09-04-2012, 12:48 PM
#3091 |
Oddometer: 121
Hi, it's not clear but is the ice air available now or in preorder status?
//Nevermind, according to http://www.advrider.com/forums/showthread.php?t=667661, you have 11 left. Just placed my order! Thanks! |
09-09-2012, 12:38 PM
#3092 |
Plunger Boy
Oddometer: 650
I searched the thread but couldn't find the answer;
When doing a TB sync do I need to set the IICE AIRE to 0* (The "pretend it's not installed" setting) or can I leave it at the -20* setting? Thanks. |
09-09-2012, 03:42 PM
#3093 | |
Magnanimous Madcap
Oddometer: 320
When TB Syncing you are doing two things: setting idle RPM and equalizing the vacuum pressure of air intake to each head. I cannot see how the IICE Aire would affect the pressure differential between the heads. It may affect idle RPM, but I am not a scientist. |
09-09-2012, 06:37 PM
#3094 |
Syndicated
Oddometer: 11,286
Thanks for your order, Stan! We appreciate it.
09-09-2012, 07:29 PM
#3095 | |||
Syndicated
Oddometer: 11,286
09-09-2012, 07:45 PM
#3096 |
Oddometer: 862
On my 1150 at about 3000 RPM, in neutral, my GS-911 reports Open Loop. My LC-1 (after the Adaptation period) reports no IAT enhancement. I would sync with the iiCe Air set as it is run. RB
09-09-2012, 07:53 PM
#3097 |
Syndicated
Oddometer: 11,286
Thanks Roger, but you have a significant modification to your bike. Would anybody like to contribute a GS-911 check on their 'stock O2 sensor' bike? |
09-10-2012, 04:35 AM
#3098 |
Oddometer: 862
You're welcome. The GS-911 data was taken before and after the modification on my 1150.
roger 04 rt screwed with this post 09-10-2012 at 04:44 AM |
09-10-2012, 05:22 AM
#3099 | |
Syndicated
Oddometer: 11,286
09-10-2012, 07:03 AM
#3100 |
Oddometer: 862
It would be good if you could get one of each. I believe that the 1100 and 1150 have different Closed Loop areas. And doesn't the 1200 use a BMS-K ECU versus the Motronic used for 1100/1150?
09-10-2012, 11:00 AM
#3101 |
Mod-U-Later
Oddometer: 13,515
If no one has done this check before I get back home I can do it then (≈ 14-15th)
JJ
QUOTE from vermin I lie to myself because I am the only one who continues to believe me. |
09-13-2012, 04:25 PM
#3102 |
Oddometer: 80
Setup for change from Techlusion to IICE Air
My 1100 GS had the Cat sensor unplugged with the Techlusion installed. Swapping the Techlusion for the Air does the Cat sensor need to be plugged in? I imagine so, but a definitive answer is more fun.
09-13-2012, 07:21 PM
#3103 | |
Syndicated
Oddometer: 11,286
The IICE Air changes the 'air density' calculation in the ECU. The air/fuel mass ratio calculation is unrelated to the exhaust system. O2 sensor, catalyst, headers, or otherwise. |
09-14-2012, 04:47 AM
#3104 |
Oddometer: 80
Is there any reason why it needs to be plugged in?
Sorry this is off topic, but I'm still waiting on manuals for this R1100 GS and don't have detailed info. |
09-14-2012, 05:03 AM
#3105 |
Oddometer: 862
Think of the O2 sensor as a probe that the Motronic (a fueling/spark computer) uses to see if its fuel calculation meets the needs of your catalytic converer (and also the needs of aging components in your engine and E10 fuel).
When the Teclusion was added to your bike (to add more fuel to the mixture than the Motronic wants to allow) the O2 probe was disconnected so that the Motronic wouldn't undo the Techlusion's work. When you add the ICE Air it will add some additional fuel to the amount the Techlusion is already adding. If that is what you want then leave the Techlusion connected and the O2 disconnected. It all comes down to how much fuel you're trying to add and whether you want the Motronic to keep the catalytic converter running. In your setup what are you hoping to achieve by adding the iice Air? |
