Old 05-18-2011, 06:28 AM   #811
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,286
Originally Posted by Hollow Road Rider View Post
[Where] are my [mounting] options on my GS/A?
(I hope you got the Steve Martin movie joke. "Just in this little area here.") Seriously though, you mount the IICE Air in the general vicinity of the air box air temperature sensor. There's about 8in/200mm of harness.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List
Poolside is offline   Reply With Quote
Old 05-18-2011, 06:45 AM   #812
Hollow Road Rider
Hollow Road Rider's Avatar
Oddometer: 190
Got it! I'll have to put it between the Chickletts and under the thimble... should fit just fine.
Hollow Road Rider is offline   Reply With Quote
Old 05-18-2011, 12:45 PM   #813
Monsignore
Plunger Boy
Monsignore's Avatar
Oddometer: 651
I'm assuming that would be where the red arrows are in the diagrams on this page?
Adversity + Time = Adventure
To be old & wise, you must first be young & stupid.
Monsignore is online now   Reply With Quote
Old 05-18-2011, 04:45 PM   #814
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,286
Cool! I think you've just found our installation guide.
Yes, the red arrows point to the connector on the temperature sensor.
That info page has some good pictures of the competitive products. Not much actual information, though it does validate many widely held beliefs.
Old 05-22-2011, 07:59 AM   #815
Boxerwrench
Boxerwrench's Avatar
Oddometer: 106
I wonder if it is the same for us antique R1100RT owners.
Feeling like owning one as I watch vendor accessories and farkels disappear.
2000 R1100RT, Opel blue
2006 Zuki C50 w/ modified C90 drive.
Boxerwrench is offline   Reply With Quote
Old 05-23-2011, 04:20 AM   #816
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,286
Here are all the parts from Wednesday last week. I started building that night.
Old 05-23-2011, 04:34 AM   #817
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,286
Assembly report.
I figure many of you might be interested in the steps involved during assembly.
Off to a roaring start on Wednesday night! First solder the header to the board.
Wait. What the heck is going on with that white jumper!?
Apparently this little jumper is made from a brittle plastic. Dang.
There are other jumpers of course, but the tabs are not all the same size. As you can see here.
The blue jumper trims down with a razor. Adding an assembly step.
This will work fine. Order and trim 159 more of these blue jumpers.
Poolside screwed with this post 05-23-2011 at 05:23 AM
Old 05-23-2011, 05:19 AM   #818
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,286
Assembly report.
This plastic vial is originally about 3.5in. It must be trimmed down to the length shown here.
The bottom must be flat, or very nearly so. Not like in the picture. The cut in the picture below was made with a box knife.
YOU'RE DOING IT WRONG!
I spent a day and a half rigging up a router table fixture to make a nice clean and quick cut on the vial. As you can see, the cutting tool grips the plastic and tears it. What's going on is, the polyethylene plastic doesn't cut readily, and the tool just grabs ahold of it.
Back to the drawing board on Saturday.
Old 05-23-2011, 05:42 AM   #819
Hollow Road Rider
Oddometer: 190
Have you tried a band saw?
Old 05-23-2011, 06:19 AM   #820
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,491
Or a simple hobby saw and mitre box:
About $15
Jim
Old 05-23-2011, 06:36 AM   #821
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,286
Thanks for the tips guys. Great minds and all that!
A buddy and I went milling around in the hardware store trying to figure out some reasonable way to cut those plastic vials. He comes up with a great idea to cut the vial with a hacksaw, and use a stack of standard 5/8" washers for the cut length.
I figured the cut length needs to be adjustable, so I add the threaded fasteners to adjust the spacing.
This has some potential.
Looks about right.
Just might work.
Holding the saw blade against the washer is easier than it looks. Zips right through in about 2 seconds flat.
This is promising.
There's quite a burr there.
That burr doesn't just flake off. The kerf from the cut is still attached to the main body.
The material isn't so much cut as just bulldozed around the corner.
The excess plastic must be removed with a razor or exacto knife. Ever try and run a razor around the outside of a soft plastic round? I try a few and find that it's going to be too time consuming.
Back to the drawing board on Sunday. I'm rattling around the shop trying this and that, looking for some ideas. I give JJ a call about 7pm. And we start what turns out to be a 2-and-a-half hour marathon con-fab!
We tried lots of different things, razors, cutters, and more razors. And there was much comic relief to be had. JJ says, "Try doing that." I say, "Ouch!" He says, "That didn't work eh?"
Finally JJ convinces me that I should use a hot wire cutter. Convince is probably the wrong word. Really, there was nothing left for me to try. It should be noted that JJ first suggested using a hot wire cutter right after I selected the plastic vial as part of the design. And I was convinced a hot wire cutter wouldn't work.
At this point, the only trouble is I don't have a hot wire cuter. Not to fear, I grabbed the propane torch and a box knife blade! (This was also probably JJ's idea from a while back.)
Pictures and band-aids to follow. I'll get some shots up later tonight.
Poolside screwed with this post 05-23-2011 at 06:43 AM
Old 05-23-2011, 06:39 AM   #822
jbdesigns
jbdesigns's Avatar
Oddometer: 80
Make up a mandrel out of wood that slip fits the plastic tube. An exacto knife blade in a holder cuts the plastic as you rotate the mandrel. Blade is on pivot so it is rotated into position for cut and swung out of the way to remove cut piece and reload the next "victim". This will make a good clean cut. Could also use new utility blade if a stiffer blade ( and bigger blade) is desired. Might be easier to rig up with a clamping block to allow a blade change every 20 or 30 cuts.
Think "manual lathe". I believe you could rotate the plastic tube by hand grasping the cap end. The open end buts up against a stop for getting the length right each time. Your other hand puts pressure on the cutting blade holder while you rotate the tube. Maybe three time around it should be cut through. No burrs or trimming needed.
"Governments first duty is to protect the people, not run their lives" Ronald Reagan
jbdesigns is offline   Reply With Quote
Old 05-23-2011, 06:51 AM   #823
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,286
You and JJ are reading from the same playbook!
It turns out the friction against the blade from that sort of cut into soft plastic is too considerable for a simple fixture. The torque required to turn the vial is enough to deform the tube shape, and the cut starts to walk.
Along those lines, a pipe cutter or pizza cutter 'wheel knife' might work. I'm pretty sure we've got it sorted it out using a propane-heated box knife blade, held with a small vice-grip.
Old 05-23-2011, 06:56 AM   #824
JimVonBaden
"Cool" Aid!
Oddometer: 41,491
How about a PVC tubing cutter?
Might be the soft plastic will deform too much, but maybe not. Definitely a burr free cut.
Jim
Old 05-23-2011, 06:57 AM   #825
Jason1202GStime!
Jason1202GStime!'s Avatar
Oddometer: 239
Did you try cutting it with a really hot knife???
Jason1202GStime! is offline   Reply With Quote
Times are GMT -7.   It's 10:48 AM.
