Closed Thread
Old 06-02-2011, 10:40 AM   #871
Boxerwrench
Boxerwrench's Avatar
Oddometer: 106
Originally Posted by AKmud View Post
Just being lazy and not wanting to read back through all 870 posts.....
Riding an '08 1200GS....How much are you charging for these babies? Is this batch you are working on all spoken for or do you have some available?
http://www.advrider.com/forums/showt...pre-order+sale
Think all 113 are pre bought.
2000 R1100RT, Opel blue
2006 Zuki C50 w/ modified C90 drive.
Boxerwrench is offline
Old 06-02-2011, 01:41 PM   #872
ghostrider1964
Edumacated Red Neck
ghostrider1964's Avatar
Oddometer: 6,860
Originally Posted by Boxerwrench View Post
Yup sure is.
You gotta take off the side panel to get access to the rear brake master cyl. too, at least I do.
Total plastic tear down is 39 screws....just for the tupperware.
more if ya go into the dash too.
If ya could relocate it to under the seat that would be great!
That was part of the reason I sold my 09RT...but I am more comfortable on my GSA
2008 R1200 GSA (Ghostrider), G650 X/Challenge
"Fuck'em. I'm a lifer. " SlowOldGuy
"The older I get, the faster I was", HardyBaker
TEXAS-ROLL THE BONES RALLY 6 10/23-10/25/2015: ?.......
http://www.rollthebonesrally.com/
ghostrider1964 is offline
Old 06-03-2011, 04:58 AM   #873
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Originally Posted by JimVonBaden View Post
Since the tank pannel goes down a little further, you need a bit more length. The ST needs about 7.5", depending on where you plan to mount it. I suspect, based on your above info, that you can attach it to the blank brass nut pictured. It will have to be pretty small to clear the seat bracket and seat though, not pictured.
If ya could relocate it to under the seat [on the RT model] that would be great!
So this doesn't turn into a big mess. Here's what I'm doing.
The standard harness has 9in/225mm of wire. On the 1200, according to the measurements I took, along with JVB's and others, that will easily get the IICE Air from the original sensor location, down to the top of the battery.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside screwed with this post 06-03-2011 at 07:16 AM
Poolside is offline
Old 06-03-2011, 05:47 AM   #874
Boxerwrench
Oddometer: 106
Eh?
The standard harness has 9in/225mm of wire. On the 1200, according to the measurements I took, along with JOBs and others, that will easily get the IICE Air from the original sensor location, down to the top of the battery.
which sits UNDER my 2000 1100RT tank
so it will make it non adjustable w/o a major tear down and might as well gotten a non adjustable booster plug.
Please find a way to get it under the seat
Boxerwrench screwed with this post 06-03-2011 at 07:52 AM Reason: odd format.
Old 06-03-2011, 06:00 AM   #875
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
I didn't read your post, did you say you had a 1200?
Poolside is offline
Old 06-03-2011, 06:05 AM   #876
Boxerwrench
Oddometer: 106
2000 R1100RT
MY battery and ABS reservoir are under the fuel tank.
access requires removal of ALL the tupperware then I can lift the tank.
Boxerwrench screwed with this post 06-03-2011 at 06:21 AM
Old 06-03-2011, 06:33 AM   #877
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
So you're not going to fit it to a 1200 then?
Poolside is offline
Old 06-03-2011, 07:06 AM   #878
Boxerwrench
Oddometer: 106
Question
I don't understand.
I do not own a R1200RT, I do not have plans for any R1200 ( no $$$ for one)
I own a R1100RT.
To use the adaptability of your device on my R1100RT it would have to have easy accessible.
This means to get at it easy it has to be under the seat or the bike has to be disassembled to get at it to make changes.
ordered early on, post #31
Boxerwrench screwed with this post 06-03-2011 at 07:13 AM
Old 06-03-2011, 07:31 AM   #879
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
I don't understand.
I do not own a R1200RT, I do not have plans for any R1200.
Alright, that picture is just too cute! Nice doggy!
You don't understand? How do you think I feel?
My harness length post was referencing the 1200, not the 1100/1150. You don't need to connect to the battery to connect the IICE Air. It only connects to the Air Temperature Sensor on the top of the airbox.
On all the 1100s and 1150s, the top of the airbox is right there under the seat.
The harness is 9in/230mm so it will fit the 1200s. And it will reach from the top of the 1200 airbox, to the battery. Which on the 1200s, is right there under the seat.
Poolside is offline
Old 06-03-2011, 07:39 AM   #880
Boxerwrench
Oddometer: 106
Whew!!! Glad I am on the same page w/ you now!
I didn't want to start anything, sry, shoulda read more closely!
BTW that's a cat and a few weeks after that pic I had to let him go to the universe.
Too many Illnesses at the same time.
He was 14 and his name was Teddy the Biker Cat.
Old 06-03-2011, 07:42 AM   #881
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Yaaaayyyy! Were all on the same page now. Good deal.
Looks like he was one lucky cat. Sail on Teddy!
Poolside is offline
Old 06-03-2011, 09:48 AM   #882
David_Moen
David_Moen's Avatar
Oddometer: 1,283
So how's the manufacturing coming?
2013 KTM 350EXC-F, 2005 BMW R200GS, 1984 Kawasaki GPz 750
David_Moen is offline
Old 06-03-2011, 06:22 PM   #883
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
I'm sorting out the holding fixture for the potting process. There's a lot of items to hold in place just so. Also, how to pour the epoxy and fill the box without making voids. Pour is the really wrong term here, there's no way to pour it, the gaps are too small. Imagine trying to pour maple syrup down a straw.
I'm working on two different methods. One method is to fixture the board exactly aligned, and inject the epoxy with a large bore syringe. The other is to pre-fill the epoxy by weight into an empty box, then plunge the completed board and wires into it.
The hypodermic method has its advantages, but half the time the epoxy doesn't fill properly under the board and a bubble forms, only to pop out later right as the epoxy is setting. Grrrr. The plunge method also has things going for it, but it's very easy to make a small splash. And at this postage stamp scale, a small splash is a wave. Hang five.
I'm going to try a one half pre-fill, then plunge the board and fixture it, followed by a post-fill to the final level. That seems like the best parts of the two methods.
As you can imagine, a mistake during this step makes a scrap part.
Poolside is offline
Old 06-03-2011, 07:23 PM   #884
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,640
Shoot-me-now. That's what I'd be saying if it was me. But, since it's not me, keep on keeping on. You are almost there. We'll keep cheerleading. Not sure how much that helps.....but , hey. It's all we got.
RTB V- The Texas ADV Rally- Hurry before we fuck this up!
"If you can't fix it with a hammer you can damn sure teach it a lesson".
slowoldguy is offline
Old 06-03-2011, 07:33 PM   #885
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Hey I can't complain, this is a good job. One of the guys on this board calculated that I'm making $0.75 an hour. Every six hours I have enough to buy a Latte at Starbucks, with enough left over to tip the barista!
I'm in Fat City over here.
Poolside is offline
Closed Thread
Times are GMT -7.   It's 08:57 AM.
