07-04-2012, 11:37 AM
#2986 | |
Happy Wanderer
Oddometer: 102
But maybe you won't need them anymore once the oil temp sensor is modified also.
07-04-2012, 12:08 PM
#2987 | |
Mod-U-Later
Oddometer: 13,515
You can be fairly certain all you want, and hold to your opinion, meanwhile what I stated is correct. JJ
QUOTE from vermin I lie to myself because I am the only one who continues to believe me. johnjen screwed with this post 07-04-2012 at 12:37 PM |
07-04-2012, 12:13 PM
#2988 | |
Happy Wanderer
Oddometer: 102
EDIT: After looking closely at all the photos PS posted I see that the circuit is configured to allow the selection of one of three thermistors and a fourth position that just reconnects the OEM sensor. So this is the "do nothing" position. Or so it appears. Without the device on my bench with my trusty multimeter I'm just going by the photos and where the traces go. So that was the reason for the two connectors. I stand corrected. The booster plug and other devices I've played with add resistance to the circuit. Replacing the OEM sensor with a higher value thermistor achieves the same result. One device or two. Same result as far as the ECU is concerned. Happy Wanderer screwed with this post 07-04-2012 at 12:56 PM Reason: Curiosity |
07-04-2012, 01:00 PM
#2989 |
finding my own way
Oddometer: 1,462
Are product related questions still allowed in here?
I was attempting to install the IICE air product on my 1200 GSA, but despite filing through tons of threads and posts starting at the main link area, I still don't have a definitive answer of where this thing goes. I think it circumvents the plug residing on the opposite left side of the dongle my two fingers are pointing toward. (directly beneath the white lettering "KS"...) Is this correct? What are the two open inlets that I'm touching? Is there an issue that the cover is deteriorating from the top one and the bottom one is completely open? And finally, I ride in Mississippi where the temps are 90-100 for at least 5 months, is the -10* setting my best option during the heat or would -20* be ok?
If you wish to travel far & fast, travel light. Take off all your envies, jealousies, unforgiveness, selfishness, and fears. -- Glenn Clark Let the morning bring me word of your unfailing love, for I have put my trust in you. Show me the way I should go, for to you I lift up my soul. Psalm 143:8 |
07-04-2012, 02:56 PM
#2990 | |
Oddometer: 4,474
No
I submitted and Poolside posted a series of photos I took of the installation of the IICE Air on my '07 GSA...sorry but I do not have the number of that post bookmarked...perhaps someone else can post it for you. FOUND IT: #2646 [Pg 177] and there is a great picture of the intake air temp sensor in the air box in the Haynes "BMW R1200 Twins '04-'06" manual...figure 15.20 page 3.20. You disconnect the sensor wiring and plug in the two wires from the IICE Air wiring into the two wire and the plug that you just disconnected. No confusion since the IICE wires will only fit the correct sensor wires. If you try to install it and have question send my a PM. It takes perhaps 10 mins to R&R body panels and 3 mins to install the device.
"In Wallowas" ==================== 2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!"
Wallowa screwed with this post 07-04-2012 at 05:04 PM |
07-04-2012, 03:20 PM
#2991 | |
Oddometer: 939
But there is one significant difference here. BP and other products that ADD resistance in series with the original IAT sensor can only fool the ECU to see an air temp that's LOWER than the air temperature inside the air box. This "ICE Air" completely replaces the original IAT sensor with an NTC that sits inside the "vail" (three settings out of four). Now the location, and hence temperature, of the ICE Air is critical to the end result. Why? Let's take an example. Let's say you choose the "-20" setting. Well, if the ICE Air itself is 20 deg hotter than the original IAT sensor inside the air box then the net effect is a flat zero! Or if a -10 setting is used and again the ICE Air is mounted so that it is at a temperature that's 20 deg higher than the air temp inside the air box the the effect is +10 deg. Not what one would want or expect. All that considered, I think it would have been prudent to mention in the ICE Air installation instructions that location of the device is absolutely critical for the desired end result. -- Mikko
"It is not when or how you die but how and if you truly were ever alive!" Dr. Jerri Nielsen FitzGerald |
07-04-2012, 03:21 PM
#2992 | |
Oddometer: 4,474
I Missed That...
Guess I should confess...not that I expect the IICE Air to ever die, but since you need it to interface with the Cool and Smooth [yes, I really believe they will be birthed...] I bought a second IICE Air to keep in reserve. Could you please explain the comment about the oil temp sensor...I have no idea what that refers to...thanks.
Wallowa screwed with this post 07-04-2012 at 03:26 PM |
07-04-2012, 04:53 PM
#2993 | |
Mod-U-Later
Oddometer: 13,515
A resistor is a fixed linear device. A thermistor is a non-fixed non-linear device. Expecting a linear device to respond in a non-linear way isn't gunna happen. JJ
QUOTE from vermin I lie to myself because I am the only one who continues to believe me. |
07-04-2012, 05:00 PM
#2994 | |
Mod-U-Later
Oddometer: 13,515
http://www.advrider.com/forums/showpost.php?p=15438749 http://www.advrider.com/forums/showpost.php?p=15452060 http://www.advrider.com/forums/showpost.php?p=15453444 In short it doesn't really matter where you put the IICE Air, AS LONG AS YOU ARE MOVING, and as long as the IICE Air is in the moving ambient air stream. JJ
07-04-2012, 08:26 PM
#2995 | |
What are we waiting for?
Oddometer: 3,339
To me, the best kind of trips are the ones you planned on the way, allowed yourself to change, and maybe didn't end up where you expected. Klay I tell it what it wants to hear, and it does what I want it to do. I made that Motronic my bitch. Poolside Save $5 on Smugmug by entering coupon code: GJBcMk1uLoZm6 |
07-05-2012, 02:12 AM
#2996 | |
Happy Wanderer
Oddometer: 102
When I said "adding resistance" like the booster plug does, I meant adding the (variable) resistance of a thermistor, not a fixed resistor. I guess that was not clear. The example I was loosely explaining is that replacing two thermistor devices in series with one of double the value by itself in the same circuit and assuming the same location of the device(s) you are going to achieve pretty much the same result. A temperature offset. Hope that clears up what I was attempting to say. |
07-05-2012, 11:47 AM
#2997 |
Oddometer: 20
IICE Air and IICE Cool on 2012 Models.
I have a 2012 R1200R. I'm assuming the IICE Air provides some benefit to the '11 and '12 models as it richens up the mixture but do you expct the IICE Cool and Smooth to improve driveability in the newer models. I believe I read the newer cam heads have revised sensors and/or mapping that help smooth cruising and transitional throttle when compared to older models. I have NO technical expertise in this area so I am merely parroting what I believe I have read. I am considering purchasing the IICE Air just to get the benefits of the IICE Cool and Smooth at a later date. I already have a Accelerator Module so will skip the whole thing if you think think no additional benefit can be had on recent models by using the Cool and Smooth. Please provide a detailed answer if possible.
I've always felt fuel injection problems were killing the joy factor of newer bikes when compared to a well-tuned carburetor. It's the elephant in the room and very few people discuss it outside of the threads on this board and others. If your 3 devices can effectively simulate a perfectly-tuned carb (is a perfectly-tuned carb even possible in the real world? lol.), I will be ecstatic. I like to compare carbs and fuel injection to digital vs analog music. In theory, analog music sounds better, but in practice, digital is more convenient and usable. I apologize if this question has already been asked. Sincerely, Barry badbs101 screwed with this post 07-05-2012 at 11:54 AM |
07-05-2012, 12:04 PM
#2998 | ||
Syndicated
Oddometer: 11,286
07-05-2012, 12:08 PM
#2999 | ||
Syndicated
Oddometer: 11,286
07-05-2012, 12:17 PM
#3000 | ||
Oddometer: 20
Sincerely, Barry |
