Closed Thread
Old 05-28-2012, 11:00 AM   #2881
FlyingFinn
Oddometer: 1,097
The "lean pop" from the exhaust when going off throttle IS NOT a sign of lean jetting.
So if the popping is only "issue" you're experiencing then you're good. There's no issue.
Mikko
"It is not when or how you die but how and if you truly were ever alive!" Dr. Jerri Nielsen FitzGerald
FlyingFinn is offline
Old 05-28-2012, 12:26 PM   #2882
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 15,813
Originally Posted by Wattner View Post
Poolside,
Good day!!!
Long story short... I had a 2007 GSA with a Remus exhaust and K&N style filter, and had installed a Techlusion. I had the lean pops sorted and it ran great. I sold the bike to a fellow inmate... Fast forward 3 years. I bought the bike back and the Techlusion is disconnected, the bike pops like crazy on decel so I hook the techlusion back up and it is not functioning.
My thoughts here... Does your system allow any adjustments for adding fuel (making it richer) to compensate for the increased airflow? Do you feel going with your setup will take care of my issues, or should I send the techlusion device back for service?
I tried reading through some of the threads, but was unable to find exactly this issue with a direct answer.
Thank you!
Wattner
To help minimize the pop make sure the throttle is FULLY closed when decelerating.
The IICE Air deals primarily with one fuel injection algorithm as explained in several posts in the early portion of this thread. And while it is adjustable it is designed for compatibility with other IICE products and extreme temperature environments.
JJ
• The hidden harmony is found with joy, while the obvious brings indifference.
• The farther you enter into the Truth the deeper your conviction for truth must be.
• There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is offline
Old 05-29-2012, 02:12 AM   #2883
BMWzenrider
The Road Scholar
BMWzenrider's Avatar
Oddometer: 1,089
Ok, I actually read this ENTIRE thread and have not seen all of my questions answered.
Bikes:
2002 R1150R(A) - Stock except for canister disconnected.
Will readily ping/knock under hard acceleration (worse with low-grade fuel, of course...). Local fuel is all 10% ethanol added, all grades.
It never suffered from the 'surging' of other oilheads until after I had my canister clog up which required it to be disconnected (after a couple of fillups of the tank which showed that it was not venting properly {vacuum in the tank}, so the pump was probably working extra hard).
2005 R1200RT with Hannigan LT sidecar attached - Canisterectomy, and lowered gearing through combination of 2.75 ST final drive and smaller diameter car tire (~14% total gearing reduction).
Would like a little more 'oomph' when accelerating and to maintain speed on grades without downshifting. Hopefully with no hit in fuel economy during steady-state cruising.
I also ride this rig year-round in Wisconsin, so my ambient intake air temps are regularly below freezing for several months of the year, and during the transitional seasons I can experience very wide daily temperatures.
I understand that the "Air" product is designed to only affect fueling during "Leading Throttle" conditions, and that future pieces will work in other running modes.
As such, I am thinking that the current product should help with the pinging/knocking under acceleration that the R1150R suffers from, correct?
For the sidecar my thought is that this may also help during acceleration due to the added load (weight and drag) that the bike is hauling along, but am not sure whether I am feeling more of an issue of tip in, or steady throttle acceleration. Even with the lower gearing I know that I am always using more throttle for a given speed than when the bike was ridden as a solo.
I am also wondering if it would be worthwhile to get on-board in order to be able to install the future mods. (will they have any specific benefits for a hex-head dragging along a big & heavy sidecar).
Anyone else have one of these installed on a sidecar rig with results to relate?
A couple of questions:
1) So, do you think that the current module will have any noticable/beneficial effect for the sidecar rig? If so, why?
Has anyone else installed one of these on a sidecar rig who can tell what, if any, difference it has made?
2) I know that at least one other person had talked about a way to more easily alter the offset of the "Air" module due to wide temperature fluctuations in the same day of riding. Has this been addressed by anyone yet?
3) You mentioned that for the second module (the Cool) in addition to the "accelerator pump" function, you will also be altering the throttle overrun fuel cutoff function. Is your plan to eliminate the fuel cutoff completely or just alter when it engages?
I tend to use the override fuel shutoff quite a bit when riding locally (coasting up to red lights and stop signs) and can see the positive effect on my average fuel economy. I would hate to lose that benefit.
4) Will phase 3 (Smooth) require both of the prior modules to opperate?
5) What is the current projected timeline for the future modules and estimated costs for each?
TIA!
Karl Kugler
www.theroadscholar.net
2005 BMW R1200RT w/Hannigan-LT sidecar
2002 BMW R1150RA
In Memoriam: Harley, 1993-2010 You will be missed.
BMWzenrider is offline
Old 05-29-2012, 04:16 AM   #2884
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,872
Decel Popping and the IICE Products
Good day!!!
Hey there Wattner! Hold on to your hat, this is going to get technical.
Let's start with the condition commonly referred to as 'lean popping' or 'decel popping'. Decel popping is caused by creating a combustible mixture of fuel and air in the exhaust, and then igniting it. POP!
But the whole idea of it seems a little odd though, doesn't it? "What the heck is a combustible mixture of fuel and air doing the the exhaust in the first place?" I'll try and explain how that happens.
There's a sequence of events that occurs which results in air and unburned fuel getting into the exhaust. The first thing to happen is the ECU switches to a mode of operation called Overrun Fuel Cutoff. (Link to read more about that.) OFC is the initiator or lead event if you will.
Overrun Fuel Cutoff happens when you 'roll off' or 'get out of' the throttle. Rolling off the throttle is also called 'Trailing Throttle' or 'Overrun'.
If you roll off the throttle a small amount, the ECU merely reduces the amount of injected fuel. But if you roll off by a larger amount, at some point the ECU cuts off the fuel flow completely. Hence the name Overrun Fuel Cutoff.
Do you get that so far? Roll off the gas far enough, and at some level of trailing throttle a limit or threshold is crossed. And when that happens the ECU switches to Overrun Fuel Cutoff. The ECU is programmed with a set of rules that determines when to switch over to OFC.
A characteristic of Overrun Fuel Cutoff is that during OFC, the motor isn't actually running. The motor is turning because of the inertia of the bike, but there is no flame in the combustion chamber. You may as well have switched off the ignition key.
There is no 'decel popping' during Overrun Fuel Cutoff because there is no fuel being injected to ignite. During OFC the exhaust plumbing begins filling with normal oxygen-rich air. Because when the fuel is cut off, the motor is merely an air pump.
So that's how the fuel gets turned off. What causes injection to resume? It's pretty much the opposite condition. You've backed way out of the throttle, to enter a corner say, and OFC is in effect. Now you're about mid-corner and your going to pick up the throttle a little. As you begin opening the throttle, fuel cutoff is still in effect.
Pick up the throttle far enough, and at some point trailing throttle is reduced enough so that the 'fuel cutoff threshold' is crossed again, and the ECU begins injecting fuel.
To be continued...
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline
Old 05-29-2012, 02:47 PM   #2885
Wattner
Wattner's Avatar
Oddometer: 5,268
Wattner screwed with this post 05-29-2012 at 04:39 PM
Wattner is online now
Old 05-29-2012, 04:07 PM   #2886
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,872
Previously:
Continued from previous post...
In the above example, the ECU is in the 'fuel cutoff transition area' let's call it. The bike is still decelerating slightly, but not quite enough to solidly engage the fuel cutoff routine. Not every combustion cycle is getting fuel. Some are, and some aren't. The ECU cannot clearly decide what to do with the rider input.
This fuel cutoff/resume transitional area is sort of a 'non-definitive operational range' say. The ECU is literally straddling the fence. Sometimes injecting fuel, sometimes not.
If you're an electronic technician you might recognize the condition described above as output signal noise occurring at the input threshold. The technical description of the problem is that the ECU algorithm doesn't have enough hysteresis surrounding the fuel cutoff threshold.
This cutoff/resume transitional area is the operational range where Decel Popping happens.
Here are a few questions that are sometimes asked at this point. "If the ECU begins injecting fuel, how can that cause decel popping?" and "Won't the injected fuel simply burn normally in the next combustion cycle?" and "What the hell are you talking about, Jim?"
I'll try and answer those questions in the next post. As well as describe what effects the IICE Air, Cool, and Smooth, and also the Techlusion, might have on the issue of decel popping.
To be continued...
Poolside is offline
Old 05-29-2012, 04:31 PM   #2887
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,872
I see your post up there BMWzenrider. I'll get to it after I finish with Wattner's questions.
Poolside is offline
Old 05-29-2012, 08:48 PM   #2888
MSteven
Oddometer: 83
Yoohoo, Poolside dude.
Just a note letting you know my majic device arrived today. You beat me to it, the GS is still in butt in the air condition.
Thanks, I'll let you know how it works. I sure would like to take it with me to Alaska in July, but I can't get it in overhead storage.
MSteven is offline
Old 05-29-2012, 11:51 PM   #2889
roger 04 rt
roger 04 rt's Avatar
Oddometer: 2,192
Overrun Fuel Cutoff
Regarding Jim's good comments on decel popping, here is the Motronic MA 2.4 logic for when OFC kicks in: overrun fuel cutoff.
Regarding decel popping, I agree that yes, the throttle does have to be open a couple degrees for the fueling to come back on but I believe the popping occurs due to misfire due to leanness due to air filter or exhaust mods, and maybe due to lean fuel e10. Once the engine misfires (hard to detect when decelerating) that misfired fuel ignites and pops in the exhaust.
roger 04 rt is offline
Old 05-30-2012, 02:35 AM   #2890
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,872
Originally Posted by roger 04 rt View Post
[H]ere is the Motronic MA 2.4 logic for when OFC kicks in...
Regarding decel popping, I agree that yes, the throttle does have to be open a couple degrees for the fueling to come back on...
That isn't what I'm saying, Roger. It is more interrelated than that.
I'll be done with this short primer in a couple of posts. There will be plenty of time for opinion and voting.
Poolside is offline
Old 05-30-2012, 09:42 AM   #2891
darmahman
"Illogically Deluded"
darmahman's Avatar
Oddometer: 2,962
Put the ICEE Air on just now and took it for a quick spin around the block. What I noticed: Starts quicker, idles slightly higher, and just as advertised smoother transitions between idle/ off idle. Not huge changes but definitely noticeable positive drivability changes. Easy install - very good workmanship.
Now with that ringing endorsement and having waited months for mine, can I be first in line for the IICE cool???
Thanks PS. Hope you are getting rich off this after taking such verbal abuse from us inmates.
ABC# - 4011
“Folks are usually about as happy as they make their minds up to be.” Honest Abe
The last honest politician to come out of Illinois
darmahman is offline
Old 05-31-2012, 02:34 AM   #2892
KCDakar
What are we waiting for?
KCDakar's Avatar
Oddometer: 3,388
BMWzenride, you have a PM. I got your message before I got to this thread or I would have answered here. It's 3:30 am and I need to hit the hay. When I get some needed sleep I will come back and answer in more detail your questions you have posted.
And until then, buy it!!!
To me, the best kind of trips are the ones you planned on the way, allowed yourself to change, and maybe didn't end up where you expected. Klay
Save $5 on Smugmug by entering coupon code: GJBcMk1uLoZm6
KCDakar is offline
Old 05-31-2012, 05:20 AM   #2893
tmgs
...Trailers are for Boats
tmgs's Avatar
Oddometer: 989
quick question
Has anyone put this on and run the bike on a gas analyzer and a dyno before and after? I did dig through some of the posts, but wow there are a ton!
I would like to see the results if so
thanks!
tmgs is offline
Old 05-31-2012, 10:36 AM   #2894
roger 04 rt
Oddometer: 2,192
thanks!
I have put in a BoosterPlug and run an AFR gauge during Closed Loop operation--there was no difference and none expected since the O2 controls the fueling to a ratio of 14.7:1. With the O2 sensor disconnected, the mixture was richened 6% as claimed because the device altered the temp sensor signal such that the Motronic measured a temperature 20C colder than actual and richens the mixture accordingly. Most Oilheads are in Closed Loop operation about half the time. I would expect the same results with an Iice Air set at 20C. See post #82 on this page, http://advrider.com/forums/showthrea...=749080&page=6.
I don't know what a dyno run would show, maybe not much since dyno runs are usually made on intertial dynomometer with the throttle wide open for the whole "pull". The Motronic already uses a pretty rich mixture at WOT.
roger 04 rt screwed with this post 05-31-2012 at 10:41 AM
Old 05-31-2012, 11:22 AM   #2895
Deco
Deco's Avatar
Oddometer: 246
+1
Same experience here. Very nice mod. Thanks PS for all the work!!
I have only ridden a short time with it but the difference is very apparent. It smooths out some of the throttle's rough edges, please forgive my lack technical expertise in describing the performance.
Me likey.
Bring on the IICE Cool!
Deco is offline
Closed Thread
Times are GMT -7.   It's 08:58 PM.
