Closed Thread
Old 11-15-2013, 08:26 AM   #3556
johnny80s
johnny80s's Avatar
Oddometer: 267
Does this work with the Booster Plug or instead of the Booster Plug? The booster Plug made the throttle a little smoother from 0-3000 rpm not buttery smooth which is what I want.
Will this give me that buttery smooth throttle?
johnny80s is offline
Old 11-15-2013, 10:48 AM   #3557
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
You could say that the IICE Air is an adjustable Booster Plug. It's adjustable so it will work with the upcoming Cool and Smooth products.
Let's talk about that smooth throttle. First a question about 'from idle to 3000rpm'. Are you talking about accelerating quickly, accelerating slowly, holding a constant speed, or something else?
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline
Old 11-15-2013, 10:55 AM   #3558
johnny80s
johnny80s's Avatar
Oddometer: 267
Doing slow speed maneuvering mostly.
Old 11-15-2013, 11:21 AM   #3559
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Ok. Would you say primarily constant speed, or primarily changing speeds? And if changing speeds, slowly changing speed, or gassing it up a couple thousand RPMs?
Poolside is offline
Old 11-15-2013, 04:08 PM   #3560
johnny80s
johnny80s's Avatar
Oddometer: 267
Changing speeds like going around a 90 corner and trying to do it smoothly. Nothing where I would rack the throttle open and closed just trying to make adjustments to the throttle up and down under 3000 rpms and having it be smooth.
Old 11-16-2013, 10:17 AM   #3561
johnny80s
johnny80s's Avatar
Oddometer: 267
Old 11-16-2013, 01:22 PM   #3562
Wallowa
Oddometer: 5,409
Same Bike
Johnny,
You and I both have '07s ...your GS vs my GSA...I had the BP, unplugged it and the put in the IICE Air...with the Air on the 90 degree corners you asked about, at slow [1st gear] speeds I found the throttle was easier to modulate and had less, not zero, problems with surging or abruptly doing the "I am off" no "I am on" thing.
Plus if the lean got too much picking up the throttle to stand the bike up more was quicker and more in control...even going up to 2nd at lower RPMs was easier since the RPMs came up like they were controlled by a rheostat ..
All this is off road and going up or down grade...
Phil
"In Wallowas"
2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!" After 2014 BOM my bike is forthwith the "GS McGee"!
Wallowa is offline
Old 11-16-2013, 03:46 PM   #3563
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,644
I was thinking about the question so I was playing with my 07 today below 2000 rpms and I was mighty impressed. Very tractable.
RTB V- The Texas ADV Rally- Hurry before we fuck this up!
http://www.rollthebonesrally.com/
"If you can't fix it with a hammer you can damn sure teach it a lesson".
slowoldguy is offline
Old 11-17-2013, 12:25 PM   #3564
InTheMuck
So it goes...
InTheMuck's Avatar
Location: Amongst the has beens & the addicts (Verona, WI)
Oddometer: 344
Talking Finally!!
So my IICE Air finally showed up in the mail yesterday! Once it showed up, my concern went from "Will it ever get here?" to "Will I be able to install it?" The answer to that was yes I have only done basic maintenance and farkle installs on my bikes over the years and this was as easy as anything else I have done. I took a few photos of the five minute process on my 2010 F800GS (see below).
So then the next question was "Will it work?" The answer to that is...maybe
Unfortunately, it is raining today, I was able to sneak in pre and post install rides between the downpours. Post install (with the default setting of -20) the bike seemed to be smoother on acceleration and deceleration but it wasn't a long enough test ride to set my mind at ease. I'm hoping we get a nice day before we are forced into hibernation so I can give it a thorough shakedown.
Edit to add: I took a longer ride this past weekend and I'm not so sure how much improvement there was. It was cooler than before and I didn't have time to play with the different settings, but I'm not 100% ready to say it works. Until next season.......
IICE Air-1
IICE Air-2
IICE Air-3
IICE Air-4
IICE Air-5
2010 BMW F800GS
2008 Yamaha WR250R
“I haven’t been everywhere, but it’s on my list."
InTheMuck screwed with this post 12-04-2013 at 07:03 AM
InTheMuck is offline
Old 11-18-2013, 10:17 PM   #3565
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Thanks for answering my clarifying questions. As I understand it, the situation you're talking about is low speed 90° turning maneuvers, between idle and 3000rpm, in 1st gear.
The thing about that operational range, is that not much throttle movement happens at such low throttle settings. You know what I mean? At small throttle openings like that, a throttle adjustment is closer to being either on or off, as opposed to having any significant throttle movement.
That category of throttle movement can be called 'off-idle transient'. And to get smooth motor response during a transient throttle event requires good Transient Throttle Enrichment.
As a couple of guys said a couple of posts back, the IICE Air improves off-idle transient response to some extent. But its primary function is to improve leading-throttle acceleration. The IICE Cool is your Transient Throttle monster.
Poolside is offline
Old 11-19-2013, 05:16 AM   #3566
Feo y Gordo
Now What?
Feo y Gordo's Avatar
Oddometer: 5,136
Well, mine arrived in the mail yesterday.
I'll install it and report back in, say, in March.
______________________
Use tools, don't be one.
http://www.advrider.com/forums/showthread.php?t=949341
Feo y Gordo is offline
Old 11-19-2013, 09:42 PM   #3567
Muncle
Muncle's Avatar
Oddometer: 64
Feo y Gordo
Mark,
No need to rush the report.
Got mine Sat. and installed Sunday (before Seahawks game) and first ride today, roll on seems easier and it pulls harder. More miles tomorrow.
Muncle is offline
Old 11-20-2013, 10:48 AM   #3568
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Poolside is offline
Old 11-20-2013, 03:10 PM   #3569
johnny80s
johnny80s's Avatar
Oddometer: 267
ok so what is this ICE Cool thing?
Old 11-20-2013, 04:02 PM   #3570
CanoeMoon
CanoeMoon
CanoeMoon's Avatar
Oddometer: 15
IICE Cool ?
The IICE Cool is the new 'long weight'. But i'm sure it'll be worth it, if the Air is anything to go by.
CanoeMoon is offline
Closed Thread
Times are GMT -7.   It's 05:36 PM.
