07-11-2011, 01:05 PM
#1021 |
Oddometer: 479
lazy bugger
can't be bothered to read it allagain, will my camhead run like the wind with this gizmo?
and now I drink Orange Crush as well |
07-11-2011, 01:09 PM
#1022 |
Oddometer: 1,048
It's been a week since the first "production" gizmos hit the street. Are you able to say when you will be able to fill the rest of the orders yet?
2013 KTM 350EXC-F 2007 KTM XC300 (for sale!), 2005 BMW R200GS, 1984 Kawasaki GPz 750 |
07-11-2011, 05:05 PM
#1023 |
Oddometer: 80
Poolside:
How come you did not use a waterproof, 4 position rotary switch instead of the jumper? ![]() I've got some good experiences with mechanical engineering/design of low volume production-quality parts from Quickparts.com (I am not affiliated in any way, just appreciate the service) and at first look figure that it might have added maybe $8 to the COGS (at 100+ units). Not complaining or anything, your project rocks just the way it is ,just wondering if you had a specific reason |
07-11-2011, 05:36 PM
#1024 | |
exulcero
Oddometer: 594
“How much easier it is to be critical than to be correct.” – Benjamin Disraeli |
07-11-2011, 06:05 PM
#1025 |
Mod-U-Later
Oddometer: 13,506
Ok so marketing will chime in here. And this isn't meant to be what engineering was thinking during design, just what I remember.
Over the long haul the seals will break down. After a few freeze/100º+ thermal cycles the seal will deteriorate and when the switch fails the whole unit will fail. And then there is the torque needed to rotate the switch on such a small unit. Not that, that can't be (at least partially) dealt with, again thru time the applied torque will tend to lead to a break down. And yes the cost was a factor in keeping the unit price down. Such was the thinking at the time (if memory serves). JJ
QUOTE from vermin I lie to myself because I am the only one who continues to believe me. |
07-11-2011, 06:44 PM
#1026 | |
Oddometer: 80
It's always the question which of the parts will break down first and then figuring out, how one can make that one last longer, isn't it? From what I can see from the pictures, the part now most likely to fail first is the cap sealing in the jumper. It needs to be snapped on/off every time one wants to change the jumper. Assuming I guess the material property of it right, it will probably simply start loosing its sealing ability rather than breaking off, time-to-failure much depending on how often it is used. However, if I understand your design right, even with a completely ripped off cap, due to the complete submerging of the actual active components in the epoxy, the device itself should still not fail, as long it is mounted (i.e. sideways) so that water can not collect in it and shorting out the pins, right? So, even in a worst case (cap gone), one only would have to apply something to keep the pins from rusting, and it should work forever, right? - NICE! ![]() Just out of curiosity, what would happen (to the device, and as a result to the bike's electronics) if someone manages to submerge all pins in water (say you drop your bike in a river crossing - let's ignore all the other nice issues one would have to deal with in such a case)? |
07-11-2011, 07:25 PM
#1027 | |
Mod-U-Later
Oddometer: 13,506
And even IF the cap were missing as long as the plug jumper were in place, the unit will still function. AND as a fall back in case of complete unit failure, for whatever reason, all you have to do is plug the original cable from the ECU back into the original air temp sensor and the unit is out of the circuit and the bike will resume 'stock' operation. JJ
07-11-2011, 09:49 PM
#1028 |
Oddometer: 80
Just let me say as a fellow engineer, it is a pleasure seeing this much care and thought put into a design. In these days it happens so rarely!
One word: Ausgezeichnet!
07-12-2011, 01:06 AM
#1029 | |
Syndicated
Oddometer: 11,286
Poolside screwed with this post 07-12-2011 at 01:14 AM |
07-12-2011, 05:14 AM
#1030 |
Oddometer: 9
I have a (new to me) '09 gs I would like to add the IICE part to, are they still available or on hold?
07-12-2011, 05:27 AM
#1031 |
Oddometer: 106
![]() I can see active military on the short list they earned it. ( vet here).
2000 R1100RT, Opel blue 2006 Zuki C50 w/ modified C90 drive.
07-12-2011, 05:30 AM
#1032 |
Oddometer: 614
I have asked that quetion 2
07-12-2011, 05:32 AM
#1033 |
Oddometer: 9
I would just like to order to get on the list, but the link is down for the "buy" button, and I didn't see an update on future orders.
07-12-2011, 01:35 PM
#1034 | ||
Mod-U-Later
Oddometer: 13,506
But first a word from our sponsor. The order desk staff is currently building IICE-Airz and he is chained to the table as a demonstration of our commitment to YOU our valued customers. Please come back again when we let him off his chain. See the above marketing announcement of a future marketing announcement of when the order desk will again be available. Thank You The Marketing Dept. JJ
QUOTE from vermin I lie to myself because I am the only one who continues to believe me. johnjen screwed with this post 07-12-2011 at 02:23 PM |
07-12-2011, 02:33 PM
#1035 |
Oddometer: 80
So I've been thinking about how to solve the issues that made using a jumper the better solution.
Just to be clear, this aspect has caught my interest on a pure engineering-challenge level, and in now way am I suggesting that your awesome device needs any improving in any way shape or form. In this spirit, if you rather not have a discourse on this subject / in this thread, just say the word and I'll leave it alone, nullo problemo. On the other hand, if you find this interesting, maybe for a future revision, You could have me step up to the plate and put my Solidworks where my mouth is ![]() A while back I was working on a project involving magnetically actuated relays. Using that principle, I could see a design, in which one could solder 4 such relays to your current pin locations on the board (in star form), and then mount the dial with a small cylindrical magnet at the edge on top, rotating the magnet over the 4 relays in turn. The electronics would be completely submerged in the epoxy (100% sealed) and the dial could use a simple spring loaded detent structure to arrest in the four positions (aligning the magnet over the four relays respectively). There would be no need for seals, the design can fit easily inside your current enclosure envelope, the actuation would be contactless and thus the only thing that possibly could break, would be the dial construct. That, being mechanical, could be designed as a replaceable assembly - leaving a choice of going german-style for longevity (higher quality parts, construction, respective cost) or ultra cheap, just-replace-it-if-it-ever-breaks-style, with a clip-in live-snap all plastic design (maybe three componetnts plus magnet). Of course, Due to the additional components, it would cost a few bucks more in materials. However, a design like this, should also be able to be optimized to create benefits for the assembly process, shaving off some time/money there, and I submit, that it would provide a benefit to the enduser that they should be happy to pick up the difference - they get a dial with engraved info what setting is what, and depending where it is mounted, it could be even blindly adjusted on the "fly"... |
