Closed Thread
Old 11-19-2011, 06:58 AM   #1846
JRWooden
Oddometer: 4,262
Originally Posted by Poolside View Post
Half the folks that tried an IICE Air thought their bike ran pretty much fine without it. Then they found out what they were missing.
Hey ... that sounds like you're taking over MARKETING'S JOB ...
Seriously, I understand your point, but is what people describe a "snatchy throttle" is really more of a transient throttle response issue?
JRWooden is offline
Old 11-19-2011, 07:04 AM   #1847
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
What, you don't thing Engineering is persuasive! Sure the IICE Cool works on transient throttle, but without the IICE Air to follow up the transient throttle with acceleration enrichment, the response goes flat.
You'll know what I'm talking about if you don't get one. You'll also know what I'm talking about if you do.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline
Old 11-19-2011, 07:16 AM   #1848
Wallowa
Oddometer: 5,453
Check Invoice?
Hey, I checked the invoice and it does indeed clearly say: "Shipped Whenever".
Seriously, ice and snow is in my little corner of heaven, so I am geared for backcountry skiing not riding for several months. If you need to put me at end of list, no problem. As long as I eventually end up with an ICE & Cool I am in no hurry.
"In Wallowas"
2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!" After 2014 BOM my bike is forthwith the "GS McGee"!
Wallowa is offline
Old 11-19-2011, 08:37 AM   #1849
Plane Dr
Plane Dr's Avatar
Oddometer: 866
I'm in
01/09 DRZ470SSW more bits than necesary
2005 R1200 GS AKA The Mothership
2003 Z1000 Nuclear Pumpkin (gone)
86 RG500WW (gone)
Bikes are like women. What you think you want, and what you want, change after the first ride.
Plane Dr is offline
Old 11-21-2011, 12:49 PM   #1850
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Bejesus.... I guess my order is in the next batch. Any idea when that will be? I'm hoping before christmas...
Ride more, bark less
Gangplank is offline
Old 11-21-2011, 01:23 PM   #1851
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
CORRECTED Shipping List
You're in luck, I was just putting this post together. Apparently I made some sort of mistake while working with the master spreadsheet file. In the process of adding the people from the 'Final Sale', I was moving and inserting columns in Excel and some data got misaligned. Anyway, here is the correct list below.
L.K., MI
R.N., CA
C.N., CA
G.B., CA
B.D., WV
D.H., OR
R.L., NM
J.G., NV
B.M., CA
N.S., WI
J.W., TN
A.J., CA
J.K., TX
A.F., TX
D.S., WA
W.B., GA
J.D., NM
J.L., KY
G.H., WI
M.B., VA
J.G., TX
J.K., CA
H.K., PA
S.S., FL
R.W., KY
Poolside is offline
Old 11-21-2011, 01:30 PM   #1852
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
THANK YOU for the recent orders everyone! Many thanks!
Poolside is offline
Old 11-21-2011, 02:29 PM   #1853
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Originally Posted by jrwooden View Post
I think this is the correct thread in which to ask ....
I have read the materials and understand that iice air "tricks" the air temp. Sensor, while iice cool will trick the oil/coolant temp. Sensor and each provide different improvements to engine function.
Q1) i'm wondering first why they both don't provide a "general" improvement rather than segregated....
Is that just the way bmw programmed the ecu, and that while there is some "overlap" that the functions are "mostly" as shown in your chart?
http://www.advrider.com/forums/showp...&postcount=146
Q2) i think you said taht the iice air will give about 1/3 of the total improvement, while the iice cool will give 2/3rds.
Why is that ... More german ecu magic?
thanks!
Q1) It has nothing to do with anything that specifically BMW did. Gasoline-powered vehicle motors require different fuel control algorithms during a motor's various operational modes. In the case of your question, the two operational modes are Leading Throttle and Transient Throttle. The IICE Air works on Leading Throttle, and the IICE Cool works on Transient Throttle.
Q2) When the ECU doesn't get Transient Throttle (aka: Throttle Tip-in) fueling right, it's more noticeable/objectionable than if Leading Throttle isn't right. You could say that those terms are too subjective if you like, but it won't change anything.
Poolside is offline
Old 11-21-2011, 02:49 PM   #1854
frogy
frogy's Avatar
Oddometer: 840
Darn,still not on the list.Oh well I guess I'll have to wait for summertime.I always do a TBS over the winter.So I will ride it for a bit and then put on the new gizmo.
frogy is offline
Old 11-21-2011, 03:32 PM   #1855
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
L.K., MI
R.N., CA
C.N., CA
G.B., CA
B.D., WV
D.H., OR
R.L., NM
J.G., NV
B.M., CA
N.S., WI
J.W., TN
A.J., CA
J.K., TX
A.F., TX
D.S., WA
W.B., GA
J.D., NM
J.L., KY
G.H., WI
M.B., VA
J.G., TX
J.K., CA
H.K., PA
S.S., FL
R.W., KY
Sweet. There can't be more than one JGNV.
Old 11-22-2011, 08:09 AM   #1856
tuzirix
hit the road, Jack!
tuzirix's Avatar
Oddometer: 48
Hi Poolside, does this list include the Final Sale purchasers? If yes, I'm not seeing my initials on that (FF,FL) deal closed on Nov 8, 2011...
...like there's no tomorrow!
tuzirix is offline
Old 11-22-2011, 08:41 AM   #1857
freedomtwoup
freedomtwoup
freedomtwoup's Avatar
Oddometer: 97
Ditto my order placed on Nov. 17th. DR CA.
All the very best,
David
freedomtwoup is offline
Old 11-22-2011, 09:40 AM   #1858
Plane Dr
Plane Dr's Avatar
Oddometer: 866
Ahh, that your name isn't on the list? But seriously, and jovially , it doesn't mean anything, Magoo. This batch and half of the next fills the last of the previous pre-orders. Then starts the orders from this Final Sale. I think your invoice explains that.
And speaking of long-time prior orders... You wonderful and patient folks that have been waiting and haven't yet lynched me, THANK YOU for your patience and confidence!
Previously posted for the most recent list.
I'm about middle of the list from 29 June....
86 RG500WW (gone)
Plane Dr screwed with this post 11-22-2011 at 09:47 AM Reason: add info
Plane Dr is offline
Old 11-22-2011, 11:00 AM   #1859
rattis
rattis's Avatar
Oddometer: 1,204
Talking Once more
What will the IICE AIR do for my camhead, I ask this (again) as you have som left and I could do with some more omph
I wish I had bought a GSA a long time ago
and now I drink Orange Crush as well, thrice up now, two 990 Adv and a 950 SER
rattis is offline
Old 11-22-2011, 11:34 AM   #1860
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Yes I have missed a few questions along the way. The camhead motor runs on gasoline, and passes EPA regulations. The changes from the IICE Air perform the same as on any of the other fuel-injected BMW bikes.
Poolside is offline
Closed Thread
Times are GMT -7.   It's 12:49 AM.
