Closed Thread
Old 12-03-2013, 08:57 AM   #3586
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,873
Originally Posted by Three Dawg View Post
A girlfriend??? How many have you got, you old dog?
Heh heh. I'm lucky to have two that still talk to me, you know?
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline
Old 12-03-2013, 06:58 PM   #3587
spartanman
regret minimizer
spartanman's Avatar
Oddometer: 1,022
Poolside, you have a PM.
spartanman is offline
Old 12-04-2013, 03:15 AM   #3588
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,873
Originally Posted by spartanman View Post
 Cheers, Spartanman!
And thanks to all of you, for your kind messages and posts of support as we come down to the wire with these remaining batches of IICE Airs!
Poolside is offline
Old 12-10-2013, 06:35 PM   #3589
Ma Duce
TBD
Ma Duce's Avatar
Oddometer: 90
Laugh Order placed
Placed an order for one IICE Airs. Thank you
Ma Duce screwed with this post 12-11-2013 at 01:43 AM
Ma Duce is offline
Old 12-13-2013, 04:46 AM   #3590
Tbone
off-ramp slayer
Tbone's Avatar
Oddometer: 4,277
Santa came early!
just hooked it up yesterday and I'm not sure exactly what it's doing but the bike runs better and smoother even on a tired 150k mile bike..thanks Poolside !!!
Tbone screwed with this post 12-13-2013 at 10:09 AM
Tbone is offline
Old 12-13-2013, 06:42 PM   #3591
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,873
You bet, Tbone. Thanks for posting!
Poolside is offline
Old 12-13-2013, 06:47 PM   #3592
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,873
Assembly report
Hey there folks.
I'm working on the last batch over the weekend. It's looking like they'll be shipped out just in time for Xmas.
Poolside is offline
Old 12-13-2013, 09:10 PM   #3593
Ma Duce
TBD
Ma Duce's Avatar
Oddometer: 90
Thumb
Looking forward to it. Hope mine will be in that batch.
Ma Duce is offline
Old 12-16-2013, 10:36 AM   #3594
virco
The lighthearted rider
virco's Avatar
Oddometer: 24
Hello Jim.
All good and dandy about the "last batch" of pine scented AIR's, but when shall your faithful (fateful?) followers expect the other 2 new gizmos (ze Cool and ze Smooth)?
Thank you, and happy holidays!
Originally Posted by Poolside View Post
Hey there folks.
virco is offline
Old 12-16-2013, 11:56 AM   #3595
guitstik
Oddometer: 332
I tried to order one through PayPal the other day and received a message that there were no more available. When will the next run be?
Another question I haven't been able to find an answer for, I had a problem with shuddering at about 3K RPM when I first got the bike but I knew that was a concern so the first thing I did to it was go through the list of fixes for it. What finally fixed the problem was changing the spark plugs from the Bosch to Autolit 3923. Will this work with those plugs or would it be better to go back to the stock Bosch plugs?
It's not that I wouldn't own a Harley, admitting it would be the problem.
Harley Davidson: The cure for the common man.
71 R75, 73 R75, 81 R65, 97 R1100GS
guitstik is offline
Old 12-16-2013, 12:18 PM   #3596
Happy Wanderer
Day Dreaming.. .
Oddometer: 203
I wouldn't waste money on stock Bosch plugs for your 1100. Owners have been using the Autolite 3923 for that engine for many years with excellent results. I've been running them for over 3 years (>100,000kms) without any problems in two 1100 bikes. They are inexpensive and work extremely well in that motor. Just make sure you gap them correctly to 0.8 mm (0.0315 in).
Happy Wanderer is offline
Old 12-16-2013, 12:23 PM   #3597
guitstik
Oddometer: 332
Thanks Happy. I plan on sticking with the Autolit plugs because they cured a really bad surge on this bike I was just wondering if the IICE would be compatible.
guitstik is offline
Old 12-16-2013, 12:30 PM   #3598
Happy Wanderer
Day Dreaming.. .
Oddometer: 203
I think it's safe to say the Autolites will have no effect whatsoever on the IIce.
Old 12-19-2013, 02:55 PM   #3599
Carlo Muro
Supercàzzola
Carlo Muro's Avatar
Oddometer: 2,120
I just installed mine today.
If you're hoping to turn a GSA into a GSW you're going to be disappointed
OTOH, it does make a difference. To me it seems like the bike is laboring a lot less to do the same work. I know the steady state throttle is not supposed to be effected at all but it definitely seems to go down the road with less throttle input now. Tip-in (I'll borrow the cage term) doesn't seem to be changed as much as I thought it would be though. Perhaps I'll try the coldest setting later and see what happens.
Carlo Muro is offline
Old 12-21-2013, 05:32 AM   #3600
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,873
...[I]t does make a difference. To me it seems like the bike is laboring a lot less to do the same work. I know the steady state throttle is not supposed to be effected at all but it definitely seems to go down the road with less throttle input now. Tip-in (I'll borrow the cage term) doesn't seem to be changed as much as I thought it would be though. Perhaps I'll try the coldest setting later and see what happens.
Hey there Carlo. Thanks for the report. It was just the nudge I needed. I've been doing some feature development on the IICE Smooth on the R1200. And while I was at it I revisited the performance of an IICE Air on the R1200 motor, this time on a newer 1200GS. After a few minutes it was obvious that it performed just as you said. That is to say, not the same as when I originally tested the IICE Air on R1200 models years ago. I could say I was surprised about that, but that doesn't quite cover it. I'm sure there will be a lot of talk about this, and more details to discuss.
The upshot of this is an upgrade part. It will be free of course, and it plugs into the IICE Air. With the upgrade part it increases performance to optimum levels.
Poolside is offline
Closed Thread
Times are GMT -7.   It's 03:16 PM.
