driven by emissions regs. For good drivability to survive the design process costs money and requires qualified people and components. With a loyal customer base, and without any equivalent competition from the big 4, the factory may not have had much motivation.
The ECU already has the 'right maps' as it were. The ones we want are just in a different area. And what our products do is access them.
Poolside screwed with this post 12-09-2010 at 04:06 PM
Poolside is offline
Closed Thread
Times are GMT -7.   It's 06:58 PM.
