Closed Thread
Old 06-03-2011, 07:51 PM   #886
Cranky Yankee
exulcero
Cranky Yankee's Avatar
Oddometer: 602
Originally Posted by Poolside View Post
I'm sorting out the holding fixture for the potting process. There's a lot of items to hold in place just so. Also, how to pour the epoxy and fill the box without making voids. Pour is the really wrong term here, there's no way to pour it, the gaps are too small. Imagine trying to pour maple syrup down a straw.
I'm working on two different methods. One method is to fixture the board exactly aligned, and inject the epoxy with a large bore syringe. The other is to pre-fill the epoxy by weight into an empty box, then plunge the completed board and wires into it.
The hypodermic method has its advantages, but half the time the epoxy doesn't fill properly under the board and a bubble forms, only to pop out later right as the epoxy is setting. Grrrr. The plunge method also has things going for it, but it's very easy to make a small splash. And at this postage stamp scale, a small splash is a wave. Hang five.
I'm going to try a one half pre-fill, then plunge the board and fixture it, followed by a post-fill to the final level. That seems like the best parts of the two methods.
As you can imagine, a mistake during this step makes a scrap part.
I still have my old vacuum pump used for epoxy potting runs.
Wanna trade for one of the upcoming 1200 can-bus modules?
I'm done with the carbon fiber molding crap.
(yeah, modified dishwashers, flux and DI bottles, those were the days. )
How much easier it is to be critical than to be correct. Benjamin Disraeli
Cranky Yankee is offline
Old 06-03-2011, 08:39 PM   #887
David_Moen
David_Moen's Avatar
Oddometer: 1,293
I've heated epoxy in advance of using it laminating balsa before. It thinned out real nice, then when the heat set off the epoxy, it hardened up in a hurry! Thinning the epoxy may make getting a even bubble free fill a little easier. But what do I know, I'd end up gluing my eyelid to my cheek or something.
Thanks for your hard work. If you decide to charge more for your phase II product, I for one won't hold it against your!
2013 KTM 350EXC-F, 2005 BMW R200GS, 1984 Kawasaki GPz 750
David_Moen is offline
Old 06-03-2011, 11:43 PM   #888
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
I've once or twice microwaved epoxy for a few seconds to thin it out. This particular mixed epoxy is about the consistency of thick molasses or cool honey. Not too bad for a pour-in-place operation. I would not want to brush it though.
I must settle for the increased viscosity because in this case I need all the working time I can get. The interim steps between mixing, filling, and placing and fixturing the assembly uses up many of the available minutes.
Thanks for the props. When you folks get these goodies on your bikes, it will all have been worth it.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline
Old 06-06-2011, 04:19 AM   #889
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Assembly report.
I'm posting this on a netbook from down in the shop. Somehow the wireless router can reach down here now, go figure.
Anyway, I'm crimping and soldering, and waiting for epoxy to cure. Man, 36 hours for a full cure is a long time! A little while ago I rigged up an oven of sorts to try to speed the epoxy curing process. Here's a data point for you... A 75 watt light bulb heats up the inside of a 1ft plastic box to 60/140F! According to the datasheet, at that that temperature the epoxy should cure in 3 hours.
Poolside is offline
Old 06-06-2011, 06:17 AM   #890
jbdesigns
jbdesigns's Avatar
Oddometer: 91
You made an easy bake oven!
"Governments first duty is to protect the people, not run their lives" Ronald Reagan
jbdesigns is online now
Old 06-06-2011, 12:28 PM   #891
Codewheeney
Hoopy Frood
Codewheeney's Avatar
Oddometer: 2,681
Are we going to get cookies with our order?
Jim
Morgan Hill, CA - 2015 R1200GS, 2004 R1150GS.
Plays in traffic.
Codewheeney is offline
Old 06-06-2011, 12:32 PM   #892
rtortore
'00 R1150GS
rtortore's Avatar
Oddometer: 463
I am not sure if it is sad or funny but I was thinking the same thing
Here is a photo of him in action (too big for a inline post)
http://4.bp.blogspot.com/_1A-txrEn9M...+bake+will.JPG
R
"From the point of ignition
To the final drive
The point of the journey is not to arrive
Anything can happen."
rtortore is offline
Old 06-06-2011, 04:26 PM   #893
Monsignore
Plunger Boy
Monsignore's Avatar
Oddometer: 919
Ooh! Ooh! I want oatmeal raisin!
Ewig war ich.
IBA # 55612
Monsignore is offline
Old 06-06-2011, 06:08 PM   #894
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Hey, easy fellas! That's not too far from the truth you know!
It looks like this test oven works ok. I just have to scale it up a little. I'm off to the hardware store to get more oven parts.
Poolside is offline
Old 06-06-2011, 06:24 PM   #895
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,704
A bigger cardboard box? A higher wattage bulb? Brownie mix?
RTB V- The Texas ADV Rally- Hurry before we fuck this up!
http://www.rollthebonesrally.com/
"If you can't fix it with a hammer you can damn sure teach it a lesson".
slowoldguy is offline
Old 06-06-2011, 07:23 PM   #896
rtortore
'00 R1150GS
rtortore's Avatar
Oddometer: 463
Ever tried his brownies? ... they have a special someth'n someth'n in there - directly imported from BC
Looking forward to the taste test ... err ... final product.
Richard
To the final drive
rtortore is offline
Old 06-06-2011, 08:58 PM   #897
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
http://cherrypatter.com/wp-content/u...ke-cupcake.jpg
Poolside is offline
Old 06-07-2011, 06:58 AM   #898
ghostrider1964
Edumacated Red Neck
ghostrider1964's Avatar
Oddometer: 6,926
I have made custom ovens out out foil back insulated board. With two bulbs and a reostat, I varied the Temp of the oven from low 100s to as high 375 I used it cure baked on finishes on weapons
2008 R1200 GSA (Ghostrider), G650 X/Challenge
"Fuck'em. I'm a lifer. " SlowOldGuy
"The older I get, the faster I was", HardyBaker
TEXAS-ROLL THE BONES RALLY 6 10/23-10/25/2015: ?.......
ghostrider1964 is offline
Old 06-07-2011, 09:34 AM   #899
jbdesigns
jbdesigns's Avatar
Oddometer: 91
Poolside, if you put a couple of 500W halogen lights in your easy bake epoxy cure oven, do you think we will get this goodie before fall? I've got some splines to strip out on my 04 GSA.
Old 06-07-2011, 05:21 PM   #900
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Great minds! I was thinking about that material yesterday. With that material I could build the oven to any specific size. Right now I'm using a double thickness of corrugated cardboard. It works ok, but of course it doesn't insulate like the polyiso foil sheets. And would take a lot of 'light bulb' energy to heat a large oven.
I have another oven design in mind for a different application and I'm leaning toward an aerogel sheet product called Spaceloft. (http://www.aerogel.com/products/overview-product.html)
Got wheelies? Seriously though, I want to help with breaking your bike :-), and the 500W bulbs will certainly speed up the epoxy cure, but the maximum service temp of the vinyl jacket for the wire harness is 80C/176F.
Poolside is offline
Closed Thread
Times are GMT -7.   It's 03:33 AM.
