Closed Thread
Old 03-05-2011, 06:14 PM   #436
biggziff
Funk Soul Bruvah
biggziff's Avatar
Oddometer: 8,704
Originally Posted by GeoAggie View Post
Don't get the joke, sorry. My bike is a 2010 R1200GS adventure. If I can't get past this issue I have decided to sell the bike, which would end a long run of GS models dating back to a R100GS. Perhaps it's simply a tolerance issue . . . . . .
I had a similar sounding issue last year. It also was after the dealer had adjusted my valves. I went through them and found them to be tight...not by a lot, but apparently enough to cause the engine to get very raw feeling at similar RPMs as you have mentioned. I adjusted them a little loose (a tappy valve is a happy valve) and re-synced the TBs and viola! Back to smoooooooooooth!
"Fools you are. To say you learn by your experience. I prefer to profit by others' mistakes and avoid the price of my own."
- Otto von Bismarck
biggziff is offline
Old 03-05-2011, 06:15 PM   #437
biggziff
Funk Soul Bruvah
biggziff's Avatar
Oddometer: 8,704
Originally Posted by oneydee View Post
Link please! Or at least more information. I will do my own TB synch when the time comes and if I don't have to buy somebody elses expensive machine to do it, even better!
http://www.powerchutes.com/manometer.asp
- Otto von Bismarck
biggziff is offline
Old 03-06-2011, 11:25 AM   #438
GeoAggie
GeoAggie's Avatar
Oddometer: 271
Great information, thanks
GeoAggie is offline
Old 03-06-2011, 12:09 PM   #439
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,090
One of the reasons that OVAD even exists is because the dealer would always return my bikes with the valves in worse condition that when it went in. The same for the carbs (on my R65LS) so I got in the habit of ALWAYS going back in and re-adjusting them back to where they were 'happy' once again.
This lead me to figuring out the optimized way to adjust the valves for the oil heads, because I'd have to go back in and get them back into their sweet spot, again. And I just kept playing with the setup and adjustment procedure. Then when I figured out the magic formula things got real interesting.
JJ
• The hidden harmony is found with joy, while the obvious brings indifference.
• The farther you enter into the Truth the deeper your conviction for truth must be.
• There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is offline
Old 03-06-2011, 05:00 PM   #440
GeoAggie
GeoAggie's Avatar
Oddometer: 271
JJ
Is there an OVAD for camheads? Thanks JJ . . . . . .
GeoAggie is offline
Old 03-06-2011, 05:26 PM   #441
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,090
In a word, no.
One of the trends that BMW has been pursuing is to reduce or eliminate the technicians expertise (or lack of same) in maintaining their bikes. With camheads, dual channel EFI, CanBus, and other improvements the need for exactitude of adjustments has been significantly reduced. Remember surging and how BMW claimed it was a lack of proper attention to detail in maintenance? Well with the march of improvements the need to have to fuss with the knobs is greatly reduced. But so is the ability to dial in some of those adjustments to within a knats ass.
In short the techniques that OVAD brought to the table can't be applied to the camheads. But then some might argue/suggest that, that degree of pickyness (anality) isn't necessary. Perhaps. We'll never know because unless someone wants to go to the trouble and expense and time and effort to find out, it's simply out of reach by any other means.
But if I were to own a camhead I might attempt to apply the lessons learned in OVAD, but it would be a PIA because I'd have to purchase a bunch of button shims and go to town on matching them to the engine, valve by valve. And only after the engine had been fully broken in.
But you know what? I'd bet that, after I got thru matching each valve in a set, that engine would sing… Because that is the end result of what OVAD is all about. Getting that engine to optimally breath.
JJ
WingMakers.com
johnjen is offline
Old 03-06-2011, 05:56 PM   #442
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,912
In a word, no.
JJ
Based on a few that I have done, one over the weekend in particular, I tend to agree. Fortunately most Camheads seem to have very precisely matched valve clearances based on my limited experience. This weekend I found my first Camhead out of factory tolerance, and the first with not precisely matched clearances. Based on a single bike, the smoothness of the bike was a little off from the Camhead "norm" in my experience.
Jim
JimVonBaden is offline
Old 03-06-2011, 06:13 PM   #443
GeoAggie
GeoAggie's Avatar
Oddometer: 271
Jim
Is the throttle body sync procedure the same for camheads . . . . I would assume so? Jim - Is this covered for camheads in your maintance DVD? Thanks,
Jeff
GeoAggie is offline
Old 03-06-2011, 07:21 PM   #444
JimVonBaden
"Cool" Aid!
Oddometer: 53,912
Jeff
Yes, it is the same as the Hexheads, and covered.
Jim
Old 03-06-2011, 09:11 PM   #445
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,332
JJ
I did that the last time I checked the valves on my K1200R. They were all within the "normal" range but not equally. I bought half a dozen shims.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline
Old 03-06-2011, 10:57 PM   #446
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,090
So did you notice any changes/improvements?
JJ
WingMakers.com
johnjen is offline
Old 03-06-2011, 11:04 PM   #447
Jason1202GStime!
Jason1202GStime!'s Avatar
Oddometer: 251
Hey guys,
Just curious, recently i just checked the Throttle sync with a carbtune.
The reading form the Carbtune shows that both bodies are very balance, so i did not tune it.
However, i am experiencing rough idling every time when i start the bike.
Is this normal? Or is there something which i am missing?
Sorry for the poor english..
Jason1202GStime! is offline
Old 03-06-2011, 11:27 PM   #448
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,090
Check your valve gap clearances first. (adjust as necessary)
Then check the Throttle Body synch.
If that doesn't clear up the problem look for air leaks in the intake system.
JJ
WingMakers.com
johnjen is offline
Old 03-07-2011, 05:36 AM   #449
JimVonBaden
"Cool" Aid!
Oddometer: 53,912
JJ
I'll let you know when the new shims are installed.
Jim
Old 03-07-2011, 05:56 AM   #450
slipknot
slipknot's Avatar
Oddometer: 851
Ste
Has anyone used this?
http://www.cbperformance.com/catalog.asp?ProductID=572
Say what you will about the South but no one retires and moves up North.
"Ahhhh marriage, it's all in the execution." Henry VIII
slipknot is offline
Closed Thread
Times are GMT -7.   It's 11:22 PM.
