Closed Thread
Old 08-18-2011, 06:17 PM   #1231
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 15,817
I can't help myself……
Marketing ALWAYS sez
YES!
JJ
• The hidden harmony is found with joy, while the obvious brings indifference.
• The farther you enter into the Truth the deeper your conviction for truth must be.
• There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is offline
Old 08-18-2011, 08:21 PM   #1232
Plane Dr
Plane Dr's Avatar
Oddometer: 847
Who let him (Poolside) out of the cage to post? He's supposed to be sniffing epoxy or some such.
01/09 DRZ470SSW more bits than necesary
2005 R1200 GS AKA The Mothership
2003 Z1000 Nuclear Pumpkin (gone)
86 RG500WW (gone)
Bikes are like women. What you think you want, and what you want, change after the first ride.
Plane Dr is offline
Old 08-19-2011, 06:50 AM   #1233
frogy
frogy's Avatar
Oddometer: 808
I think he came up for air.
frogy is offline
Old 08-19-2011, 03:54 PM   #1234
Boxerwrench
Boxerwrench's Avatar
Oddometer: 106
Laugh
I think the natives are getting restless..................
2000 R1100RT, Opel blue
2006 Zuki C50 w/ modified C90 drive.
Boxerwrench is offline
Old 08-19-2011, 05:12 PM   #1235
vintagerider
vintagerider's Avatar
Oddometer: 1,964
'96 R 1100 GS
old style TB's, single throttle cable
stock exhaust
Bosch 4417 plugs
stock air filter
wide, non-stock air inlet/horn
stock 1100GS air tubes
stock stop screw settings on TB'
99 low mileage injectors
fuel prep and delivery system well maintained
CO pot not currently installed
new Lambda, pink CCP config
1150 HES
Howdy Jim, JJ
Would like to know if one of these wunderwaffe is right for me.
Pinging is intermittent. Can be be severe at times and almost non-existent at other times at the same ambient, same route and load. Pinging, when it's severe, is usually accelerating on the freeway ramp or passing, above 4k rpm. Suspect a sticky barometric pressure sensor if that's possible because I notice it more right after dropping down from 2,000 ft to <500ft.
Other:
Recently had problems idle stalling at >7,000 ft which I never had before. Had to leave cold idle on to keep from stalling at high elevation.
Possible upgrades:
Have a clean set of Bing 144/113 w/ updated throttle wheel compatible with late style 1100 bowden throttle planned for install this winter. That will require the new style battery box. (JJ thanks for the link to the airhead throttle cable splitter). Have a 99 1100R Mo 2.2 which I could try also.
When riding >5k ft loaded in the summer I need to back the throttle, down to 4k to prevent heat build up, although I rarely notice severe pinging at elevation. Hoping that one of these products will solve the pinging problem under 2k ft and also allow temporary fuel enrichment under certain high ambient, high load,/high speed conditions. Would like to be able to switch from performance to economy mode while underway.
Decel pop has also been annoying and on-off throttle response seems to have worsened. Rubber manifolds have been replaced but haven't tried RTV on them yet. Considering new injectors and an adjustable fuel regulator. Thanks.
vintagerider is offline
Old 08-19-2011, 05:48 PM   #1236
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,872
(Taking a cue from Marketing.)
Yes, yes, and . . . wait for it . . . .
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline
Old 08-19-2011, 07:23 PM   #1237
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,423
I can still remember back when I placed that order... still had all my hair, I did.
Splitting lanes, and splitting hairs.
Andrew is offline
Old 08-19-2011, 07:27 PM   #1238
Geoffster
Fool - Born This Way
Geoffster's Avatar
Oddometer: 1,368
Back before Babe became bacon ...
Geoffster is offline
Old 08-19-2011, 07:34 PM   #1239
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,423
Andrew is offline
Old 08-19-2011, 07:54 PM   #1240
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 15,817
And by now EVERYONE knows
YES
JJ
WingMakers.com
johnjen screwed with this post 08-19-2011 at 11:57 PM
johnjen is offline
Old 08-19-2011, 08:19 PM   #1241
Boxerwrench
Oddometer: 106
sooooo.....if marketing always says yes.......That mean I will get an IICE Air for free when it comes out??????
Old 08-19-2011, 09:14 PM   #1242
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 15,817
YES
in your dreams
JJ
ps marketing NEVER wants you to read the fine print
WingMakers.com
johnjen is offline
Old 08-20-2011, 07:21 AM   #1243
Boxerwrench
Oddometer: 106
son of a Ferengi...............
Old 08-20-2011, 07:41 AM   #1244
tagesk
Tuscan rider
tagesk's Avatar
Oddometer: 3,210
Sir,
Does that cup contain black tea, or do you drink Coke from mugs.
[TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here.
Renting out motorbikes in Toscana, Italy
Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index.
IBA: 33616
tagesk is online now
Old 08-20-2011, 07:57 AM   #1245
Boxerwrench
Oddometer: 106
I'm guessing bourbon & branch water.........and the marketing jailers think its coffee
Closed Thread
Times are GMT -7.   It's 02:21 AM.
