Closed Thread
Old 01-14-2013, 05:52 PM   #3256
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 15,894
I'm not sure that tickling or a stimulating experience would be an accurate description of the result if that device were in close proximity to 'the boys'.
Thanks for your participation.
Don Pardo what do we have as a consolation prize?
Next!
JJ
• The hidden harmony is found with joy, while the obvious brings indifference.
• The farther you enter into the Truth the deeper your conviction for truth must be.
• There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is offline
Old 01-14-2013, 06:04 PM   #3257
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,875
Originally Posted by johnjen View Post
All employes and their family's and subcontractors and friends are ineligible to win this contest.
Dang!
And the only reason YOU know is because that IS a picture of your secret hidden electro-lair, where all the electrons are neatly arranged and under control for those top secret and sensitive 'experiments' (here jimmy, hold these 2 wires…).
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside screwed with this post 01-24-2013 at 08:28 PM
Poolside is offline
Old 01-14-2013, 06:11 PM   #3258
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,875
Unfortunately he spoiled the answer for the rest of our at home audience…
Lets see if he (or anybody else) knows what the device in the foreground on the right with the gold top and red sides is…
JJ
Sorry, I won't spoil it. But where's Marvin?
Poolside is offline
Old 01-14-2013, 06:25 PM   #3259
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 15,894
Ya mean Marvin the Martian?
http://www.angelfire.com/pa/lkmarvin/Sounds/MARVIN1.WAV
JJ
WingMakers.com
johnjen is offline
Old 01-15-2013, 02:56 PM   #3260
mark883
Holding up Michoagán
Oddometer: 1,602
This thread makes me glad I was an early adopter.
Its worth the wait guys, particularly on a slant 4 K1200GT.
It was a marked improvement, more so than my R1100GS
A pain to install (remove plastic, lift fuel tank, install with long needle nose) but my gas mileage even went up 4 mpg according to the computer. Driveability much improved.
Couple vintage tube testers hanging around in that photo up there...
mark883 is offline
Old 01-16-2013, 08:12 AM   #3261
joenuclear
Planning.....
joenuclear's Avatar
Oddometer: 6,245
Question
Originally Posted by Poolside View Post
Dang!
It looks like Marketing needs to crack the on Production again....
How is this run coming Poolside? I can't smell epoxy curing from here.
Since you spend a lot of time using one which soldering iron do you recommend for automotive/motorcycle modifications?
My first car was a bike. [1973 CB500F]
joenuclear is online now
Old 01-23-2013, 04:35 AM   #3262
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,875
Originally Posted by trapperj View Post
Ok...so I ordered one of these a couple months ago...ran across a used one and bought it. Now I have another that will be in my Hands soon...I just bought a new Husqvarna ..it has a FI engine from BMW seems to suffer from the same lean conditions as the big GS...MY question is .... will the IICE work on this bike?
I'm going out on a limb and say YES! With one or two little caveats. The motor in your new Husqvarna is for all intents a BMW G650 single, but I don't know if the bike uses the same Intake Air Temperature sensor as all the other BMW fuel injected bikes. If so, then the IICE Air will work, provided there is a handy location for a ziptie within about a foot from where the stock air temp sensor is located. Which doesn't look like a problem.
I searched for an online parts fiche for the new Husqvarnas and didn't find one, so you'll be doing the recce on this. Maybe you can take some pictures of the stock air sensor and surrounding area and post it up. Or email them to me.
p.s.: Even if Husqvarna uses a different Intake Air Temp sensor or connector, as long as the temperature/resistance curve of the stock sensor is the same as the BMW bikes, then the IICE Air can still be fitted to your bike with a wire splice.)
Poolside is offline
Old 01-23-2013, 05:05 AM   #3263
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,875
I declare winter officially over in southern California. To celebrate, and because I'm a little ahead in my work obligations, I'm taking the rest of this week and the weekend for Air assembly.
About your soldering iron question, do you mean for splicing wires and such? I don't remember the last time I soldered a wire splice connection on a bike or car. I'll solder one or two types of connector contacts, but for wire splicing it's always a crimp connection.
For a capable workaday soldering iron, a good value is the Hakko FX-888, which is a remake of the model 936.
And you cannot fail with Kester 60/40 solder, .031" thick, with the common #66 core and '44' rosin flux. (The original 'no clean' flux, heh heh.) Use distilled water in the cleaning sponge reservoir, and keep your tip clean as they say.
Poolside is offline
Old 01-23-2013, 07:09 AM   #3264
bracky72
Oddometer: 953
One of these works great for tip cleaning.
http://www.amazon.com/Hakko-Cleaner-...g+iron+cleaner
bracky72 is offline
Old 01-23-2013, 09:12 PM   #3265
joenuclear
Planning.....
joenuclear's Avatar
Oddometer: 6,245
Old 01-24-2013, 07:23 PM   #3266
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,875
The base for the FX-888 has one of those brass sponges, as well as the cellulose sponge.
The brass sponges work well too, but I really prefer the classic cellulose sponge with distilled water. Somehow the little ttssss-s-s sound when the hot tip hits the wet sponge is reassuring. It seems like the tips last longer too. And that's quite enough innuendo I think.
Poolside is offline
Old 01-25-2013, 08:26 PM   #3267
joenuclear
Planning.....
joenuclear's Avatar
Oddometer: 6,245
Yup, back on your head!
Old 01-25-2013, 10:45 PM   #3268
TrainedChimp
Consistently wrong
TrainedChimp's Avatar
Oddometer: 185
Thumb
Dang!
That just makes me laugh.
"Fools congregate."
TrainedChimp is offline
Old 01-29-2013, 03:26 PM   #3269
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,521
Poolside and Johnjen is this thing similar to the ICE? LC1
Came up here
scooteraug02 is offline
Old 02-02-2013, 09:10 AM   #3270
funsummer
funsummer's Avatar
Oddometer: 102
Any reports on the batches that are currently being produced?
Has there being fantastic progress?
funsummer is offline
Closed Thread
Times are GMT -7.   It's 05:50 PM.
