Closed Thread
Old 05-23-2011, 07:12 AM   #826
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Originally Posted by JimVonBaden View Post
How about a PVC tubing cutter?
Might be the soft plastic will deform too much, but maybe not. Definitely a burr free cut.
Another good idea. An anvil cut, similar to the PVC cutter, was my initial plan. But unfortunately it just deforms the plastic and the cut walks. Boooo!
The cut must deform the plastic because no material is being removed, and the blade takes up space. Look closely at how un-square and un-flat the cut edge of a PVC pipe is. Sure you can get lucky and hold the cutter juuuuust right and get a pretty square cut once in a while. This has got to be repeatable.
We went the flames and knives method. It does a good job and there's no need to deburr the cut. Thanks just the same for your ideas everyone!
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline
Old 05-23-2011, 07:38 AM   #827
jbdesigns
jbdesigns's Avatar
Oddometer: 91
Good for you. I only posted cause I don't want you guys hung up. Glad to hear your moving forward again. I want my part. I rode my buddies 06 multistrada with new pipe and chip work. It was definitely better accelerating than my 1150gsa (although it is much less mass than my bulky GSA). I want more peppiness. I don't have to have just as quick, just want to close up the gap.
"Governments first duty is to protect the people, not run their lives" Ronald Reagan
jbdesigns is online now
Old 05-23-2011, 10:05 AM   #828
chopperdoc60
chopperdoc60's Avatar
Oddometer: 30
Do you have a buddy the builds homebuilt airplanes? You can try a hotwire rig they use for cutting and shaping the foam core. That might work with your jig, just hot wire the bottom off nice and flush!
Brew your own damn beer!
chopperdoc60 is offline
Old 05-23-2011, 01:59 PM   #829
David_Moen
David_Moen's Avatar
Oddometer: 1,293
Hot wire cutters are dead easy to rig, all you need is a method to pull the wire tight, and a means to regulate the power, as someone mentioned if you know a R/C home-builder, you can probably borrow it ready-built.
I would use a rotary cutter though. My wife has one in her quilting tackle, when I was building planes it regularly made midnight trips to my shop for cutting mylar covering.
Like this:http://www.olfa.com/RotaryCuttersDetail.aspx?C=20&Id=70
Hellaciously sharp, and with your jig, I would think would make a very nice job of the cut for $15.00 or so.
2013 KTM 350EXC-F, 2005 BMW R200GS, 1984 Kawasaki GPz 750
David_Moen is offline
Old 05-23-2011, 05:06 PM   #830
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Thanks again for your ideas everyone. If these IICE Airs do get built again, many of the assembly processes will benefit from retooling. Or at least a retool of optimistic estimates Seriously though, to make one or two of something, like a hobby item for example, it's easy to invest hours in the build process. Acourse to build 100-plus of something, that's a different story.
Electrically it was easy. Mechanically, that was the problem. You know, it's a complex set of mechanical specs. Part of the shape needs to be exposed to the air, and another part must be watertight. The watertight portion needs to be easy-open with a durable seal mechanism. And whatever you two geniuses come up with for an adjustment mechanism, it must fit inside the watertight portion. Oh yes, you must use a very small standard enclosure, with a mounting flange(s) for zip ties.
Somehow it all got figured out. Only now I have to build it.
You should have heard JJ and me talking at the beginning of this project, and all along during the process. Talk was rife with things like "it'll be easy", "we'll just...", "no problem", and the dreaded "I'll cross that bridge when I come to it." That one is a killer.
Poolside is offline
Old 05-24-2011, 05:21 AM   #831
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Assembly report.
As promised, flames and knives.
Makes a nice cut.
A real nice cut.
I did a little assembly marathon today, and my hands hurt! I'll check in later.
Poolside is offline
Old 05-24-2011, 05:48 AM   #832
jbdesigns
jbdesigns's Avatar
Oddometer: 91
Great job on the cut. Now take some advil and get back to work!
Old 05-24-2011, 05:55 AM   #833
gratefulJED
long strange tripper
gratefulJED's Avatar
Oddometer: 1,889
Originally Posted by Poolside View Post
...and the dreaded "I'll cross that bridge when I come to it." That one is a killer.
The killer one is "I'll drive off that bridge when I come to it"
Can't wait for the finished producto
"The liberties of a people never were, nor ever will be, secure when the transactions of their rulers may be concealed from them." - Patrick Henry
gratefulJED is online now
Old 05-24-2011, 02:04 PM   #834
ghostrider1964
Edumacated Red Neck
ghostrider1964's Avatar
Oddometer: 6,926
Assembly report.
Makes a nice cut.
A real nice cut.
All ya had to add was guns and it would have been a party Need me to come help ya...I am a first rate fabricator of the official Redneck School
2008 R1200 GSA (Ghostrider), G650 X/Challenge
"Fuck'em. I'm a lifer. " SlowOldGuy
"The older I get, the faster I was", HardyBaker
TEXAS-ROLL THE BONES RALLY 6 10/23-10/25/2015: ?.......
http://www.rollthebonesrally.com/
ghostrider1964 is offline
Old 05-26-2011, 04:16 PM   #835
dsrydr
dsrydr's Avatar
Oddometer: 273
dsrydr is offline
Old 05-26-2011, 04:25 PM   #836
Cranky Yankee
exulcero
Cranky Yankee's Avatar
Oddometer: 602
HR has been flooded by complaints followed by claims to the insurance company for disability.
Oh, wait...
“How much easier it is to be critical than to be correct.” – Benjamin Disraeli
Cranky Yankee is offline
Old 05-30-2011, 06:14 AM   #837
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Assembly report.
I'm about 1/3 of the way done with the done-as-a-full-batch processing. Many of the remaining steps are done in small batches of five or so. The units will be shipped in medium-sized batches as they are finished, maybe 20 at a time. I'll be working on them later this afternoon. And I'm going to try and take one unit the rest of the way through the assembly steps to the last step, partial encapsulation in epoxy. That's the most important step and I need to verify the encapsulation process goes smoothly.
Enjoy your Memorial Day. Cheers!
Poolside is offline
Old 05-30-2011, 07:32 AM   #838
Jim Moore
Jim Moore's Avatar
Oddometer: 13,909
Hey, I'm planning to trade my GS for an R1100S. Will the contraption still work?
Jim Moore
Jax, FL
Pay the lady, PirateJohn, you thieving piece of garbage.
http://advrider.com/forums/showthread.php?t=949341
Jim Moore is online now
Old 05-30-2011, 07:56 AM   #839
pigfixer
Oddometer: 94
Yes it will work
pigfixer is offline
Old 05-30-2011, 12:47 PM   #840
Shortguy on BMW
Shortguy on BMW's Avatar
Oddometer: 127
You can get a hot knife blade for a soldering gun.
Shortguy on BMW is offline
Closed Thread
Times are GMT -7.   It's 03:47 AM.
