Closed Thread
Old 11-22-2010, 07:10 AM   #46
wgrant
Rambler
Oddometer: 8
Originally Posted by Poolside
The primary problem with the Mono Jetronic is that BMW used it to control 2 injectors with a single injector signal.
I did not know that. It really helps to explain (and the SINGLE throttle cable) some of the undesirable characteristics of the engine.
I even installed a Rhinewest chip, but probably couldn't pick the Rhinewest chip in a blind test.
I hope you guys crack the code.
wgrant is offline
Old 11-22-2010, 07:32 AM   #47
Geoffster
Fool - Born This Way
Geoffster's Avatar
Oddometer: 1,373
Will there be an OS X version? I have an extra MacBook Pro I can duct tape to my fuel tank.
Consider this before arguing with me:
You're an idiot if you argue with a fool!
http://www.flickr.com/photos/geoffster/sets/
Geoffster is offline
Old 11-22-2010, 08:24 AM   #48
Monroe
Monroe's Avatar
Oddometer: 678
following with interest, good luck gentlemen
Steve
Monroe is offline
Old 11-22-2010, 09:11 AM   #49
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,524
You bet. Not so pie-in-the-sky as you might think. You can get virtually the whole way there with external mods.
That 16 year old Motronic was born in the 80's. The version in the 1100/1150 is called a Mono Motronic It was designed for throttle body (single injection point) fuel injection systems. It was re-labeled simply Motronic as the OE product for the BMW boxer motor.
Because of the 180° opposed cylinder arrangement on the boxer motor, the Mono Motronic ECU can be operated as if it's controlling a single cylinder motor running at twice the RPM.
The primary problem with the Mono Jetronic is that BMW used it to control 2 injectors with a single injector signal. The method is commonly referred to as batch injection. It is sort of like wasted spark ignition, only for fuel.
That's ok for spark control, but it leaves a lot to be desired from a fuel control point of view.
Poolside so this explains what is wrong with the present system. Can you explain what a perfect or ideal system would do.
Say you had no limitations what would you build to make a perfect control unit? Would you have more sensors to make more accurate calculations and more accurate fuel delivery in conjunction with timing changes?
Would it disregard pollution standards and go for performance only?
Does another mfgr do it better already?
Does the boxer do the wasted spark method on the ignition? I had a Pontiac V6 that did the wasted spark. I think they said it sparked the coil of the charged (firing) cylinder and the opposing cylinder at the same time and more spark went to the charged cylinder because it had less resistance.
This is interesting!
scooteraug02 is offline
Old 11-22-2010, 05:22 PM   #50
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,047
And for a hell of a lot less time and money spent on getting it working in the first place, let alone the time spent dialing it in, from scratch.
It along with most (if not all) of the early EFI systems were single channel or 'simplified' systems. Mostly because of the limitations of the available technology back then. My Volvo 164 had 3 paired injectors so even though it was a 6 cylinder engine it only 'knew' about 3 cylinders, sorta, kinda.
Another 'limitation' is the overall 'resolution' of the early EFI systems. Sensor inputs and processing power were crude by todays standards. So getting the older systems to step up and effectively deal with todays emission standards required 'creative' solutions. Translated into BMW speak they are called 'driveability issues'.
JJ
• The hidden harmony is found with joy, while the obvious brings indifference.
• The farther you enter into the Truth the deeper your conviction for truth must be.
• There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is online now
Old 11-22-2010, 05:35 PM   #51
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,047
We will write up a simplified explanation of some of the functions of a 'modern' EFI system in parts. Each will be a piece of the whole and will give a glimpse into what our solution to that functional area will be.
But a complete write up of an "ideal system", no probably not. That is WAY beyond the scope or time available for both of us combined.
There are a variety of different solutions to the complex process of combustion as it needs to be applied given todays rules and regulations. To bring even a portion of this up in enough detail would take a lot more time than would be possible right now. Needless to say we need to spend it getting the devices sorted out and ready for production.
Yes boxers use the wasted spark method. Vintageheads, Airheads, early Oilheads, Hexheads, Buttonheads, all of them.
And the real interesting stuff is still yet to come.
JJ
WingMakers.com
johnjen screwed with this post 11-22-2010 at 06:46 PM
Old 11-22-2010, 05:52 PM   #52
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,512
Originally Posted by johnjen
Yes boxers use the wasted spark method. Vintageheads, Airheads, Oilheads, Hexheads, Buttonheads, all of them.
JJ
That's not what Poolside said in this post.
marchyman is offline
Old 11-22-2010, 06:45 PM   #53
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,047
OOpps. My bad.
The dual channel 1200 EFI shouldn't be on that list.
JJ
WingMakers.com
Old 11-22-2010, 07:17 PM   #54
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,079
JJ
Konstant Fahr Ruckeln, perhaps?
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline
Old 11-22-2010, 07:41 PM   #55
hasenwerk
hasenwerk's Avatar
Oddometer: 1,323
Poolside,
That looks like the MegaSquirt system... way to go! There will be smoothness and power to be found in that system for sure. Way to go for starting down that trail - I look forward to your progress and benefiting from the results!
To everyone else... if it is the MegaSquirt sytem Poolside is working on, no, Windows isn't going to be running on your bike! It a micro-controller based system and it is little more intelligent than the MonoMotronic system on the 11x50 bikes now - the Windows box would be there for monitoring and fine tuning. The MegaSquirt system is quite the setup!
David Marshall - Quesnel, BC, Canada - fastforward.ca
2006 BMW F650 "YZ" Dakar | 2013 BMW G650 "YZ" Sertao
hasenwerk is offline
Old 11-23-2010, 01:11 AM   #56
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Ja. Konstant Fahr Ruckeln ist farfomgroovin.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline
Old 11-23-2010, 01:17 AM   #57
Dan Căta
Dan Căta's Avatar
Oddometer: 1,667
So... will it replace the motronic or will it run among it?
When will you release the product?
Dan Căta is offline
Old 11-23-2010, 01:17 AM   #58
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Originally Posted by marchyman
That's not what Poolside said [about the 1200] in this post.
The 1200 has its own set of problems. The more modern ECU in the 1200 runs an even more aggressive EPA/EC emissions profile. The 2 cylinders on the 1200 are operated as two different motors. Though they're operated separately, they share two things, the crankshaft and the catalyst.
The ECU on the 1200 uses control algorithms too complex to get into here. I'll just say that it's both worse and better than the 1100/1150.
Poolside is offline
Old 11-23-2010, 01:21 AM   #59
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Yes, it will run amok. I mean, it will operate along with the ECU.
Info about the release date will be in the next post or two.
Poolside is offline
Old 11-23-2010, 07:34 PM   #60
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,047
Originally Posted by hasenwerk
Poolside,
Nah it isn't the MegaSquirt. That's so yesterday.
And from what I understand it would take so many custom parts to interface the 2 systems it would almost be easier just to start over.
Besides we dun got ourselves a reel ottermotive genius work'n on this here project. We don't need no stink'n mega squirt…
And remember this is for the backyard mechanic so we have designed it to be easy to install and use.
JJ
WingMakers.com
johnjen screwed with this post 11-24-2010 at 12:37 AM
Closed Thread
Times are GMT -7.   It's 02:38 AM.
