Closed Thread
Old 01-05-2011, 10:57 AM   #361
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,341
Originally Posted by hasenwerk View Post
The source code is really a Bosch thing - even for Volkswagen and it is based on an Intel processor designed for cars. So if one spoke assembly language and knew what each of the registers does then one could easily follow the program. If you only know how C++ or Visual Basic or Java works then you have no clue how assembly language works! Each command in these higher level languages is dozens of commands at the CPU level - where you do thing literally one step at a time. The high level languages take your "human" code and turn it into machine code. There really is no simple or even difficult way to go from machine code to human code - it's more like όber complex!
Really smart people have written programs to reprogram TDIs and Bosch Motronic (1.8T) where you can visually look at the tables and with a click of the mouse change things... this is after 15 years of TDI and there are a lot more TDIs out there than BMWs. I think I am going to crack open my Motronic 2.2 ECU on my 1100 and see what I can see with one of these programs... could be quite simple!
Also, like I was saying there is the ECU's source code that can also be manipulated to turn off things like the immobilizer or EGR system or if you want to use a 3.0 bar MAP instead of a 2.5 bar MAP that is all part of the "source" for the ECU.
All the sensor add-ons would do is give the ECU a more favorable signal that works better with the original software. So just the like air intake sensor mod for the BMW where the ECU believes that it is cooler than it really is so there for it delivers a different (richer) mixer that makes more power. Once you put chip tuning on there you are in effect doubling those efforts and sometimes (most of the time!) that is too much.
I have a feeling that if someone was to crack the immobilizer routines for the R1200 ECUs there would be some happy customers!
CAN bus programming is also something to look at. 35W HIDs on a 55W circuit makes an error... but... if you change what CAN is looking for (like don't care how many watts) then there's no problem.
Now, here's a guy who knows his stuff. the scary thing is I understand him?!
def is online now
Old 01-05-2011, 01:18 PM   #362
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Originally Posted by roadrage View Post
How about the discarded cat code plug crowd? Not to mention the Steptoe mod folks...
Check, and check. It's all good.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline
Old 01-05-2011, 01:27 PM   #363
ragtoplvr
Oddometer: 6,390
The best solution is to go open source and fit something like the microsquirt. How this might work with CAN buss and how interrelated the ABS and other displays are I do not know. However you can use this to tune any way you wish.
http://www.microsquirt.info/
Not affiliated in any way.
Rod
ragtoplvr is offline
Old 01-06-2011, 03:05 PM   #364
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Certainly an ambitious open source project. Do you have any experience with the Microsquirt/Megasquirt products?
Poolside is offline
Old 01-07-2011, 07:09 PM   #365
charles960
charles960's Avatar
Oddometer: 517
link?
Is there a product in Vendors yet? I cannot find my way through all these posts, perhaps I missed it.
TIA
Charles
Family & Senior Portraits, Kid's Sports, Events Photography. Atlanta.
404-697-8587
charles960 is offline
Old 01-17-2011, 08:33 AM   #366
wrysingfeenix
Dust off those ashes
wrysingfeenix's Avatar
Oddometer: 639
Where'd everybody go?
Out riding their newly hotrodded GS's?
---'99 BMW R1100GS
---'96 BMW R1100GS Mod Project ???
---'80 Honda CB750 Street Tracker Project
---'09 Vespa GT200 Granturismo
wrysingfeenix is offline
Old 01-23-2011, 11:25 AM   #367
Monroe
Monroe's Avatar
Oddometer: 678
Hello? is this thing on?
Monroe is online now
Old 01-23-2011, 11:41 AM   #368
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,055
When doing a sound check the proper phrase is "P's, T's and S's". This ensures that plosives (P's) slew rates (T's) and high frequencies (S's) are all functioning properly, for full and proper intelligibility for maximum communication thruput!
JJ
• The hidden harmony is found with joy, while the obvious brings indifference.
• The farther you enter into the Truth the deeper your conviction for truth must be.
• There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is online now
Old 01-24-2011, 07:46 PM   #369
richard cabesa
The Mayor
richard cabesa's Avatar
Oddometer: 9,202
JJ
Then PleaSe Tell uS iT will be Soon
R1200RT
XLV600
Grom
richard cabesa is online now
Old 01-24-2011, 10:04 PM   #370
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,639
Two months of Gabbo! Gabbo! Gabbo!
and still nothing.
You guys shoulda hired coffee monkey to do your writing. Distract them with laughter.
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline
Old 01-25-2011, 06:37 AM   #371
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,686
I don't know if this helps, but there are four cats at my house. Both Poolside and myself have checked the ones we can catch for codes. None so far.
But, cats are sneaky bastards I expect they have them stuffed under some large immovable piece of furniture.
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is offline
Old 01-25-2011, 07:58 AM   #372
Minnesota
Conform or be cast out
Minnesota's Avatar
Oddometer: 4,007
Hmmph. Subscribe, I guess.
This argument between the "modify the inputs" crowd and the "modify the controller" crowd reminds me of this book:
The competition for how to determine longitude came down to a struggle between an amateur watchmaker and the greatest astronomers of the time. The amateur won. Lesson: the simplest solution is usually the best one.
Good luck in your quest.
To learn who rules over you, simply find out who you are not allowed to criticize. -Voltaire
Minnesota is offline
Old 01-25-2011, 12:42 PM   #373
Cpt.Barbossa
Oddometer: 62
Whaaa??? Someone else has read that book? Outstanding! I agree stop the bs banter and get on with it...or get off of it...please!
Cpt.Barbossa is offline
Old 01-25-2011, 12:45 PM   #374
Minnesota
Minnesota's Avatar
Oddometer: 4,007
Hell Yes! Should we start a longitude thread?
Old 01-25-2011, 01:57 PM   #375
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,686
I find it interesting that the Flat Earth Society is centered in Iowa.
...Dick
Smugmug
Mr Head is offline
Closed Thread
Times are GMT -7.   It's 02:45 PM.
