Closed Thread
Old 06-01-2011, 09:26 AM   #856
David_Moen
David_Moen's Avatar
Oddometer: 1,309
Nope, "second unit" is the ICECool (sorry if I mangled the name) that fiddles with the fuel mixture based on oil temp/pressure inputs.
2013 KTM 350EXC-F, 2005 BMW R200GS, 1984 Kawasaki GPz 750
David_Moen is offline
Old 06-01-2011, 10:00 AM   #857
ausfahrt
mach schnell
ausfahrt's Avatar
Oddometer: 1,829
Originally Posted by dirtybikefrank View Post
My bike is ready to go faster....just sayin.
You can always count on the Americans to do the right thing, after they have tried everything else.
-Winston Churchill
ausfahrt is online now
Old 06-01-2011, 06:23 PM   #858
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Originally Posted by grpweld View Post
If I recall correctly the second unit will be for 1100"s & 1150's correct?
You're both right. The second product, the IICE Cool, has two versions. One for the 1100/1150 and the other for the 1200.
The 1100/1150 version will arrive first, as it's already designed. What I mean by that is, the functional prototype works great. It's been on a couple of bikes, and I've been running it on my 1150 the whole time.
The second IICE Cool version, for the 1200, is a more complex device. Specifically, it intercepts and manipulates CANbus data. There's quite a bit more to the 1200 version. It has at least one microcontroller, and may have two.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline
Old 06-01-2011, 06:41 PM   #859
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Little help
I need to verify this measurement RT, and S models of R1200. Who can help?
http://www.advrider.com/forums/showt...8#post16048638
JVB got back to me and he'll get the info from his ST.
Poolside is offline
Old 06-01-2011, 07:23 PM   #860
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,043
Needed to take off the side pannel to get to it:
Since the tank pannel goes down a little further, you need a bit more length. The ST needs about 7.5", depending on where you plan to mount it. I suspect, based on your above info, that you can attach it to the blank brass nut pictured. It will have to be pretty small to clear the seat bracket and seat though, not pictured.
The RT configuration is different. This is the best photo I have at the moment:
Jim
JimVonBaden is offline
Old 06-01-2011, 07:50 PM   #861
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Thanks Jim!
Regarding where to mount it, looks like on the ST, ziptie the harness to the 'tinnerman clip' will work fine. I'll just go ahead and make the harness long enough to allow the end user some options. Like that brass insert nut you mention.
Between this RT picture and yours, looks like I got it covered. Thanks again big brother! Cheers.
http://www.ebbo.org/resistor_tuning/...mw_r1200rt.jpg
Picture from Ebbo.org
Poolside is offline
Old 06-01-2011, 08:00 PM   #862
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Little help
I need to verify this measurement on the R1200 S model. Who can help?
REGARDING THE S MODEL:
Specifically, when the seat is removed on the S, there is far less of the airbox visible.
The tank cover wraps most of the way around the back and side of the tank. It looks like the tank cover might be cut away right where it meets the front of the seat. If there is a cutaway in the S tank cover, exposing part of the airbox, it's obviously far less of a cutaway than on the R, RT, ST, and GS models.
On the S, it looks like there may be enough room at the trailing edge of the tank cover, once the seat is removed.
It would be nice to figure a place to ziptie the IICE Air so that you can get to it either by removing the seat, or in the case of the S model, the small side panel under the seat/tank interface.
Poolside is offline
Old 06-01-2011, 08:13 PM   #863
JimVonBaden
"Cool" Aid!
Oddometer: 54,043
Originally Posted by Poolside View Post
Thanks Jim!
That will work, you just wont be able to get to it without removing the body pannels!
Jim
Old 06-01-2011, 08:13 PM   #864
Cranky Yankee
exulcero
Cranky Yankee's Avatar
Oddometer: 602
It cuts ok, but there's the deburring. And it isn't just the deburring, it's leftover the 'chips' from cutting the plastic. The tiny chips static cling onto the vial, and get up into the cap seal.
... This plastic is just too soft.
For the chips just give the batch after cutting a good wash and rinse in plain Dawn dish soap and hot water (no softener!) and a good rinse. I used to give RF assemblies this wash with no residue problems as long as the drying is quick. (DI water rinse. )
For soft plastic - a trip in the freezer before cutting.
“How much easier it is to be critical than to be correct.” – Benjamin Disraeli
Cranky Yankee is offline
Old 06-01-2011, 08:34 PM   #865
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Yea that's what I want to do, the dishes! I appreciate the input just the same.
Re aqueous flux solder, and water rinse of PCB assemblies, that's the ticket. At one point I used a converted (read sacrificed) dishwasher.
Poolside is offline
Old 06-01-2011, 08:43 PM   #866
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Originally Posted by JimVonBaden View Post
That will work, you just wont be able to get to it without removing the body panels!
I didn't think the panels would need to be removed to get to the IICE Air and make an adjustment, but you're the one looking at the side and tank panels.
The device can be mounted via a ziptie to its own harness. The little enclosure is not much bigger than the Booster Plug enclosure.
Sure, to install it the tank cover on some models will need to come off, but not to adjust it. At least it sure doesn't look like it. From the pictures, there is plenty of room there for the IICE Air enclosure.
If I'm off base, let me know.
Poolside is offline
Old 06-02-2011, 06:57 AM   #867
JimVonBaden
"Cool" Aid!
Oddometer: 54,043
I assume there are some sort of dip switches or potentiometers on the unit that may need adjusting, correct? Also, it is about the size of a small relay? If so, on the ST, you may need to add another 8" of wire to place it under the seat to access it without removing the side pannel.
You can see by this photo how the side pannels will have to be removed to get to it, the blue pannel comes off with the silver one above it in one piece, and the lower one below the blue also is another that would have to come off. The bike can be ridden with them removed though. Under the seat is a bracket, not shown, that is placed over the battery and next to the tank that removes that space for mounting.
Like I said, no problem mounting under the pannel, but it makes access more difficult.
IIRC the RT isn't much better, but I don't have the bike to be sure.
Hope this helps.
Jim
Old 06-02-2011, 07:16 AM   #868
Geoffster
Fool - Born This Way
Geoffster's Avatar
Oddometer: 1,373
I think you'd want the same for the RT.
I had a 2005 RT, and procedure for "Tupperware" removal is confusing the first and second time, and time-consuming even after you learn it. I think it involves 13 screws for the first side, possibly more.
I got it down to 15 minutes to remove one side, and 15 minutes to reinstall. Another 10/10 minutes for the other side. Makes throttle body syncing a PITA.
Consider this before arguing with me:
You're an idiot if you argue with a fool!
http://www.flickr.com/photos/geoffster/sets/
Geoffster is offline
Old 06-02-2011, 08:11 AM   #869
Boxerwrench
Boxerwrench's Avatar
Oddometer: 106
Yup sure is.
You gotta take off the side panel to get access to the rear brake master cyl. too, at least I do.
Total plastic tear down is 39 screws....just for the tupperware.
more if ya go into the dash too.
If ya could relocate it to under the seat that would be great!
2000 R1100RT, Opel blue
2006 Zuki C50 w/ modified C90 drive.
Boxerwrench is offline
Old 06-02-2011, 10:06 AM   #870
AKmud
Muddy Gruver
AKmud's Avatar
Oddometer: 958
Just being lazy and not wanting to read back through all 870 posts.....
Riding an '08 1200GS....How much are you charging for these babies? Is this batch you are working on all spoken for or do you have some available?
AKmud is offline
Closed Thread
Times are GMT -7.   It's 02:47 AM.
