Closed Thread
Old 06-17-2011, 10:14 AM   #931
ghostrider1964
Edumacated Red Neck
ghostrider1964's Avatar
Oddometer: 6,775
Originally Posted by slowoldguy View Post
Measure twice, cut once. Keep doing it right. Ain't nobody dying here. Except ghost. ;) lol
Hey..I resent that...I hurting like hell from the peridontal experience yesterday...least it wasn't the proctologist
2008 R1200 GSA (Ghostrider), G650 X/Challenge
"Fuck'em. I'm a lifer. " SlowOldGuy
"The older I get, the faster I was", HardyBaker
TEXAS-ROLL THE BONES RALLY 6 10/23-10/25/2015: ?.......
http://www.rollthebonesrally.com/
ghostrider1964 is offline
Old 06-17-2011, 06:54 PM   #932
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 15,817
In researching the physical, and thermal requirements for the coating we need, we determined that an extra thick coating of a quality polymer is the ideal solution.
What we need is full encapsulation to keep what little moisture the IICE Air might see from touching the thermistor. Certainly repelling a little water is an easy task for most any coating. We also need to keep the thermal conductivity high so they respond quickly to changes in ambient air temp.
Usually in automotive paint applications the paint is thinned down and applied in very thin coats, here we want a very thick coat, like a big dollop. We also have a need for multiple colors.
The range of temperatures these devices will see is significantly lower than in normal automotive uses. Because of that we aren't concerned with aging, since there won't be any direct solar exposure nor anywhere near the thermal extremes like the hood of a car would see.
We even considered a prophylactic approach but we couldn't find ANY mouse condoms
JJ
• The hidden harmony is found with joy, while the obvious brings indifference.
• The farther you enter into the Truth the deeper your conviction for truth must be.
• There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is offline
Old 06-21-2011, 07:06 AM   #933
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,872
Assembly report.
Ok, I have a pair here curing in epoxy. I think these are the magic.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline
Old 06-21-2011, 08:44 AM   #934
Kawidad
Kawidad's Avatar
Oddometer: 4,751
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline
Old 06-21-2011, 09:11 AM   #935
DualMule
Oddometer: 306
JJ
Really? A thick coating seems counter-intuitive to me: thicker coating = more insulation = slower response to temperature changes. I suppose that for this application it may not matter. What about a polyurethane or epoxy glue?
Just trying to help...
DualMule is offline
Old 06-21-2011, 09:36 AM   #936
jbdesigns
jbdesigns's Avatar
Oddometer: 90
Thinking that temperature will vary gradually over time. From morning to mid day temperature change is not very rapid. Even driving up or down mountain, temps change at a rate I would think this sensor with a coating on it would be able to keep up with without much lag at all
"Governments first duty is to protect the people, not run their lives" Ronald Reagan
jbdesigns is offline
Old 06-21-2011, 02:48 PM   #937
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 15,817
Thanks for the input.
We considered a variety of options and the thick polymer coating provided the easiest means of application and curing, water protection, color choices and thermal conductivity of the available coatings.
JJ
WingMakers.com
johnjen is offline
Old 06-21-2011, 07:54 PM   #938
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,872
+1 on thanks for the input.
I understand how the description of a 'thick coating' doesn't sound right, BGS, but it's a relative term. The thermistor element is a tiny object, about 1/2 the diameter of a BB. That's pretty tiny, you know? In real terms, the coating is 0.020in/0.5mm thick. But in relative terms, compared to the scale of the tiny sensing element, it's a larger percentage of the overall diameter.
In more important relative terms, relative to sensing changes in temperature I mean, the poly coating is 'paper thin'.
Here's a good point of reference. The stock BMW Intake Air Temperature sensor element is over-molded in plastic. As a point of reference, the stock BMW air temp sensor responds to the heat of human breath in approximately 2 seconds.
Poolside is offline
Old 06-21-2011, 08:33 PM   #939
DualMule
Oddometer: 306
Busted! I admit it...at the end of the day I'm a T&A guy...the day job of bioMEMS development is just bait for the bunnies. Why the GSA? because some times the A is a lot bigger than the T...I get away with it because I live in a state that requires a helmet.
Seriously, nothing but respect. I read JohnJen's post and jumped to a reply.
DualMule is offline
Old 06-21-2011, 10:39 PM   #940
thealaskan
Oddometer: 30
Well, after reading the intro salvo I couldn't bother through another 63 pages of smoke & mirrors. Sorry in advance if that offends anyone.
The main ingredients any stuffed up EPA regulated air cooled motor needs are 1, cams, 2, intake, and 3 exhaust, 4, valves (heads) & timing, and given the techno computo these days the ECM that controls all that, fuel flow, etc., needs to be adjustable.
And that's really about it in practical terms. There is no magic coating.
thealaskan is offline
Old 06-22-2011, 05:31 AM   #941
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,872
Sure, there is no magic coating, but there is magic. I'll have a couple of extra if you want one.
The ECU "techno computo" as you say, is adjustable by external means. These external adjustments aren't about high RPM horsepower. Rather they produce power, driveability, and wonderfulness in the power range that we spend all our time.
Poolside is offline
Old 06-22-2011, 01:47 PM   #942
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,872
Assembly report.
Look at the little darlings in their potting fixture. Everything is looking good! It took many iterations to get to this fixture configuration.
Thanks to Mr Head for the fixture idea. Using a second vial lid as the holder is a great idea!
The silver pills are the thermistor sensing elements. As the final step in the assembly process, the thermistors get a protective polymer coating. The coating's affect on temperature response time is nil. A coated thermistor responds to the heat of human breath in roughly 1 second. As a point of reference, the stock BMW sensor responds to breath in 2 seconds
Poolside is offline
Old 06-22-2011, 02:47 PM   #943
Cranky Yankee
exulcero
Cranky Yankee's Avatar
Oddometer: 601
To speed things up...
  • Some weak springs to turn the all-thread/cap into a spring loaded plunger.
  • Use some of the cheapo velcro wire ties on a roll from Home-depot instead of cable ties to hold the wires.
  • Good coffee!
“How much easier it is to be critical than to be correct.” – Benjamin Disraeli
Cranky Yankee is offline
Old 06-22-2011, 10:28 PM   #944
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,872
  • Good coffee!
Thanks for the ideas!
Here are some things that the thread/cap needs to do. Before tightening, the cap end of the thread must swing freely approx. 30° to either side. The thread itself must move freely up and down in the metal angle. Those two requirements are to allow the completed board assembly to swing to the side and plunge into the epoxy-filled enclosure at an angle. That removes all the air under the board. Then the board must be slowly lowered through the epoxy and then held just above the bottom of the box. The preceding processes take about 2 minutes. The assembly sits in the fixture for 18 to 24 hours. Most importantly, when the fastener at the metal angle is tightened, the tightened fixture holds the completed board fixed in all 6 axes.
I was thinking about removable ties. I tried a trimmed down velcro wire wrap, but there just isn't enough room for all of it. I'm going to the grocery store later, I'll pick up some twist ties.
Good coffee is always a winner!
And tunes! Tomorrow is Triple Live Thursday on KSWD! All day it's three recorded-live songs in a row, from some artist. There's a 'listen live' stream at www.thesoundla.com
Poolside is offline
Old 06-23-2011, 11:02 AM   #945
KCDakar
What are we waiting for?
KCDakar's Avatar
Oddometer: 3,388
Would something like this work? (customized to move as you need)
http://www.destaco.com/products.asp?loc=&products=Clamps〈=&Category_1=Vertical+Handle+Hold-Down+Clamps
To me, the best kind of trips are the ones you planned on the way, allowed yourself to change, and maybe didn't end up where you expected. Klay
Save $5 on Smugmug by entering coupon code: GJBcMk1uLoZm6
KCDakar is offline
Closed Thread
Times are GMT -7.   It's 11:57 PM.
