02-25-2012, 04:54 PM
#2326 |
Happy Wanderer
Oddometer: 103
Well, OK but..
- Dip switches are not actually affected by cold or heat. Unless you're talking about pizza oven hot or so cold your wheels won't turn and you ain't goin nowhere anyway. - I've populated thousands of IC boards and soldered them with water soluble flux type solder, then put them in a dishwasher and cleaned them with scalding hot water to remove the flux. No damage to the switch occurs. Zero failures. These things are simple and tough. - The IceAir is built in a plastic container with a tight fitting lid. I would not expect "contamination" to be a problem in there. As you say, once the novelty wears off they won't be exposed much if ever. Only real downside I see is they are not as cheap as headers and jumpers. |
02-25-2012, 05:19 PM
#2327 | ||
Syndicated
Oddometer: 11,288
02-25-2012, 06:09 PM
#2328 | ||
Syndicated
Oddometer: 11,288
02-26-2012, 03:28 PM
#2329 |
Happy Wanderer
Oddometer: 103
Why PussyLips!!! I've been just fine. Shucks, I didn't think you cared!
![]() ![]() You spent a MONTH looking for low profile rotary DIP switches? I found some that measure less than .250 in height in about a minute. That is lower than a header and jumper. Temp range of -40C to 85C. My thought was to put the thermistors and wires on the bottom side of the PCB and only the rotary switch on top. Fill with epoxy to top of PCB leaving only the rotary switch exposed on top for access and well, I leave the rest to your most fervent imagination. Anyway, this thing is in the can so it's a moot point anyway. 2329 posts. WOW! Is this a record? |
02-26-2012, 11:21 PM
#2330 |
Syndicated
Oddometer: 11,288
Good job. But you already dug up well-covered topics in your previous posts in this thread. Now shooo Poolside screwed with this post 09-03-2012 at 02:27 PM Reason: Updated link to previous posts |
02-27-2012, 01:10 AM
#2331 | |
Oddometer: 23
JW
Warner |
02-27-2012, 06:40 PM
#2332 |
CanoeMoon
Oddometer: 12
Missed by that much...!
Poolside, JJ, and all the other reprobates appearing in this lengthy thread... excellent work. I have spent the last 3 days reading this epic from start to finish and it's the best discussion yet. I really liked the sparing in the middle where most of us got a headache. Full on. All the accessible clarity on how and why... all the unveiling of ECU world... , even the admirable marketing takes (I'm sure JJ must have handled the Bejing Olympics) Excellent work.
![]() ![]() Poolside, i have a booster plug for some years and i like how it works but not how it drinks, and the IICE Air would sort that for sure. You explanation of the -20 setting clarifies why this is so. I just emailed Mike at Beemer boneyard and he sold the last unit a week ago. (I should try electricity in my computer and ditch the mice/wheel combo... i might have found the thread sooner) If you have the notion of re-editioning the Air at some point can you put me on the list please (this of course means getting the Cool in conjunction with it) . I am always keen to get the big GS to behave how nature intended it too. (98 GS 1100. 255,000 kms, Australia) cheers, CM
02-27-2012, 08:42 PM
#2333 |
freedomtwoup
Oddometer: 95
Simply enjoy the story & buildup to the delivery ... thank you for all your diligence, patience, hard work and replying to even the most perplexing emails ...
02-28-2012, 04:16 AM
#2334 |
s00per n00b
Oddometer: 42
Shipped?
On the list as "scheduled for 2/18". Did this group ship? If so I will need to get some tracking info as it's not shown up yet. If not, I'll sit patiently.
Prysock screwed with this post 03-01-2012 at 04:04 PM Reason: Brevity |
02-28-2012, 04:24 AM
#2335 |
Tundra Thumper
Oddometer: 2,274
Alright, on the "Scheduled for 2/25" list. After waiting patiently for months I can hardly wait much longer
![]() Good work guys,,,,,,,,,,,,,,,now where's that mailman?
DONATE TO ADVRider sidestandup.com ridedualsport.com motoboss-terlingua-bound.blogspot.com MSF Rider Coach-Rider's Edge Instructor-Track Coach |
03-01-2012, 09:35 AM
#2336 | |
Syndicated
Oddometer: 11,288
Here are some pictures taken at various times over the last week. Wiring harness assembly. ![]() Here are the little thermistors and jumper boards. Aren't they cute? ![]() One batch assembled and starting on the next one. ![]() A batch of assembled IICE Airs ready for testing and epoxy potting. ![]() Here they are curing as of 7:20am this morning. These are 72 hours from being ready to ship. ![]() Starting another set of component prep and wiring harnesses. ![]() Poolside screwed with this post 03-01-2012 at 09:44 AM |
03-01-2012, 09:43 AM
#2337 | ||
Heavyweight Boxer
Oddometer: 4,758
Maybe you meant the IICE Cool? |
03-01-2012, 09:45 AM
#2338 |
Syndicated
Oddometer: 11,288
Yep, thanks. |
03-01-2012, 01:28 PM
#2339 |
freedomtwoup
Oddometer: 95
From my point of view, this is an item tha willt bring lots of pleasure and comes with a great story. Keep on keeping on Poolside.
Best from The Napa Valley, David |
03-01-2012, 08:23 PM
#2340 |
What?
Oddometer: 579
I think I can see mine from here!
