Closed Thread
Old 09-09-2011, 08:25 PM   #1411
RomaDakota
Illuminatus!
RomaDakota's Avatar
Oddometer: 1,452
Higher altitude = less dense air = leaner fuel mixture.
Same as... Higher temp air
We call it "density altitude".
By saying to use the -30 setting at cold temps means the air is more dense at cold temps so more fuel is needed to maintain the mixture. Hence the more negative the setting, the richer the mixture.
КМЗ Dnepr MT11 // КМЗ M72 // ИЖ Planeta 5 // КМЗ MV750 // Урал М63 // BMW R1200GS 30th
RomaDakota is offline
Old 09-09-2011, 11:18 PM   #1412
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,878
Originally Posted by duckboy View Post
how does your device differ from the Accelerator Module? i currently have one of those my '09 R12RT but when riding in warm/hot-ish weather the throttle response goes soggy, like stock, mostly when blipping the throttle for down shifting... kind of scary behavior when splitting lanes in downtown 110 traffic. feels like the engine's gonna bonk.
Can't wait for your next production run!
That's good to hear! Here's a few more words about the differences between the IICE Air, and the other competitive products.
JJ and Boxerwrench answered in the Vendors thread that the IICE Air is adjustable. Adjustability makes a performance difference but there's something more important beyond that.
To work with the upcoming IICE Cool product, the IICE Air must be set to -10C. If the air temperature device isn't adjustable to -10C then it will not work with the IICE Cool.
You mentioned that quick throttle response seems a little soft when the motor warms up. The upcoming IICE Cool is designed to address that type of issue.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline
Old 09-10-2011, 05:07 AM   #1413
Plane Dr
Plane Dr's Avatar
Oddometer: 857
Originally Posted by Gangplank View Post
Check by the pool. Just say'n.
Better not be by the pool, better be workin'.
Well unless he can move the fixtures outside. But then the neighbours may call the cops. "The guy is in the back yard with scales, white powder and syringes, hard to see what else he's doin...."
01/09 DRZ470SSW more bits than necesary
2005 R1200 GS AKA The Mothership
2003 Z1000 Nuclear Pumpkin (gone)
86 RG500WW (gone)
Bikes are like women. What you think you want, and what you want, change after the first ride.
Plane Dr is online now
Old 09-10-2011, 10:39 AM   #1414
frogy
frogy's Avatar
Oddometer: 811
Even worse...yea officer,at the house next door I can see a man soldering eletronic items together and there are a lot of chemicals laying around.UPS trucks are always there picking up large envelopes,and I see a van in his garage.
frogy is offline
Old 09-10-2011, 05:33 PM   #1415
Happy Wanderer
Day Dreaming.. .
Oddometer: 206
Originally Posted by wrysingfeenix View Post
UPDATE: I have ridden about 1,400 miles since installing the IICE-AIR, including an 800 mile ride varying from hot, arid, 4000' elevation desert to cooler, humid 9000' elevation mountain terrain. I'm more than satisfied with the performance improvement. I made a change from the -10 degree setting to the -20 degree setting when it became obvious it was running rich at higher elevations (and which had an immediately noticeable positive effect).
During that ride, I averaged 48 and 51 mpg on each of two tanks of gas, which has never happened before. Otherwise, I continue to average 40-42 mpg with this bike even though I am much more spirited with the throttle. I did do a cam chain tensioner upgrade right after installing the IICE-AIR...I have no idea if that might be a factor.
I've left it at the -20 degree setting since returning to the desert environment where it's been in the 90's, and haven't reset yet. Performance is still much improved compared to pre-IICE-AIR.
Does your bike still have the CCP and O2 sensor installed or was this removed with your previous surge fix? (potentiometer)
Happy Wanderer is offline
Old 09-10-2011, 09:43 PM   #1416
wrysingfeenix
Dust off those ashes
wrysingfeenix's Avatar
Oddometer: 633
The CCP and the O2 sensor were removed when the Remus exhaust and potentiometer were installed.
---'99 BMW R1100GS
---'96 BMW R1100GS Mod Project ???
---'80 Honda CB750 Street Tracker Project
---'09 Vespa GT200 Granturismo
wrysingfeenix is offline
Old 09-12-2011, 04:53 AM   #1417
drmajor
drmajor's Avatar
Oddometer: 524
Hotrod GS
I have 2007GSA. Runs pretty good except for the lug at the bottom. I sync it at 4k RPM so it is very smooth there @ 70 mph.
Do I understand that your mod is $70?
What does it do to MPG??
What will be your 2nd mod?
drmajor is offline
Old 09-12-2011, 02:18 PM   #1418
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 15,932
During the original pre-order, yes.
By itself nothing. But some tend to enjoy their right wrist a bit more, and this will change the mpg.
IICE-Cool
Go to the first post of this thread for additional info.
JJ
The hidden harmony is found with joy, while the obvious brings indifference.
The farther you enter into the Truth the deeper your conviction for truth must be.
There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is online now
Old 09-14-2011, 08:58 AM   #1419
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,878
Howdy campers!
Ok here's what's been going on.
I've been setting up shop to build the upcoming IICE products on a regular basis! And also, fitting in a run of IICE Airs when the current orders are filled.
Currently there are 106 pieces left to to complete the current orders. Those are going out in 2 batches. I'm finishing up a batch of 54 pieces this week. Then 52 pieces the following week.
After this week's batch is shipped, the Vendors thread 'buy it now' button will be switched back on for ordering.
Poolside is offline
Old 09-14-2011, 09:05 AM   #1420
stuckinmud
all the time.
stuckinmud's Avatar
Oddometer: 313
Great news Jim! Now all my friends can have one too. Please put me down to be first on the waiting list for IICE Air's as well.
StuckInMud
stuckinmud is offline
Old 09-14-2011, 09:15 AM   #1421
DELTATANGO
Motorcyclist and Dog Walk
DELTATANGO's Avatar
Oddometer: 13,834
I want to buy one.
DELTATANGO is online now
Old 09-14-2011, 10:38 AM   #1422
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Sweet. I'm still waiting on one I ordered...
Ride more, bark less
Gangplank is offline
Old 09-14-2011, 10:47 AM   #1423
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,609
WooHoo!! That timing is perfect for me, Jim. My hand rehab is coming along at the same pace. Bike rehab starts this weekend. And I just know I have to be in that first batch. lol
RTB V- The Texas ADV Rally- Hurry before we fuck this up!
http://www.rollthebonesrally.com/
"If you can't fix it with a hammer you can damn sure teach it a lesson".
slowoldguy is offline
Old 09-14-2011, 10:52 AM   #1424
Lonestar2112
scatology expert
Lonestar2112's Avatar
Oddometer: 7,228
Excelent timing I will just get back from a work trip and I'll have hardware waiting on me. Oh, and add me to IICE COOL list!!!!!
http://share.findmespot.com/shared/f...SKgzdmS9ir0XK3
Wypierdalaj ty chuju jebany
F*CK CANCER
Lonestar2112 is online now
Old 09-14-2011, 10:53 AM   #1425
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,609
Yeah, I'm in for Ice whatever , too.
Closed Thread
Times are GMT -7.   It's 08:25 PM.
