Closed Thread
Old 06-11-2012, 02:21 PM   #2926
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 15,914
I received your IICE Air just now. I plugged it into itself and it didn't light up. So the batteries must be dead. I'll get right on that! . (Just kidding!)
I'll plug it into my bike today and go for a run.
More later
JJ
Originally Posted by Poolside View Post
Regarding getting your IICE Air back, I have this idea and I want to see if it's ok with you.
For those of you who don't know, Mouthfulloflake was having some issues with his bike. And to eliminate the possible influence of a defective product I got it back from him to test it out.
Here's what I found. The Air tests out just fine, and is working properly. There is a slight trace of dielectric grease on the electrical contacts. I remember someone mentioning that they applied some dielectric grease to the contacts, I don't remember if that was you. Either way, I did not observe any effect from the slight residual contamination.
The dielectric grease is green in color and I initially thought it was copper oxide on the electrical contacts. There is very little on there. Looking at it under high magnification showed it was a grease compound of some sort. I rubbed a tiny speck of a sample between my fingers and it feels like a silicone not petroleum based product. Like I said though, The Air passed the tests, and works right on the bike.
So here's what I want to try. I would like to send your IICE Air up to JJ for another bike test input, and he'll forward it to you. What do you think, would that be ok? I would send it out tomorrow to Seattle.
Originally Posted by mouthfulloflake View Post
That is fine with me PS, just give me an idea on the time frame.
It wasnt me that put anything on those connectors BTW.
I bought the bike used a few years ago, lord only knows what it went through before that.
you mentioned at one time my bike possibly having an aftermarket eprom in the morotronic box.
would I still have lean surge issues with the rose colored plug in that scenario?
also, you asked me to unplug the IAT and run it and see what happens, I have yet to do that, but I will certainly try that if it wont harm anything else on the bike?
The hidden harmony is found with joy, while the obvious brings indifference.
The farther you enter into the Truth the deeper your conviction for truth must be.
There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is offline
Old 06-11-2012, 02:47 PM   #2927
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,053
Try putting it into the freezer to recharge it JJ
More later
JJ
Tilt your head, not the taco. - Pati Jinich
Charter member: T.O. club.
mouthfulloflake is offline
Old 06-11-2012, 03:05 PM   #2928
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,878
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline
Old 06-11-2012, 03:29 PM   #2929
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 15,914
Ouuuuuuuuu Good Idea!
JJ
WingMakers.com
johnjen is offline
Old 06-11-2012, 03:33 PM   #2930
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,878
Thanks for your input a few posts back, Roger.
To add one thing. (And if I remember right from some of your other posts.) That set of readings were taken with a 'reset' ECU. You know, disconnect the battery.
A 'reset' ECU is different than ongoing operation. After dozens of heat up/cool down cycles of normal operation, the ECU eventually adjusts the long-term trim settings from initially operating without an O2 sensor.
Fortunately, the above doesn't apply to Open Loop operation , which is where the Air and Cool do their stuff.
Poolside is offline
Old 06-11-2012, 05:05 PM   #2931
roger 04 rt
roger 04 rt's Avatar
Oddometer: 2,224
Yes, you're right, with a reset Motronic. As long as the O2 sensor were never reconnected, the graphs below would continue to apply because no new Closed Loop factors could be generated.
roger 04 rt is offline
Old 06-11-2012, 06:37 PM   #2932
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,609
And now for a word from our sponsors......
This Pocket Protector Convention is over. You nerds get the hell back down to the sandpit. Lollygaggers, every one of you. I'm getting a brand spanking new used Lithuanian transmission put in and won't even have a new widgit to put on it.
RTB V- The Texas ADV Rally- Hurry before we fuck this up!
http://www.rollthebonesrally.com/
"If you can't fix it with a hammer you can damn sure teach it a lesson".
slowoldguy is offline
Old 06-11-2012, 06:44 PM   #2933
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 15,914
Ok Quality Control Checks A thru G all performed and passed.
But I KNOW it's working because the YEEEEEE HAAAAAW Factor is in full effect.
So just what is the YEEEEEE HAAAAAAW factor you ask?
Well when you whack open the throttle, the front tire has difficulty staying on the ground in 1st & 2nd gear.
Now that can be done when you deliberately set it up, you get the rpms just right and roll on the throttle just so, but this is different. It happens all the time, just because.
It'll be in the mail tomorrow winging its way back to you. It's work'n just like it's supposed to.
JJ
WingMakers.com
johnjen is offline
Old 06-11-2012, 08:25 PM   #2934
roger 04 rt
Oddometer: 2,224
TEXAS-ROLL THE BONES RALLY (RT/B3) Hell. I do Halloween-ish. 2012, Hamilton, TX
" Me? A racer? lol If you see my knee on the asphalt, you can rest assured my ass is soon to follow."
Don't worry ... there'll be plenty of time for the hammers and lessons ...
I've got to admit it, this is the channel (thread) I tune in for entertainment ... keep up the good work
Old 06-11-2012, 08:52 PM   #2935
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,878
...YEEEEEE HAAAAAW...
It'll be in the mail tomorrow winging its way back to [Mouthfulloflake]. It's work'n just like it's supposed to.
Well that's good. We got that much sorted out.
Mouthfulloflake, does your 1100 have the Rider Information Display? The RID was optional on the 1100 if I remember right.
Poolside is offline
Old 06-11-2012, 08:55 PM   #2936
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,878
Hey there, Roger. I understand you think that's how it works. Can we leave it at that please.
You're quoting me out of context is getting a little tedious.
Poolside is offline
Old 06-11-2012, 09:22 PM   #2937
roger 04 rt
Oddometer: 2,224
This is your thread, happy to leave it as is. As I said I really do enjoy reading it.
Old 06-11-2012, 09:46 PM   #2938
mouthfulloflake
Not afraid
Oddometer: 17,053
Yes on both.
mouthfulloflake screwed with this post 06-11-2012 at 09:52 PM
Old 06-11-2012, 11:19 PM   #2939
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 15,914
Originally Posted by Boxerwrench View Post
I take it by the no response to my question above the IICE Cool isn't ready yet?
It's still in development
JJ
WingMakers.com
johnjen is offline
Old 06-11-2012, 11:43 PM   #2940
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,726
JJ
I didn't tell anyone about my flux capacitor.... promise
Mr. Fisherman is offline
Closed Thread
Times are GMT -7.   It's 04:21 AM.
