Old 01-20-2012, 08:35 AM   #2161
jadoca
Oddometer: 41
Hopefully these things will plug into the new water cooled power plants soon to be @ a dealer near you.
jadoca is offline   Reply With Quote
Old 01-20-2012, 10:21 AM   #2162
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,758
Originally Posted by Wallowa View Post
Good review and thanks...could you clarify, your second paragraph, does that "-20 setting" listing of "advantages" include use of the BP? Or does only the IICE give them ["It didn't seem any different from my BP".] ? At -10 you do not have this advantages?
I am reading between the lines, but it sounds like you prefer the -10 because "I get a smoother engine and better fuel economy" for on road riding and less for off road, slow speed, subtle throttle. Could you elaborate. Thanks.
As I mentioned, I could not tell any difference between the BP and the IICE Air set at -20. So the advantages (or disadvantages) I felt with the IICE at -20 would also apply to the BP
Yes, you read it correctly. I prefer the -10 setting. It's probably does not perfect the way my engine runs but I really feel it's better on the overall than the -20 setting. I really like the added smoothness of the engine and better fuel economy but do not like the slightly increased snatchiness of the throttle (which should later on be addressed by the IICE Cool) and the ever so slight hesitation at the 3K rpm range. Obviously, the increased throttle snatchiness will really be felt during slow speed (and off-road) riding when lots of on-and-off throttle twisting is done.
I won't even bother testing the bike on the -30 setting...
OCJ
92 R100GS-PD Euro
01 Vespa PX150E
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline   Reply With Quote
Old 01-20-2012, 12:17 PM   #2163
Treadless
gunna b adventuring
Treadless's Avatar
Oddometer: 4,843
Round about what was the ambient temp when you were riding/testing?
I ride faster than I should but slower than I wish. I know there is risk, but I balance it against skill and luck and that act is a big part of why I ride motorcycles and why I bother with a trip like this. - Neduro
"When injustice becomes law, resistance becomes duty." - Thomas Jefferson
Treadless is offline   Reply With Quote
Old 01-20-2012, 05:39 PM   #2164
opposedcyljunkie
Heavyweight Boxer
Oddometer: 4,758
Daytime weather goes from 20-28degC.
OCJ
92 R100GS-PD Euro
01 Vespa PX150E
07 R1200GS
Old 01-20-2012, 06:13 PM   #2165
Wallowa
Oddometer: 4,474
Talking Where Are You!
68-82.4 degrees F ...unless I missed my conversion...are you in Florida?
Damn..don't you know it is Winter...
So -10 the "hot" setting is best at these temps on your particular bike for the way you ride it...stretch that to 100+ F, will it just get better?
I am still looking for the complete understanding of when you could guess that a particular setting might provide the optimal results...smoother everything..Hopefully there will be enough overlap that I don't need -10 at 90 F; -20 at 55 F and -30 at 33 F. Time and experimentation will tell and that part is fun, if it results in good predictive dial-in set-up guidelines. My riding and my bike are unique however hopefully I can find repeatable sweet spots for the settings under similar conditions. No perfection just the best possible.
"In Wallowas"
2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!"
Wallowa is offline   Reply With Quote
Old 01-21-2012, 03:02 AM   #2166
opposedcyljunkie
Heavyweight Boxer
Oddometer: 4,758
I'm currently based in Manila, Philippines where riding season is the whole year 'round
I guess I've concluded that the -10 setting is the best for my bike at the riding conditions I'm in. YMMV as you guys ride in much cooler temps. I'm just happy that I've found -10 to be the best since this is the only setting where the forthcoming IICE Cool will work with.
You can't get the perfect set-up and for me, -10 would be the best compromise. On occasion, it does get colder than usual here and I would think that the -20 setting would be optimal. But the differences are so minute that I found that adjusting it based on what the current temps are more of a waste of time and effort than anything else.
Again, I just found my own sweet spot by feel. That is also because until now, I really don't understand why the hotter it gets, the less temp adjustment the engine needs (according to Poolside). Seems counter-intuitive to me. But hey, -10 works fine for me. Poolside is spot-on
After using the BP for some 7 months on its hard-coded -20 setting, I thought it was a blast. And it was, until I got the IICE and got some more improvement using the -10 setting.
Have you received yours already? I'm thinking not yet
OCJ
92 R100GS-PD Euro
01 Vespa PX150E
07 R1200GS
Old 01-21-2012, 05:31 AM   #2167
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 6,206
That's a mighty big lake.
Roll The Bones IV- What's coming next?
http://www.rollthebonesrally.com/
"If you can't fix it with a hammer you can damn sure teach it a lesson".
slowoldguy is offline   Reply With Quote
Old 01-21-2012, 10:24 AM   #2168
Wallowa
Oddometer: 4,474
Thanks OCJ
Your input and experience has helped me try to wrap my mind around when to use what setting on the IICE.
Much is counter intuitive to me also. But as JJ said, if I get this correct, it is about the fuel vaporization vs temp.
And I assume fooling the BMW by -10 in high vaporization/ high temp introduces a slightly richer mix cuz most of the fuel is being vaporized and less additional fuel is needed..... as opposed to a -30 fake out which dumps more fuel when less is being vaporized [low temp] and hence the engine needs more fuel not less.
It still is counter intuitive to me since I have always envisioned the air density vs fuel ratio as the critical relationship and by putting more fuel in under lower air temps [denser] you will get more vapor to ignite by shear fuel volume increase but also this means more raw fuel [overly rich] to wash down cylinders and get into lubricant.
Damn I wished I had a clear image of how each setting works so that I could adjust the settings to meet my needs. I feel like Dumber of Dumb and Dumber.
Ps....Humidity where you are is probably slightly above our 10-20% here during Summer That at some level enters into this fuel/air discussion as well.
PPs..No, I have not received my IICE yet; but then again it is snowing hard here now.
"In Wallowas"
Wallowa screwed with this post 01-21-2012 at 10:29 AM
Old 01-21-2012, 10:33 AM   #2169
Treadless
gunna b adventuring
Treadless's Avatar
Oddometer: 4,843
Thanks.
One other thing that if you did post it I don't recall is about your bike. Are you running the stock exhaust and/or any other mods? These would also make difference, along with ambient temp, on which setting to use for those that are still working on sorting out settings.
Old 01-21-2012, 11:44 AM   #2170
frogy
frogy's Avatar
Oddometer: 616
Speaking of mods,should I put my little pink relay back in or does it matter.
frogy is offline   Reply With Quote
Old 01-21-2012, 01:02 PM   #2171
Wallowa
Oddometer: 4,474
What?
OK, I missed this memo...what "little pink relay"?
"In Wallowas"
Old 01-21-2012, 02:08 PM   #2172
dirtyoffroad
dirtyoffroad's Avatar
Oddometer: 437
yes,and dont forget to zip up
09 Husaberg FE 570
07 Honda XR 650R
11 BMW R1200GSA
dirtyoffroad is offline   Reply With Quote
Old 01-21-2012, 05:32 PM   #2173
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 13,934
This isn't JM, the mods don't patrol here very often, so not to worry - leave the little pink guy hanging out.
Chances are no one will notice.
Splitting lanes, and splitting hairs.
Andrew is offline   Reply With Quote
Old 01-21-2012, 06:07 PM   #2174
MSteven
Oddometer: 80
I'm on the list!
Originally Posted by Poolside View Post
Here's the big list of customer initials and destination states.
B.B.Y., NJ
R.S., CA
P.B., OR
J.R.T., CO
M.S., CA
G.C., NH
D.L., CO
L.S., TX
S.P., CO
R.S., TX
M.K., WI
T.T., TN
K.A., WI
A.B., CT
K.D., VA
D.M., WA
R.L., CA
J.P., TN
C.R., CA
D.S., PA
D.T., TX
J.Y., CA
M.L., NJ
M.W., GA
R.H., VA
D.M., WA
J.P., TX
C.M., CA
M.P., FL
J.M., MI
G.H., WA
S.B., LA
L.D., WA
G.K.W., APO/AE
C.K., FL
A.C., TX
M.F., MI
M.P., SC
J.L., TX
M.C., CO
F.F., FL
A.G., TX
R.B., NM
V.T., WA
W.R.D., OH
P.C., CA
B.W., IL
J.C., CA
D.B., PA
R.F., GA
R.L., NY
K.W., CA
M.M., IL
D.C., VA
M.H., IL
J.W., CA
D.R., CA
J.N., AZ
J.S., HI
T.V., OR
S.B., OK
D.W., NC
G.A., CA
B.C., CA
G.B., TX
P.C., CA
J.K., KS
S.B., IL
K.Y., CA
R.B., MS
M.C., GA
J.F., GA
G.F., AZ
C.B., CO
D.P.P., MI
D.R., VA
K.F., CA
K.D., CO
J.S., ID
D.L., CA
K.V.U., CA
J.K., AR
G.R., NH
H.B., CO
J.G., WA
F.C., MS
J.V., VA
M.F., CA
J.H., CA
USBA, IN
D.B., NJ
J.L., MO
D.H., CA
R.W., KY
S.S., WA
D.V., WA
K.S., MO
K.P., IL
J.B., FL
W.G., CO
M.C., CA
E.S., CA
D.B., CA
R.D., CA
M.C., WA
M.F., TX
M.G., DE
T.M., TX
A.H., OR
E.A., NV
GEI, OR
G.H., CO
J.J., CA
J.H., OR
M.D., AR
W.W., ID
M.J.S., CA
R.P., GA
A.H., TX
M.M., CA
E.C., CA
M.S., CA
M.S., MI
C.T., CA
M.M., CO
That amounts to 140 pieces. (Plus any additional last minute entries that is. )
The batches of 30 are divided with dashes.
A batch may have less than 30 names as some people ordered more than one.
Cool, I'm on the list. In orange text even. Must mean I'm speshull or sumtin'.
Seriously, I'm glad I got to order one of these, as I just became an R1100GS owner last month. Thanks Poolside for offering latecomers a chance to get in the game.
I'll look forward to trying it out when the snow melts and the roads are dry.
MSteven is offline   Reply With Quote
Old 01-21-2012, 07:46 PM   #2175
YetiGS
Random Hooligan
YetiGS's Avatar
Oddometer: 6,189
Depends whether you have an aftermarket exhaust or not.
-Scott-
Semper Fi
'04 BMW R1150GSA, '08 KTM 450EXC-R, '04 KTM 625 SXC
"A pessimist thinks all women are bad. An optimist is one who hopes they are." Chauncey Depew
YetiGS is offline   Reply With Quote
Times are GMT -7.   It's 02:42 AM.
