Closed Thread
Old 08-18-2011, 08:03 AM   #1201
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,384
After 5 tanks of gas my testing is complete.
My bike and I prefer the -20 position.
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is offline
Old 08-18-2011, 08:14 AM   #1202
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,267
Originally Posted by Boxerwrench View Post
Wow must be real hard to work w/ all those tiny X 's
looks good to me.
Jim
JimVonBaden is online now
Old 08-18-2011, 08:35 AM   #1203
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,609
Mr. Head. At the risk of getting too excited, can you elaborate on what you found ?
And Poolside, thanks for the teaser pics.
RTB V- The Texas ADV Rally- Hurry before we fuck this up!
http://www.rollthebonesrally.com/
"If you can't fix it with a hammer you can damn sure teach it a lesson".
slowoldguy is offline
Old 08-18-2011, 08:57 AM   #1204
Boxerwrench
Boxerwrench's Avatar
Oddometer: 106
Well all I see are the X's
2000 R1100RT, Opel blue
2006 Zuki C50 w/ modified C90 drive.
Boxerwrench is offline
Old 08-18-2011, 09:13 AM   #1205
JimVonBaden
"Cool" Aid!
Oddometer: 52,267
Might be blocked on your work computer?
Jim
Old 08-18-2011, 09:20 AM   #1206
Lonestar2112
scatology expert
Lonestar2112's Avatar
Oddometer: 7,203
I see mine in that pile.
Some suggestions; get rid of the coffee and Kit kat, replace with Jolt and some Levi Garret. Lets get this show on the road.
Yes I know, I am now at the back of the line.
Kidding of course, It is looking good. I still can't ride, so I am Jonesing REAL BAD.
http://share.findmespot.com/shared/f...SKgzdmS9ir0XK3
Wypierdalaj ty chuju jebany
F*CK CANCER
Lonestar2112 is online now
Old 08-18-2011, 09:54 AM   #1207
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,609
Me and you, bro. But we're hanging in there. I just want to open the package from poolside and make vroom-vroom noises while holding it near the bike.
3 more weeks at least before the sturgeon releases me.
Old 08-18-2011, 10:51 AM   #1208
Boxerwrench
Oddometer: 106
Question
No work 'putter but I can see them on my IPhone.
Strange.....might be my security setting and that site doesn't pass.
Old 08-18-2011, 11:03 AM   #1209
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,384
Configuration:
2004 1150 GS Adventure, 171,000 miles.
Stock headers, and CAT, TT end Can.
OEM Air Filter.
Removed BBoC, in the interest of beginning from closer to stock.
TPS value unknown, but seems fine. It was fine last time I checked.
Good sync on TB's, Valves are fine.
Idle has always had a hesitation and slight bog off idle. The idle is set to about 1100 rpm is, maybe about 1200.
Removing the BBoC, and installing the IICE the hesitation is gone. This was enough to stall the motor if I did not have a hand on the throttle at warm-up. This is no longer the case. The idle is nearly as steady as any BMW I've ever worked on, (I've had BMW dirt under my fingernails since the mid 70's).
No Change:
No change felt, slightly lean in my configuration.
No different from the IICE being absent.
But, this is better than stage one settings on the BBoC.
-10
Still feels slightly lean.
No surging, but less smooth than -20.
Feels less strong when whacking the throttle than -20.
Closing throttle feels slightly more abrupt than the -20.
Harder to spin the rear up in the canyons. I almost stopped at a shady turn out and changed back to the -20, but in the interest of testing I "stayed the course"... I didn't like it, but I did it.
-20
Best throttle response which is apparent right off the stand.
Very nice.
Smoothest throttle response when opening and closing.
Seat of the pants feels like much better power.
In the mountains I was easily able to spin the rear TKC80 past traction, which is fun.
-30
Seems rougher on and off throttle, i.e. opening and closing.
Feels less powerful than -20.
More abrupt off throttle response.
Summary and Whatnot:
My bike has had the TPS and screwed with, as well as the LHS TB rebuilt, the seal at the shaft was leaking. "Zero" is unknown on my bike. The bike has been screwed with.
Fuel Economy did not stick out as an issue. The tanks I ran through were over nearly two weeks of commuting through traffic and a weekend playing in canyons. I did not see any great variation other than at -20 in the canyons I seemed to be burning fuel somewhat more quickly and spinning the rear tire up a bit easier than at -10, or even -30.
To me the difference between -10 and -30 are less than the difference between all settings and -20. In my bike -20 feels that perfect.
There is this little wheelie bump at the bottom of my hill that I get to jump every night on my way home form work. Yeah, commuting is tough.
I used this exercise to eliminate any altitude affects on my testing since I'd spent the weekend wandering up and down mountains. The -20 position is just flat amazing at this task. With a freshly full tank last night the front comes up real easy with a throttle dip. No big exaggerated movement required at all.
-30 on this feels almost like a fat carb.
-10 feels lean at this.
When I initially installed the IICE it was in the -20 configuration, so I ran a tank with that, then pulled the BBoC, and re-ran the -20.
A tank runs about 280 miles or so.
I'm on my sixth tank of fuel from last night.
My usual commute speeds are something more than the posted limit, but just keeping up with traffic. some might interpret this as speeding. The motor officers all pass me.
...Dick
Smugmug
Mr Head is offline
Old 08-18-2011, 11:04 AM   #1210
Lonestar2112
scatology expert
Oddometer: 7,203
I already warned my bride that when I get back on the bike I might be gone for a day or two. I told her to check my spot and thats where I'll be.
Hell I might even drive out to Texas, just cuz! Wait what am I thinking, it is hell kind of hot out there. I just ride Death Valley, it is probably cooler.
F*CK CANCER
Old 08-18-2011, 11:13 AM   #1211
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,609
Great job with the detail, Mr. Head. I do appreciate it.
Old 08-18-2011, 11:56 AM   #1212
Spoke
Savage
Spoke's Avatar
Oddometer: 785
Nice, Head!
Rich
It entered my blood in 1970 on a Honda QA50
Spoke is offline
Old 08-18-2011, 12:04 PM   #1213
Lonestar2112
scatology expert
Oddometer: 7,203
Did anybody take note of:
"Configuration:
2004 1150 GS Adventure, 171,000 miles."
171K on an '04. Thats better than 24K per year. I am impressed. I hate to say that I don't have 24 K on my '07.
F*CK CANCER
Old 08-18-2011, 12:14 PM   #1214
zcfrederick
Oddometer: 45
Pinging
Does it help getting rid of the obnoxious pinging?
zcfrederick is offline
Old 08-18-2011, 01:08 PM   #1215
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,384
Mine only pings if I lug the bike uphill, or lug it on the flat in hot weather. Triple digits, F...
It was hot this weekend, and we were following part-time pirates and tourists at times. No pinging.
...Dick
Smugmug
Mr Head is offline
Closed Thread
Times are GMT -7.   It's 10:20 PM.
