Closed Thread
Old 03-17-2011, 07:08 PM   #571
Babo
Babo's Avatar
Oddometer: 253
Originally Posted by Poolside View Post
Thanks, I forgot to mention. I somehow thought it was obvious.
When the bike is moving, the sensor sees always the ambient air temperature.
No matter where the sensor is, it always gets ambient air temp. No matter if it's under the seat, behind the fuel tank panel, inside the airbox, or up in front of the steering head. It's all the same temp when the bike is moving.
Once the bike starts moving, the hot air that collects when stopped is immediately replaced by moving ambient air.
The sensor may see ambient air temps immediatly, but the ecu certainly dooes not. Have you had the opportunity to measure the AIT temp to ECU temp reading delay? Have you done this in hot weather at a stop light, or going over a mountain pass?
There are compelling reasons why your competitors are using external sensors.
Babo is offline
Old 03-17-2011, 07:24 PM   #572
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
What? The signal travels down the wire at the speed of light.
Yes mine's faster because the wire is shorter.
Yes, that is how I measured ambient vs. IAT. While riding with a GS-911 hooked up to a laptop logging data.
I get how compelling beliefs are...
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline
Old 03-17-2011, 07:43 PM   #573
Babo
Babo's Avatar
Oddometer: 253
Why do you make light of my my questions? Are you afraid of dialog?
Babo is offline
Old 03-17-2011, 07:43 PM   #574
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Originally Posted by einnar View Post
Appreciate all the mental power you've put into this, and the commitment it takes to put your product out to the rest of us comparatively underpowered riders. (mentally that is, as I don't really follow everything you're doing...)
Here's a direct question for you... I have a 2009 R1200GS. I mostly do long distance touring, with some light offroad once I get where I'm headed. I don't thrash it, race it, etc. Is this still a product that will prove beneficial to me in the long run? How will it affect fuel economy? Will the "butt dyno" really notice right away?
Thanks.
You'll notice the greatest performance increase where you actually use the engine most.
You may twist the throttle a little more because it's more fun, so you might use a little more gas when doing that.
It won't change your mileage during cruise.
Poolside is offline
Old 03-17-2011, 07:48 PM   #575
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
That was dialog. The temperature difference thing is only a belief system. And I conducted tests to prove it, and that included proving it to myself since I was believing it too. Are you afraid of facts?
Poolside is offline
Old 03-17-2011, 07:57 PM   #576
wrysingfeenix
Dust off those ashes
wrysingfeenix's Avatar
Oddometer: 638
Poolside...
It is apparent to me that the patience required to delve into this project may be exceeded by the patience required to put up with the "dialog" that has occurred here at times.
It's more patience than I have, and I have the patience of a Saint.
No matter what my wife says.
Good on you...
That was dialog. The temperature difference thing is only a belief system. And I conducted tests. Are you afraid of facts?
'99 BMW R1100GS, '09 Vespa GT200,
'80 Honda CB750 Street Tracker
wrysingfeenix is offline
Old 03-17-2011, 08:01 PM   #577
Johnny Dakar
Fuckin' Smartass
Johnny Dakar's Avatar
Oddometer: 14,169
If it's under water, yes.
Hey JD, did you order one of these yet?
What if you're riding in a buttload of rain, and it's consistently wet?
And no, I haven't. Few other priorities above it on the "to buy" list.
"Just sharing this quiet time is intimate, our tent, our bikes and our faces illuminated by yellow light from the fire. This is why we travel. To experience those rare moments of perfection of solitude of life."
-Simon Thomas
Johnny Dakar is offline
Old 03-17-2011, 08:38 PM   #578
Babo
Babo's Avatar
Oddometer: 253
Is this the test you're referring to? In your garage?
I have been waiting for that question "Does the location of the air temperature sensor make a difference?" The short answer is, no, it doesn't.
When the bike is moving, the sensor always sees the ambient air temperature.
It's easy to imagine that putting the sensor up near the steering head gives it a supply of cool air. Though just because it's easy to imagine doesn't make it true. I admit I wanted it to be true.
Seems like a reasonable question. I mean, seeing as how some of the competitor products have the sensor mounted up near the steering head/instrument cluster. Of course I had to find out.
It was a mild evening last August. The plan was to make a high speed run on the freeway, then take some temp measurements while the bike was idling. Ambient temperature was 70°F, and since it was evening there would be no influence from solar radiant heating.
I set up for the test and took off on a run up the 405 freeway from Long Beach to UCLA/Westwood. The 28 miles of freeway in 19 minutes, so the motor was good and warm.
I pulled off the fwy and quickly pulled into a waiting garage. The door was shut to eliminate any breeze, and the bike was left idling on the centerstand while we started logging measurements.
In preparation for the experiment, I had relocated the original Intake Air Temp sensor from the airbox to the area in front of the steering head.
First thing after pulling into the garage the bike is put on the centerstand, then pull off the saddle and connect to a waiting GS-911 and laptop to take temp readings. No cooling fan was used.
The setup process took no more than 30 seconds. The ambient temp in the garage was 70°F but already the IAT reading was 86°F. Remember, this was the ECU's reading from the relocated IAT sensor, mounted in front of the steering head.
The motor idled along happily with the headers turning red while the ECU gave these temp readings via the GS-911.
   IAT         OIL
   86.0    228.2
   87.8    230.0
   91.4    230.0
   93.2    231.8
   93.2    233.6
   95.0    235.4
   96.8    237.2
   98.6    239.0
   98.6    242.6
100.4    242.6
100.4    244.4
102.2    244.4
102.2    248.0
104.0    248.0
104.0    249.8
105.8    249.8
107.6    253.4
I shut it down at that point, figuring 250 degrees was hot enough for the oil.
So there it is. Ambient air temp was 70°, and after a few minutes the relocated sensor was reading 38 degrees higher at 107.6°
For comparison, I did this experiment 2 more times. Once with the IAT sensor in the factory location in the airbox. And once more with the sensor resting on top of the airbox, with the saddle in place.
Result: The ECU sees the same temperature regardless where the sensor is mounted.
Wait, that's not entirely true. With the sensor placed on a table 5 feet away, the ECU always reads the same intake temperature. (I actually did that with an extension wire on the sensor.)
Conclusions: No matter where you put the sensor, there's no way to escape the heat when you come to a stop.
And once the bike starts moving, the hot air that collects when stopped is immediately replaced by moving ambient air.
Babo is offline
Old 03-17-2011, 08:48 PM   #579
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,090
Poolside,
snip
Thanks.
Let me add a thought or two to this.
One way to look at what these modifications are doing is they will shift the way the fuel injection system operates DURING ACCELERATION. These mods change the EFI's response from its 'stock' efficiency mode to a power mode of operation.
And what I have observed when this is achieved is, the fuel economy can actually increase because you don't need to use as much throttle to get the same rate of acceleration.
This may seem counterintuitive but when the engine makes power as optimally as it is capable, then the overall efficiency ESPECIALLY DURING ACCELERATION is improved.
And it should be noted that most of the time when we are running down the road (ie. touring) in a steady state condition, (aka closed loop operation) and not accelerating nor decelerating to any great extent these mods will have no effect.
Now if you get overly enthusiastic with the go fast handle, then yes your mileage will be reduced, but that is true with or without these mods in place. Only with the mods, the fun factor is considerably enhanced.
As for the 'butt dyno' effect. Where you'll notice it is in the directness and immediacy of the response of the engine to throttle inputs. A good deal of vagueness and delay will be replaced with an immediate torque reaction from the engine.
JJ
• The hidden harmony is found with joy, while the obvious brings indifference.
• The farther you enter into the Truth the deeper your conviction for truth must be.
• There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is offline
Old 03-17-2011, 08:54 PM   #580
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,090
Actually if anything, having that remote sensor probe encased in metal will slow down the response. What with the added mass of the metal that would need to be cooled down after getting hot while at a stop light. So I'm not sure if that is a benefit or a hindrance at least in terms of the immediacy of response to ambient temp changes.
JJ
WingMakers.com
johnjen is offline
Old 03-17-2011, 10:11 PM   #581
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Careful Babo, the planet is about to be eaten by a giant space goat!
Poolside is offline
Old 03-17-2011, 10:53 PM   #582
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,090
Is that another belief?
JJ
WingMakers.com
johnjen is offline
Old 03-18-2011, 05:19 AM   #583
J-Dub
Combat Commuter
J-Dub's Avatar
Oddometer: 279
Poolside and JJ,
I've read the entire thread, and I may have missed it, but does altitude have any effect on the operation of this device, i.e., enrichening/leaning the A/F ratio? I'm thinking about fouled plugs, but maybe I've been messing with my old Triumph too much.
J-Dub is offline
Old 03-18-2011, 09:47 AM   #584
einnar
einnar's Avatar
Oddometer: 175
Thanks guys!
JJ
An amateur practices until they get it right. A professional practices until they can't get it wrong.
Det finns inget dåligt väder, bara dåliga kläder
einnar is offline
Old 03-18-2011, 10:14 AM   #585
Babo
Babo's Avatar
Oddometer: 253
JJ
I'd much rather have remote sensor encased in thin metal than a sensor buried under plastics that is subject to the bikes radiant heat. A trade-off I'm sure, and perhaps inconsequential.
FWIW, I've tested the responsiveness of a remote sensor (boosterplug) with a GS911 and found that temp changes are almost instantaneous - certainly as quick as the AIT anyway.
Regardless, there are other reasons why some vendors use a sensor in addition to the stock AIT, and there are successful vendors that don't...does the IICE Air use one?
Babo is offline
Closed Thread
Times are GMT -7.   It's 09:38 AM.
